Question about Refrigerators
Ice maker not working now refridge seals are hot, but still cooi
Side by side refridge, with ice maker. ice maker quit working last week and now seals around refridge or hot. It is a whirlpool, any suggestions?
Okay....i used to be an employee at Vinothque and these piece of **** units are always and I mean always running low on refrigerant, due to a slow leak in the system. You will have to get tech to come out and recharge the unit
Posted on Dec 30, 2008
Hotpoint refridger ice maker not despencing ice or water
my ice maker stop making ice there is ice cubes in the tray but the ice maker does not dispence the ice
Apr 04, 2010 | Hotpoint HSS25GFP Side by Side...
Water and Ice despensor stopped working last night.
You have a little control valve in the right lower back of your ref.It should be at the bottom.If it is bad you will not get water to your ice maker.If that is not it your ice maker is bad They are not that hard to replace.Cost for little control in back is about$30.Ice maker is about $90.
Aug 21, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ge refrigerator not making ice but once a week I dont know why it worked great and then it stops then a week later its fine again???????????????????????????????????????????????
I think your re fridge is getting to hot it will only make ice if it can freeze it, if its not staying cold enough it will cease making ice, with the weather we have been having hot one week hotter the next rain and get cool well 89deg beats 109 your refridge may be struggling to keep its cool pardon the pun. I don't think there is anything wrong with it but it is hard on the pump when it gets that hot try putting a standard box fan blowing at the coils so that it helps move some of that hot air away from it this should help some.
best wishes okcfirewall
Jul 24, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator/freezer just quit. Lights are still on
What has quit? The cooling of the refrigerator or the ice maker/ dispenser?
Jun 16, 2009 | Hotpoint HSS25IFMCC / HSS25IFMWW Side by...
Whirlpool stopped making ice, water side is fine.
Hi!
Please check to see whether the ice maker has been turned off. Here's how to check. Look for a wire along the right side of the ice maker that looks a bit like a coat hanger. If this wire is in the raised position, the ice maker is turned off. On some units you simply lower the wire to the down position to turn the ice maker on. On others, you lower a small red plastic lever to lower the wire. If the wire is in the proper position check the freezer temperature, it should be between 0-8 degrees Fahranheit. If it is warmer than 10-12 degrees, the ice maker may not produce any ice. Check your door seals and thermostat, repair/replace as necessary
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
May 27, 2009 | Whirlpool ED5SHAXM Side by Side...
Whirlpool sidebyside FF stopped working after ? motor stopped ...
this refrigertor is leaking refridgent gas it needs checked by an engineer
Feb 15, 2009 | Whirlpool 25.3 Cu. Ft. Frost-Free...
Will not cool - ice maker will not work
Hi there, if the compressor is making a lot of noise, its broken. If the compressor is running smooth with no pings, it just needs a recharge. here's another tip. check the control panel for lose connections.
Feb 15, 2009 | Hotpoint HSS25GFP Side by Side...
Ice maker stopped working
I have the same problem with my whirlpool every once in a while, and I found out that if I run a hot air dryer at the back of the fridge where the water tube comes in and along the ice maker it loosens everything up. I think that for some reason the water freezes in the tube somehow and prevents a full cycle. When I am using the hair dryer i can feel the frozen ice come sliding out of the tube. Also I know when I am getting close to thawing everything out when the ice maker runs through a cycle while I am blowing the hot air on it. Good luck.
Dec 16, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
166 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
