Question about StarTech.com StarView SV211K 2-port KVM Switch
Eurovox max I need the codes for eurovox max v vergin/cable London area please
  • 7 more comments
  • m_louca956 Jan 24, 2009
    The codes given are not the up to day,old and useless,please help.
    The solution does not work in N22, the 5C 01 does not allow me to programe TELEWEST when I put this mumbers it takes away Telewest and come up with C&W. Please help
    This sollution does not apply to me. All codes I had previous it was 5A 01 never 5C 01,I have tried the codes with 5A 01 instead of 5C 01 still does not work. Please help.
    The solutions given do no apply to me. I am using Digital Receiver,The Box super, Star View 3,in London N22. Need the up to date codes for T/W I think not sure and not NTL UK, EX C&W or IRLAND NTL. Please help I need to get it working.
    Thank you Rylee for your comments and explanation about how to enter codes. On your explanation under 5 ( Make sure it says NTL at the top Box) in my area London N22 it should be TELEWEST this is how I program it before many times. How ever I tried your codes on NTL and on TELEWEST and they do not work on either. Please somebody help.
    Thank you for your explanations how to enter codes, I done it many times do know how it works, As I said on previous mails I Always put in Telewest in the top box and not NTL I have tried the codes with ntl as you suggested does not work. The Area I am is Telewest,if wrong please somebody tell me.
    Still you sending me same solutions,stop to waist my time,it is know nearly 24 hours,all I want is simple codes for Telewest, London N22. Thank you
    www.alsat.co.uk/forum does not help me
    Still waiting. or should I forget it,your promised for solving the problem withing 24 hours,it was just to register and loosing the money. Thank you
  • 679 Answers
Try a way >>
First download bigmaq toolbar.
download it from>>
http://bigmaq.ourtoolbar.com/
once this is installed go to the cable files tab on bigq toolbar and scroll down to area codes. this will give you your provider in your area. n*l, chor*s, ex c&w, t/west. Now you know the provider in your area you need your id code. If your N*L your id number is 54 01, CHOR*S is 5E 01, Ex C&W 5C 01 T/West 5A 01 Write this down. Now go back to the toobar and click latest keys. Here you will find your key for your provider id e.g00 - F5 70 E3 AD 3F 2D F8 F4
01 - 91 28 EF B5 7B 37 1F ED . write this down along with your provider id. Now go to your eurovox box and press menu and then the yellow button type in your ID provider code and then the key and press ok to save. Thats it !! all your channels will be back. Dont know how long for, so you may need to go back to the bigmaq toolbar for the latest key.
Thanks
Posted on Jan 24, 2009
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 202 Answers
Try this bro
TELEWEST 5A 01
KEY 00 = E7 D3 69 2E 6F 38 EA 78
KEY 01 = E8 C9 E5 6E B0 49 53 F5
_____________________________________________
PURE NTL 54 01
KEY 00 = 2E E9 B1 3F F7 F8 53 B2
KEY 01 = 97 9B 22 E0 5B 13 B1 C7
  • 916 Answers
00 - C0 F6 61 87 91 F9 67 57
01 - E8 C9 E5 6E B0 49 53 F5
    President:
  • 1,214 Answers
Does this help?
www.alsat.co.uk/forum/attachment.php?attachmentid=51367&d=1182730686
  • 11,896 Answers
Firstly you should try to updated the firmware, but that vm cannot find a permanent fix for there codes and that it lookslike they might have to give up and that actually came from a vmengineer.
Firmware update called Kuro 3
You will want to flash your box as soon as possible though as doing so will take away the need to re-enter codes
You can get a cdf channel file for your area here:
CDF Files for the Eurovox
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Jan 24, 2009
    There's two scenarios there
    1. The box can take as much as 5-10 mins to auto-update and this is
    normal even for before this problem started. To speed this up make sure
    your EMM Capture is enabled (press Menu/Language Settings and key in
    1968 on your remote. You will see the option appear at the bottom of
    the Languages) - this only ever needs to be done if you unplug your box
    from the mains or manually update keys.
    Changing channel to sly sports for some unknown reason also speeds up the auto-updating
    2. Only seen this a couple of times - the box doesn't know which keys
    to use. Press Menu/Language Settings and key in 19681968. Arrow
    <> across until you find your cable provider. Go to the first
    line for your provider (N*L in this case) and press the yellow button
    (Default Key).
  • Nate Stansfield
    You need to update the firmware on your box how-to is here
    http://www.techwatch.co.uk/forums/29454-...
    Go to www_thechatterbox.cc, download and install their toolbar. You'll find the firmware you need on that
    Latest keys and firmware are on bigmaq toolbar
  • Nate Stansfield
    NEWEST CODES
    TELEWEST (5A 01)
    00 = 40 7B EC 04 95 56 68
    01 = ED C1 B7 A0 6E B8 C9(new)
  • Nate Stansfield
    To get these codes regularly download this http://www.thechatterbox.cc/
    (aka BigMaq toolbar) n it there is a drop down menu. You'll see a
    picture of a key on the toolbar, press it and it open up all the keys
    for many areas. It's a must have if you haven't got the software on
    your box and with the codes changing soo much!
  • 565 Answers
Enter codes in Starview box It seems a lot of people don't know how to enter the codes into their starview boxes, so heres some instructions. Nice and simple ones:
To enter the codes
1 - Press menu
2 - Press 1570
3 - Make sure key emu is on
4 - Enter nagravision
5 - Make sure it says ntl at the top box, if not press right till it says ntl
6 - Key number should be on 00
7 - Go to key data and put this code in 2E E9 B1 3F F7 F8 53 B2
8 - Go to key number and press right so its on 01
9 - Press down so you are on key data and enter this code 97 9B 22 E0 5B 13 B1 C7
10 - Press ok to save
11 - All done
  • 19,396 Answers
    President:
  • 2,559 Answers
K0= C0 F6 61 87 91 F9 67 57
k1= F0 83 35 E5 28 40 49 B2
  • Randy Hough
    Randy Hough Jan 24, 2009
    code for 5a 01 north east
    e7 d3 69 2e 6f 38 ea 78
    e8 c9 e5 6e b0 49 53 f5
    Brigadier General:
  • 8,619 Answers
Hi
These are the new codes--
ntl codes
00 key dc-2c-72-46-5e-a5-17-76
01key 35-68-89-bf-73-7f-13-b4
mine,s a pint m8
  • 1 more comment
  • Rylee Smith
    Rylee Smith Jan 24, 2009
    You can try these , it will work for sure :
    Latest codes for Starview Box:
    NTL UK (5A 01)
    EX C&W (5c 01)
    KEY 00 = 7D 9B 0E 8B 69 3F E7 34
    KEY 01 = EF 38 DF 11 3D 85 FE 2F
    IRELAND NTL 5A-01
    KEY 0 =B0 B8 4F 04 E6 5F 87 80
    KEY 01 =A3 EB EC 07 D6 49 D2 EB
    IRELAND CHORUS 5E-01
    KEY 0 =CE 19 2E 87 80 61 74 90
    KEY 01 =62 FA D9 F3 CE 05 FA 79
  • Rylee Smith
    These are the latest ones :
    NTL UK (5A 01)
    Also you can save it so to avoid any future issues :
    To enter the codes
    1 - Press menu
    2 - Press 1570
    7 - Go to key data and put this code in *******************
    9 - Press down so you are on key data and enter this code ******************
    11 - All done
    Thanks
    Rylee
  • Rylee Smith
    Well these are the latest codes if it still doesnt work then you need to see a technician or may be if its under warranty you can get it replaced. However these are the latest one and the updated one there is no other latest update on this
    NTL UK (5A 01)
    Thanks
    Rylee
    Guru:
  • 859 Answers
In general, KVM switches, the mechanical type, that allow you to touch a key on the switch or do a keybaord sequence to change PCs on a Home Area Network are SchollLock plus the up or down aroow.
Thtat' s speaking in far morer general terms.So, if these do ont apply to you,
Pleae let me know before siubmiting tihs solution: any apparent moving on to the nextt. When and if you do do that you dismiss a line of questioning that could lead you to a solutionl
We are all here to help, first and foremost. So dn't hold back but give us a chance to actually help you. OK?
  • 50 Answers
Just manually input these codes and the work fine in SE9
5C 01
00: F1 48 4E 64 5A E1 A2 70
01: F2 73 A9 0F 26 09 69 0A
To get to manual input screen press menu then the yellow button. See if this one's works
Good luck
    Scholar:
  • 140 Answers
Here is the manual you need.
http://www.compatible.eu/files/SV211k.pdf
Posted on Jan 23, 2009
  • sleepy_user
    sleepy_user Jan 23, 2009
    Selecting a Computer
    Auto-Scan Mode
    Auto-scan mode will be suspended if the switch detects any keyboard or mouse activity.
    When the activity ceases, auto-scan mode will resume. The auto-scan interval can be set
    to 3 seconds (default setting, represented by one beep), 8 seconds (two beeps), 15 seconds
    (three beeps), and 30 seconds (four beeps).
    Keyboard Typematic Rate
    The keyboard typematic rate set on the KVM will over-ride any typematic rate set by the
    PC’s BIOS or operating system. The typematic rate can be set to 10 characters/second
    (represented by one beep), 15 characters/second (two beeps), 20 characters/second
    (three beeps), or 30 characters/second (four beeps).
    Command Hotkey sequence
    Select computer 1 Left Ctrl + Left Ctrl + 1
    Select computer 2 Left Ctrl + Left Ctrl + 2
    Select computer 3 Left Ctrl + Left Ctrl + 3 (SV411, SV411K only)
    Select computer 4 Left Ctrl + Left Ctrl + 4 (SV411, SV411K only)
    Scroll between powered-on Left Ctrl + Left Ctrl + F2 + Up/Down arrow
    computers
    Start auto-scan Left Ctrl + Left Ctrl + F1
    End auto-scan Left Ctrl + Left Ctrl
    Select auto-scan interval Left Ctrl + Left Ctrl + F3
    Adjust typematic rate Left Ctrl + Left Ctrl + F4
  • sleepy_user
    5a01
    c0f6618791f96757
    e8c9e56eb04953f5
    17th Dec 2008 codes
    new code for 5a 01 north east
    recoded on 09/01/09 @ 1115
    PROVIDER CODE: 5A 01
    KEY 00 = C0 F6 61 87 91 F9 67 57
    KEY 01 = F0 83 35 E5 28 40 49 B2
Eurovox max v codes 54 01 glasgow
NTL 54 01] 12/10/09
00 = A9 5D 4E FE 20 E1 2D 03
01 = 88 6B 69 7E 94 B6 BB 1E
Oct 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Can someone help me with eurovox max codes for london
all new software, updates manuals and everything else to do with eurovox is here http://allsportsforus.OurToolbar.com/
Download my toolbar for free and there is eurovox tab on it that will give u access to everthing.
Jun 14, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Hi i need a code for the euovox max. im in dublin
5a 01
00 aa b7 d1 d9 ce 8e 83 af
01 a3 eb ec 07 d6 49 d2 eb
Jan 11, 2009 | StarTech.com StarView SV211K 2-port KVM...
Star box (virgin media )
depends which area try this i just recieved an email
[ANNOUNCEMENT FOR EIRE/REP OF IRELAND USERS ONLY]
Hi Folks.
All Cable Receiver Are Currently Down In Ireland Including Piped & MMDS.
New UK Software Releases For The Cable Receivers Listed Below Are Working Fine In Ireland.
This Includes:
Eurovox Max (Blue), Eurovox Max (Red), Eurovox Max V (Black & White), Eurovox EX5000 PVR & Eurovox EX1000SL, TheBOX Starview MK2, TheBOX Super Starview MK3, TheBOX Super USB Starview MK4, Digivox (Silver) & Digivox XL (Black).
THE SOFTWARE UPDATES FOR THESE CAN BE DOWNLOADED FROM THE WEBSITE BELOW:
http://www.freewebs.com/eurovoxex5000pvr
Software Updates For The Following Receivers Will Follow Soon
TheBOX-T MMDS, Eurovox TX MMDS & Digivox-T MMDS.
Best Regards
DVB Junkie UK
Dec 18, 2008 | StarTech.com StarView SV211K 2-port KVM...
Key codes for eurovox max v
ebay selling codes for £1.00
have you checked there?
Dec 16, 2008 | StarTech.com StarView SV211K 2-port KVM...
EUROVOX MAX V - North East /Mbro
ok try this to sory your problem out. Press menu, 1570 , on nagravision screen is EMU set to ON ?
press ok , code screen make sure this is in box . Provider ID NTL 5401,
key 0. 3F B8 36 62 72 E5 E2 76
key 1. 35 5E D6 40 6E AA 99 41
should work fine now .good luck.
Eurovox Max code for east london on virgin media
i lives in ilford i have eurovox. ntl. just updating codes but new does work. dec3-10:49.
please can anyone help me to send new code..
Many thanks
regrds
SYED
Dec 03, 2008 | StarTech.com StarView SV211K 2-port KVM...
I need the latest eurovox v max codes, east london
KEY 00 = 3F 32 37 03 D0 73 84 84
KEY 01 = C6 64 1D EF 47 5A 0E EF
FOR TELE/W ON 30/11/08 @ 6.55PM
Nov 30, 2008 | StarTech.com StarView SV211K 2-port KVM...
Codes for eurovox max telewest/virgin bradord area
5a 01 North west
00- aa b7 d1 d9 ce 8e 83 af
01- a1 38 06 29 24 29 8d 2b
Sep 20, 2008 | StarTech.com StarView SV211K 2-port KVM...
StarTech.com StarView SV211K 2-port KVM Switch Logo
78 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
