Question about JVC LT42P789 42 in. LCD TV
The screen shows ''Weak Signal'' and no picture, even though audio is coming through from both the Cable DVR box and Blue-Ray player. The cable box connects to the TV with an HMI cable - all five TV inputs show ''Weak Signal''.
  • 3 Answers
Mine did the same thing once. I think all I did was hit the setup on the remote, and let it run back through all the channels and then it worked just fine.
I hope this works for you.
Posted on Mar 21, 2009
  • Neville Jason
    Neville Jason Jan 15, 2014
    tried that but to no avail, But thanks. Any more ideas please
My samsung 67 in flat screen has a double picture and I have no idea why. An example would be: it it says weak signal the display shows it like so "weak signal" "...
http://www.google.com.au/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CB8QtwIwAA&url=http%3A%2F%2Fwww.youtube.com%2Fwatch%3Fv%3Dj7vl7-vZEL8&ei=1Dl0VKbHCobEmwWHyYL4DQ&usg=AFQjCNEAyKFYUTGQJSdIJHNNQNODhqatWQ&bvm=bv.80185997,d.dGY
That YouTube link may help as it deals with the double image problem on a Samsung LED TV. It should at least give you a clue about the nature of the problem. You might have to try Samsung's tech support otherwise. I don't think this is a matter of needing some 3rd party signal amplifier because I figure you are using cable TV if you paid a bundle for a set.
Nov 25, 2014 | Televison & Video
Black screen when turn tv on and no audio. Dish network guide will show though.
Hello!!!! This problem is very simple to fix!!!!! Even if you have already gotten this resolved, here are the steps:
1. Unplug the receiver from the power source for 10 seconds then plug back in, and let the receiver download the signal and the program guide.
It's that simple!!!!!!
I hope this helps!!!
Becki Barned
DISH Network Customer Service
Oct 28, 2010 | Sanyo DP32746 32 in. LCD Television
Panasonic TH-42PX75U Blue Screen
This could be a reception problem of the cable transmission or the cable box if used. Are you using cable or SAT box. Tv goes to blue screen if signal is weak automatically.
Dec 03, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
The picture seems very coarse and has diamonds running across it
Hello: In standard defintion the picture is showing in 480p which is the lowest resolution for LCD televisions, The picture will only look as good as the signal its getting, If you have cable then it should look some what better even with std defintion. The Diamonds/triangles are caused from a weak digital signal or weak broadcast station. This is a normal occurance for LCD televisions as the picture is put on the screen in blocks. I would not say your television is bad, just a poor or weak signal, If you are using a digital antenna and not cable, then you might try purchasing a signal amplifier to boost the signal before going into the set.
Nov 05, 2009 | Samsung LN-S4692D 46 in. LCD HDTV
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
Philips 50pf9631d/10 Audio ok but no picture
Bad power supply or backlight inverter.
If the backlight is not turning on, you should be able to see the lcd image by shining a bright flashlight at the screen.
Backlight inverters are loud, so you can hear them operating (high pitched whine) and if the backlight is coming on, you can see white light leaking around the edge of the screen, and even a little inside the cabinet.
Philips are legendary for having power supplies that fail due to bad capacitors, so that could be the culprit as well.
Oct 22, 2009 | Televison & Video
Weak signal showing on my l e d samsung haven't used it yet (new)
Try to double check the power cable is well connected if so you have to know that some screens come from the factory with some problem and in this case you have the right to replace it from the seller.
Dec 16, 2008 | Samsung LN-T4665F 46 in. LCD Television
Plasma TV
If you mean the picture froze or formed fuzzy pixelated picture and crackling, this will be due to a poor aerial signal to the tv, but if you mean the screen rolls with pink/white patchwork type squares and shows the picture in the background, all be it fuzzy, then that's the same fault as I am getting and have had to report the fault to LG as I am on my second TV. If it is the problem mentioned in the first sentence, it is happening to our friends in OS and they have been told by specialist aerial fitters, the signal is too weak for the tv.
Mar 16, 2007 | LG 50PX4DR 50 in. Plasma TV
JVC LT42P789 42 in. LCD TV Logo
688 people viewed this question
Top JVC Televison & Video Experts
easy alberta
easy alberta
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
