Question about Olympus Stylus 720 SW Digital Camera
Olympus and card problem
Howdy, i'm having a problem with my camera and card. I accidently pressed a button to format my photo's and it said ' busy erasing photo's' i opened the cover and took the battery out to prevent this happening and when i turned it back on the only option i have is to either format or turn my camera off. i tried to put the photos onto the computer but it says the device is not ready. i'm worried i have lost all my photos, or will. Please help! thank you.
Hi. Thanks for your question, it helped me solve the same problem on my 720 SW. I don't know what initialised the problem but I had the same result - when I turned the power on I only had the option to format the memory card or turn the camera off. The solution was to take the memory card out and download the pictures using a card reader connected to my laptop. When I re-inserted the card and turned the camera on it worked normally. To make sure that everything was again OK I formatted the memory card to make sure it was properly re-set. Good luck and thanks. Rob
Posted on Nov 03, 2007
Card is full; all pictures have been downloaded to my computer. How do I "delete all" from the camera? Olympus Stylus 300
In playback mode press >ok< select >mode menu< with the 4-arrow-pad, then select >card< then >card setup< then press the PLAY button below the arrow pad. Select >all erase< with the up/down buttons of the 4-arrow-pad and then press OK (the button beside the PLAY button). Confirm by selecting >yes< with the up/down button and press OK button again.
It's also a good habit to get into, to format the card after deleting the images (you can also just format the card - that will also delete all photos). To format the card start as above (Mode menu; card; card setup; press PLAY). Select >format< with up/down buttons then press OK. Select >yes< and press OK.
Hope that helps
Jul 30, 2010 | Olympus Camedia Stylus 300 Digital Camera
I have an olympus fe-340 camera. I accidently deleted all the photos. luckily i have them all on my computer. the camera has a picture card so i downloaded all the photos from the computer to the card. but...
You can't. This is a one-way street...from camera to computer...not the other way around. Now you need to format the card in the camera to get it to work properly.
Jun 15, 2010 | Olympus FE-340 Digital Camera
How do I delete all the photos off of my olympus FE-310 (formating the card in set up didn't work)
Formatting in the camera should have worked. Make sure the slide switch on the side of the card is in the unlocked position. With most cameras, when you bring up a picture and press the delete button, it gives you the option to delete that one picture or all of them. Have you tried that?
Dec 04, 2009 | Olympus FE-310 Digital Camera
Picture error message on olympus 1200
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the Picture error message and the card can be used again. The picture error message indicates that this image is now corrupted and unable to be viewed through the camera.
Apr 23, 2009 | Olympus SP-500 UZ Digital Camera
DELETING PHOTOS ON OLYMPUS C-420L
To format the card:
1 Pressing the Erase mode button and the Flash mode
button at the same time sets the screen to the YES/NO
display.
2 Press the OK button to start formatting (the Card error
indicator blinks). Press the Erase mode button to cancel
the mode.
3 When the card formatting is done, the Card error indicator
goes off.
To re-format the card intentionally:
Press the Erase mode button and the LCD monitor ON/OFF
button simultaneously, with the power OFF, to set to the Yes/No display and then press ok.
Apr 09, 2009 | Olympus Camedia C-820L Digital Camera
After trying to upload photos from my Olympus 1050 sw I now cannot use the camera to take photos. It simply says ´write protect´. When trying to view the pictures it says ´no picture´ when there is at...
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 08, 2009 | Olympus Stylus / mju 1050 SW Digital...
Picture error on Olympus C-765 Ultra Zoom
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Ok button - right arrow to Mode Menu - down arrow to Card tab - right arrow to card setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the picture error message and the cards can be used again.
Jan 04, 2009 | Olympus Camedia C-765 Digital Camera
Write protect
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - Press Ok- right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Dec 28, 2008 | Olympus FE-230 Digital Camera
I have a stylus 410 when turned on it displays 'write protect'
The memory card is corrupted and the only way to remove the write protect is to format the memory card when it is in the camera. To format the memory card:
Press the green arrow button to go to review mode then press the Ok button
Press the right arrow button to go to Mode Menu
Press the down arrow button to go to the Card tab
Press the right arrow button to go to Card Setup
Press the right arrow button to go to Format option
Here you will see Format Yes or No
Press up arrow to go to Yes and press Ok
The camera will indicate Busy because it is clearing the write protect and erasing all images permanently from the card.
Once completed the card will be able to be used again.
Sep 23, 2008 | Olympus Cameras
Card setup error
The first link is to software for recovery of deleted photos, free.
The second is a paid link, but guarantees the recovery or your money back. So try the first one, and if it doesn't work try the second.
http://www.pcperformancetools.com/recover-lost-files-email-data-pictures.htm?gclid=CL38gcTWwpACFRtzhgodBy8BRg
http://www.photo-saver.com/recover/?pu=false&srec=true
Dec 25, 2007 | Olympus Stylus 770 SW Digital Camera
Olympus Stylus 720 SW Digital Camera Logo
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Steve Allison
Steve Allison
Damen Wong
Damen Wong
Are you an Olympus Camera Expert? Answer questions, earn points and help others
