Question about Bosch Nexxt 300 Series WFMC2201UC
Bosch 300 Nexxt won't use detergent on cold cycles
We have a brand new 300 Nexxt series with three detergent trays (detergent on left, removeable softener and bleach sections on right). Cold water always seems to enter through the softener tray, and hot through the detergent chute. This means that the detergent is always left in the chute on any cold cycle. We have watched the full cycle with the cover open and no water ever hits the detergent on cold cycles.
The not-very-helpful person we talked to at Bosch said water should come up from below and wash it down, but we have never seen this. We have seen that large loads (like a comforter) will sometimes not even get fully wet, and the machine seems to use very little water (both hoses are ok and both valves wide open). This is our first front loader after a 37 year old Maytag, so we don't know what to expect.
  • clemens300 Dec 29, 2008
    I checked hoses and they are correct.
  • Bosch Master
  • 3,463 Answers
Make absolutely sure you have the hoses connected to the correct inlet valves,it sounds to me as though they are the wrong way round.
Plz rate my solution.
Thanks.
Posted on Dec 29, 2008
Bosch Nexxt 700 Series Washer, water from cold supply does not dispense into detergent tray
Make sure that the cold supply is on and/or the supply hose is not crimped or clogged. Other than that it can be a control panel issue in the unit itself. But first eliminate the basic things.
Mar 25, 2014 | Bosch Nexxt 700 Series WFMC6401UC Front...
My Bosch Nexxt 300 has E13 code, I'v cleaned the bottom drain, cleaned the outlet hose, ran 1 gallon of cold water threw on the Regular/Cotton cold water cycle, unplugged it for several minutes, t
please download the user manual from the manufactures website its normally free and look at the trouble shooting guide for help on the subject eric
Dec 19, 2017 | Bosch Nexxt 300 Series WFMC2201UC
My Bosch 300 series clothes washing machine is leaking alot. It leaks during the initial wash cycle from the lower left side. I have cleaned the detergent tray and it appears fine. I have also opened up...
Bosch 300 series This video will show you the 5 main areas to look, the washing machine door seal, the pump, check the drum bearings; look for a split hose, water coming out of the soap draw. This video tutorial will help you find the leaking parts and will also show you what needs to be done to repair it
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Mar 26, 2011 | Bosch Nexxt 300 Series WFMC2201UC
Getting E:13 error on Nexxt 300 series washer
Try putting the washer on COLD and run "TWO" cycles. It must be on COLD. There is a chance there is too much soap or fabric softener in the washer. It may also help to clean the fabric softener tray where you add the softener.
Nov 22, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Shows E13 what is it?
Nov 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
How best to remove mold from my Bosch Nexxt 300 washer
any hard water remover hydocloric acid be careful dont breathe the vapors
Jun 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
No hot water
The machine will only take water from the hot tap when it is set to a 95degree wash, it will heat the water on all other cycles itself. apparently an energy saving feature.
May 01, 2009 | Bosch Nexxt 300 Series WFMC2201UC
My brand new Bosch is not draining and is showing E:13 error code
Put the washer on cold and run "TWO" cycles. There is too much soap or fabric softner.
Mar 28, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Bosch Nexxt 100 Series washer
Look into your manual, clean outlet filter & refit. Machine will not spin out if filter is clogged.
Dec 21, 2007 | Washing Machines
Detergent dispenser
As far as I am aware, there IS NO dispenser for bleach, you have to put bleach in drum before adding clothes and starting cycle. The far right compartment is only for "pre-wash" cycles, and if no pre-wash is selected, water will run through ALL compartments at the rinse stage..... Oshie
Feb 28, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Bosch Nexxt 300 Series WFMC2201UC Logo
232 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
