Question about Olevia LT32HVM 32 in. LCD Television
Att uverse remote not working with Phillips lcd?
Our Att Uverse remote has been programmed with the code/s provided for our Phillips LCD. Remote works only when it wants tooo. Seems as if it is trying to control the TV at the same time ???
  • 8 more comments
  • jeffwysocki Jan 06, 2009
    I've had the same problem! Matter of fact uverse has been kind enough to send me out 3 different remotes in a 2 month period. I had a tech out but the problem wasn't happening while he was at the house. By accident by sitting blocking the light from the windows it acted up. The problem is in the sensor of the remote or uverse box, because when ever my problem occurs I shut the blinds and presto! Problem resolved! Uverse doesn't believe me so take it for what it's worth!
  • sickberettag Jan 20, 2009
    I just got u-verse yesterday and i am having the same problem. If i covered up the sensor on the tv the remote seemed to work fine. I showed the technician and he said it was weird, hes never seen it before and will get ahold of me later with a solution. today the thing will hardly work at all now. I think that the phillips tvs and the remotes are running on the same frequency??
  • mike_fixya Jan 24, 2009
    Yup, I have the exact same problem. I have a Phillips LCD. The timing seems random: it works for hours then chooses not to work. The only certainty is turning the TV power off makes the DVR repsond to the remote. ATT claims they have never seen this before and think I'm insane. Nevertheless they have replaced my DVR and my remotes to no avail.
    I have also noticed that my TV power turns off once in a while. I think this is related to the DVR because it never happenned before I got it.
  • skramkcir Jan 25, 2009
    An AT&T tech had told me about back lights on LCD's that emitt IR and interfere with the signal from remote to box. It is true that when the TV is off the uverse boxs responds fine with the remote. The TV responds well to volume adjustments with the same remote. The uverse box is hit or miss. I turned off the dynamic setting and it helped but still not completely normal
  • dss1958 Feb 19, 2009
    I had an old RCA tube TV and had no problems with the remote, but as soon as I installed my new RCA LCD TV the uverse remote works when it wants to. I had the technician come out and look at it and sure enough it worked fine for him. The AT&T tech support had me do everything from a reset to a total reset that wiped out all my programming of the DVR. That worked for about a day and came back. I wonder if anyone else is experiencing this problem with Concast or other cable company's DVRs?
  • Anonymous Apr 15, 2009
    I have the same stupid issue with the remote - intermittent operation, confused signals, and a general 1-second lag between hitting the remote button and the resultant action.
    I have tried turned off power saving and every other energy-related option on my Panasonic plasma TV to no avail.
    I even tried the masking-tape-over-the-IR-sensor trick described on another forum, again to no avail.
    Right now I'm extremely frustrated with the stupid thing.
  • Anonymous May 17, 2009
    I have a new Sharp LCD and I turned power save mode and backlight off. The remote will only change the DVR box if I stand 1 foot in front of it. Any other fix?
  • Anonymous Mar 15, 2014
    program att uverse remote sony str de595 reciever
  • Anonymous Mar 25, 2014
    program my att uverse remote to it
    I have Samsung smart tv and att. uverse internet wireless. what do I need to do to connect netflix
I just did some research on this problem and found a fix. If your tv has a powersaver feature on it turn it off i put mine on standard and my remote works fine now. weird but it works!
Posted on Jan 20, 2009
Just wanted to say I was having this same problem with a Samsung LCD. I saw sickberettag's post about power save mode and was very skeptical, but I tried it anyway. Sure enough, I can point the remote the entire other way and it works everytime. This would have never happened before.
Thanks!
Posted on Mar 07, 2009
I just tried putting mine to Standard mode and am in shock that it seems to be working. I was about ready to switch to another cable company I can't believe ATT didn't test their system out with LCD TV's.
Posted on Oct 17, 2009
I had been having issues with my U-Verse remote ever since getting a new Vizio LCD. I tried tweaking the display settings and using masking tape over the infrared sensor to no avail. I finally got the issue resolved. My receiver sits on a shelf about 18 inches below my TV. All I did was slide the U-Verse receiver back on the shelf until the front of it was behind the TV screen. After 2 months of constant frustration, I haven't had any issues with the remote since.
Posted on Mar 16, 2010
  • Keith Burlock Nov 25, 2010
    I have a Phillips 42 in LCD 42FLP7403D purchased from Costco in 2008. ATT U-verse Remote would freeze on Recorded shows (DVR use) pausing for 10-20 sec to react to inputs.
    Used Method above by moving U-verse box behind the TV up against the wall (about 1 foot behind TV) and the freezing problems have disappeared. It appears to be the fluorescent backlight produces EMI that interferes with the Infrared remote in a vertical line from the TV Forward. (Move the ATT box as far away from TV to prevent EMI from happening to solve problem.
Trying to program Uverse remote for Emerson 32 flat screen
i install uverse, the auto seek is done by hit and hold TV and OK. wait for lights to flash enter 900 and push play over and over SLOWLY and when the tv turns off, press enter.
NOTE: some tvs WILL NOT program to our remotes
Jul 04, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Need a code for att uverse for the remote for vizio lcd
Click Here for the list of Manufacturer's Code for AT&T Uverse
May 13, 2010 | Zenith ZEN700 Remote Control
I need to program my at&t uverse remote with the Emerson 19 inch TV/DVD. I do not have a code.
Dec 25, 2009 | Emerson LD195EM8 19 in. LCD TV
Sylvania ld320ssx remote code for att uverse
Try 1864. It worked for a Media-Com remote, when none of the other codes worked.
Oct 06, 2009 | Sylvania LD320SSX LCD TV
Att uverse remote won't work with other devices
Yes you have to use the recommended Uverse codes, and follow the directions to enter the code. Hold the tv button down, on the Uverse remote, then with it stil held down add the OK button, let go of both, then you will see the lights at the top of Uverse remote light up, it is then ready to accept the code, it will be a four digit code, Go to helpme@att.net, and look under TV, then programming the remote is there. Put remote Code in the att search box if you can't find it.
Apr 04, 2009 | Televison & Video
Not able to program vizio remote towork with att uverse Cisco box
Maybe too late for you but ATT just gave me a code that works with my Vizio plasma. Code is 1343. Even the mute works correctly. They gave me some others to try but I didn't need them. Other codes were 1018, 0030 and 0056.
Mar 19, 2009 | Vizio VO47L 47 in. LCD TV
Programing Remote
1343 or 1005 are the codes - press the TV mode button and the OK button together - the release at the same time - the top row of mode buttons needs to blink twice - then enter the code - the TV button should blink 2 times - try the power and volume buttons - if it worked then be sure to press the ATT mode button again after so you can change the channels
Jan 02, 2009 | LG 32LG30 32 in. LCD HDTV
Programing Remote
Most Polaroid flat-screen TVs won't program to the Uverse remotes. Try buying a different universal remote that shows coding for both Uverse and Polaroid.
Apr 19, 2008 | LG 47LC7DF 47 in. LCD HDTV
Olevia LT32HVM 32 in. LCD Television Logo
2,410 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
