Question about GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL1400 microwave Turn table does not work-
How do we fix a GE Spacemaker XL 1400 microwave Turn table?
I had a large bowl in the microwave and it looked as if is stopped turning. I tired running with nothing in it and the table still does not work.
I can turn it manually and there is some kind of noise and it looks like it wants to turn but does not.
How do I get access to this and fix this?
  • billybudd Mar 23, 2009
    Same difficulty with turntable not turning in a GE Spacemaker XL1400.
  • Thomas F. Schneider May 11, 2010
    Microwave - Turntable Does Not Turn
    To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
    • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
    • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
    • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
    • Be certain you are pressing a cook function rather than a timer function.
    • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
    http://www.geappliances.com/service_and_...
MicrowaveSvc
  • 9098 Answers
SOURCE: Disassembly of GE JVM1460 microwave oven door to clean
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 10, 2008
SOURCE: ge microwave spacemaker XL 1400
I did research and found out that the GE Magetetron (sp) are notorious for going bad. I called and it was still under warranty - 10 years, but i needed to pay for labor. That ran me $180. The part was $125 but would have taken my time to install, plus I didn't want to deal discharging the capacitor.
Posted on Apr 14, 2008
najah
  • 180 Answers
SOURCE: GE Spacemaker XL1400 microwave doesn't heat anythting
Magnetron may be defective. Replace the magnetron by a new one.
Posted on May 01, 2009
localwonder
  • 6784 Answers
SOURCE: MICROWAVE IS NOT HEATING
HI, the actual device that produces the heat is damaged or faulty. this device is called the Magnetron. you will need to replace this part in order to restore the heating ability of this microwave oven.
Please rate and have a great day:)
Posted on May 29, 2009
SOURCE: Spacemaker XL1400 GE Microwave
my xl1400 spacemaker ,it just won't heat, everything else works
ok, can you all advise me what to do, what could be causing it to not heat.
wendell
Posted on Feb 18, 2010
Turn table does not work. How do you fix it? I have a GE Spacemaker XL 1800, Model # JVM1842BD. Thank You
i have a ge 1800 model and it cooks fine but after awhile it shuts down and in about a hour it comes back on and ask you to set the clock.....
Jun 03, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
How do you change the belt if there is one for the
There is no belt on unit. There is a turn table motor and a turn table tripod or coupler. Either the motor is out or the coupler is broken. You can check coupler easy by removing glas tray and see if coupler turns around. If its appears ok, then t/t is probably out. This can be replaced by removed screws from bottom of unit and the complete bottom folds toward wall. Its in the middle with 2 wires connected too it.
Dec 01, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
I have a ge spacemaker XL1400. It was manufacture
it sounds to me like the magnetron is shot in it. this is the part that creates the heat. not worth repairing on a 10 year old unit. Sorry.
Nov 08, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
Jun 23, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Upgrading from an old GE XL1400 Spacemaker Microwave
GE Customer Service should be able to tell you if they have a new "drop-in" replacement for your model.
On that page you can also find your model's installation instructions, which make removing the old oven pretty simple.
Jan 29, 2009 | Microwave Ovens
Spacemakerxl1400 suddely stopped heating,all other functions are working.is it due to some small problem
GE Spacemaker model XL1400 not heating. Everything else works on it, but no heat. What could be the problem? Can it be fixed reasonably?
Jan 27, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Glass turntable won't turn - spacemaker - XL 1400
Most likely a bad turntable motor - check with www.martinmicrowave.com for a replacement .
Dec 23, 2008 | GE JVM1440 Microwave Oven
wendell
Dec 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker making odd noise
We are having the same problem with our XL1400. I suspect it has something to do with the turn table but don't know for sure. We would be willing to disconnect the turn table...anything to stop the noise but don't know how.
Mar 05, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 - turntable issues
check capacitor and motor drive of turn table.
Jan 03, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
1,035 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
