A Miele Washing machine that will not drain
I have a miele Novotronic W838 Front loader Washing machine. It has been sitting unused for 18 months. Recently, I started it up and went through a quick wash cycle with the machine unloaded to check all functions.
The machine performed fine until it came time to drain the water. The pump ran, but no water came out of the discharge hose.
I emptied the drum of water, stripped the filter and it was clean, removed the pump unit, and checked it was running under power. Removed ALL the drain hoses, the main drum hose, hose from the pump to drain box, flushed the drain box and also flushed the drain hose..
Same problem still exists. There is not water getting to the pump housing, but I can hear the impellor turning, in fact it makes a loud rattling noise, I presume because the pump housing is empty?.
Is there a solenoid valve that i don't know about that opens and fills the pump housing aprt from the water from the drum. There is a large plastic ball inside the Drum to pump hose. What lifts that up to allow the water to drain from the drum? There is a small 1/2'' hose that leads into the botoom of the drum housing, does this lift the ball up to allow the water to drain.? Any suggestions?
Regards
Simon
  • 54 Answers
SOURCE: Miele Novotronic.
all miele are supplied with schematics. on washers take the top off and its on top of dispenser tray. if not there remove front panel it will be there
Posted on Feb 14, 2008
SOURCE: miele W830
I have exactly the same problem - what was the answer ?
Posted on Apr 05, 2008
SOURCE: Water inlet flashing ,not filling,
Hi Paul,
We currently have a similar problem with our W939. I took the front panel off and found that the Miele service folks had incorrectly routed the ribbon cable linking the fill level sensor with the control panel and severed one of the wires. The machine was reporting a series of errors, one of which was an outlet blockage and the discharge pump was not working.
The relevance to you is that your problem may be a loose or broken wire or corroded terminal.
SA.
Posted on May 04, 2008
eagle338
  • 4889 Answers
SOURCE: Miele leak when switched on for wash, from filter unit front LHS bottom of machince
The leaks in a washing machine could be coming from many different places in the washer.
The first place you need to check is behind the washer, check the two fill hoses and the water mixing valve.
The next thing to do is to remove the front panel, set the washer on the regular cycle and turn it on to start filling.
Use a drop light and check all the hoses under the washer as the washer is filling. Make sure to keep your hands away from any moving parts.
If the hoses are ok, check the pump for leaks. When the bearings in the pump wear out, that is when the pump will get noisy and that could cause your Maytag top load washing machine water leaks.
Another place that the washer could leak water from, is the stem & seal on the holding tank. When washer leaks water from the stem & seal, the water leaks down the center of the transmission.
When the stem & seal need to be replace, the tub bearing has to be replace at the same time. This is an expensive repair if you have to pay someone to do it. If you do it yourself it will cost you about $110
Posted on Aug 21, 2008
  • 6 Answers
SOURCE: Washing machine WK61420GB drum does not turn
replace the brushes in the motor ( approx £5 parts)
Posted on Feb 21, 2009
What to do about a washing machine, that does not heat anymore?
It could be the contacts of a switch (or the electronic part) is defect, or the heating. Mechanics are not cheap, so to invite one for the repair could cost between 200 an 600 euro or dollar. depending what the parts will cost. if the machine is about 10 years of age I would think twice before I invite someone for a repair, because even with a new heater, the rest of the machine is not that young. I would replace the whole machine. Miele should work for 20 years, but Google and see in how many fora they are talking about defects.
Success
Jul 25, 2014 | Miele Washing Machines
W3831 not draining
check the drain hose is not clogged, also check the pipework that the drain hose goes into. if there is a block the machine is programmed to stop pumping.
Dec 12, 2013 | Miele Novotronic W1918A Front Load Washer
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Hi, I have a W526 Novotronic Miele
rinse light flashing is an indication the is a problem within the motor circuit. Brushes,motor or electronic.
Dec 24, 2010 | Miele Novotronic Premier 500 Front Load...
Miele front loader rubber door sela has small tear
No.
At the beginning of every cycle water enters appliance via top of door seal this is connected to the inlet water supply
Jul 05, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic W 833 won't drain
hi,
if your washing machine drains into a spigot in the u bend under your sink you will probably find a blockage here. you need to remove the drain hose and have a look in the hole.
if not when you remove the fluff filter have a look in the hole and make sure the drain pump turns freely. you can also run a drain spin cycle with the fluff filter removed and make sure the drain pump is working.
Jun 14, 2010 | Miele Novotronic Premier 500 Front Load...
How do I use the washing machine, a miele novotronic w 969
The I is the pre-wash and the III is the main wash where you put the soap powder. the # star looking symbol is the fabric conditioner.
If you don't have a manual you can download this from the miele website.
Jan 10, 2010 | Miele Novotronic W1918A Front Load Washer
Miele Premier Novo Washing Machine
Open drain door at bottom front left of machine. Pull yellow tab that is there. This is the manual door opener.
Jul 15, 2008 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
246 people viewed this question
Top Washing Machines Experts
