Question about Whirlpool LER5636P Electric Dryer
Dryer does not heat all the time.
My dryer Whirpool model LER5636LQ0 does not heat all the time. Some times it heats up for 1 load and the other load it does.
  • 1 more comment
  • lori_matlock Dec 30, 2008
    Yes I've check the vent, fuse and inside the dryer to make sure the holes weren't plugged up. I can put a load of clothes in and they will dry. I can put a load of clothes in to dry and they come out wet, I can run the dryer again and the clothes are damp, and again and the clothes are dry.
  • Mike Pham May 11, 2010
    have you try different heat cycles or heat selector switch? time your dryer with your clock vs the timer on your dryer...
  •  Sherman
    Sherman May 11, 2010
    did you check your dryer vent
    Problem Solver:
  • 19 Answers
Replace both the hight limit thermostat and low limit thermostat they come in a kit and also clean dryer vent
Posted on Feb 01, 2009
I have a whirlpool dryer Model # LEB6000PQ0 It seems to be heating sometimes, but not all the time. Could that be a heating element, or something else? We have to dry a load several times...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jan 24, 2011 | Whirlpool Dryers
I have a whirpool dryer Model LER 4634 PQ0. The dryer turns but does not heat. What could the problem be?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 07, 2010 | Whirlpool LER4634J Electric Dryer
Electric Whirpool Dryer doesn't stay hot
Check the vent for obstructions if all is clear do an ohm reading on your heating element. For video instructions go to www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | Whirlpool Dryers
Whirpool Dryer Heating and timer issue
YOU NEED CHEK:
1-thermal fuse.
2-heater element.
3-hi-limit switch.
4-temp sw.
5- electronic control.
Oct 05, 2009 | Dryers
Dryer has no heat. runs 1 minute and the screen
is this a whirpool wth a humidty mister if so the control needs to be replaced (main)the he means there is a fault in the heater circuit check heater ,fuses ..if had a brand and model number could pin point for you better
Aug 10, 2009 | Dryers
No heat
The following link will explain the most common causes of a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
To answer your question, "yes", this is a problem that is worth your effort repairing. This should not be a difficult repair and can be accomplished by the average do-it-yourselfer with just a little guidance. Read through the link I provided you, thoroughly. Pay particular attention to the paragraph that discusses proper ventilation as most dryer heat related problems are attributed to poor (or clogged) ventilation. In general, most commonly, if the heating circuits fail, its for a reason. This is usually caused by overheating due to poor air flow. If you cannot remember the last time your dryer heat ducting was inspected or cleaned, it may be a good time to do so now. If you do not ensure the dryer has proper air flow, replacing parts could become futile as these same components will more than likely fail again. If you have questions, or require addtional assistance please let me know. I hope this helps you.
PS Check your thermal cut-out (TCO) first. This component acts as a fuse and is usually the first to go bad when a dryer fails. If the TCO fails, it is strongly recommended that you replace the hi-limit thermostat at the same time. These components are commonly sold as a set. Failure to do so may result in premature failure of any replaced parts. NOTE: Do all components checks with the dryer UNPLUGGED. Dangerous voltages are still present even with the dryer turned off.
Jan 12, 2009 | Dryers
Whirpool twin thin no heat
Make sure you have 220 volts first at dryer. Heating element is on back of dryer. You'll need a test meter to see what's wrong unless you can see broken wire in element itself. Thanks, please leave feedback or contact me again for more info if you need it.
Nov 29, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LER5636P Electric Dryer Logo
140 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
