Question about Polaroid FLM-3732 Television
Screen shows no signal
When I turn on tv it shows no signal
  • onipko55 Jan 11, 2009
  • 718 Answers
HDTV sets are different from the old analog sets.
If your set is showing No Signal or Weak Signal you will have to do the following.
1) Connect an Antenna or Cable to the input on the back.
2) Go into the Channel signal source menu and select either the Air/Antenna or Cable option.
3) Go into the Auto Program Scan menu and SCAN in the channels.
Now you can watch available channels.
Posted on Mar 03, 2009
How do I get Amazon Fire TV resolution set so I get more than a blue screen?
Select the input channel for your Fire TV - Turn on your TV and select the input channel for the HDMI port you used to connect your Fire TV. You should then see a loading screen with the Amazon Fire TV logo 4.
Jul 04, 2017 | TV Box Televison & Video
Why does the screen turn blue and indicate "no signal"?
Hi Jocelyn,
The TV will show no signal when either there is a break in the input signal or the TV is not receiving or processing it properly. Please check the input cables and connections and the signal box. If that is ok please call the local TV tech.
May 29, 2015 | RCA Televison & Video
Hi Recently i turned on my TV and the picture was crystal clear as always, but then i turned it off for 20mins turned it back on and now the whole screen is messed. it shows a double of everything and...
Tries tv unplug,replug it back like about an hour later.By letting the tv resetting itself back to the factory setting,see if this solved ur problems.Still have the same result.Tv have Tuner signal board have problems.The tv Tuner signal board is causes and the problems,it dead.That the board where the inconming broadcasting signal cable plug into.Tries webssites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Jan 14, 2011 | Televison & Video
The tv had blue screen briefly showing "no signal" then turns off. ... and I am getting the same blue screen-no signal.
If your television is displaying a blue screen or no signal message and then turning off, your TV may be at an inactive input. Here's how you can get back to watching your TV:
1. Powering on your TV and press the INPUT button on the VIZIO remote control repeatedly until a picture re-appears.
2. If this does not work, try again but press the button slower this time.
I got this off the vizio website.
Feb 21, 2010 | Vizio GV42L 42 in. LCD Television
Cannot connect acer extensa 5220 laptop to hd tv via aga
Hold down Fn and tap F5, you may have to tap F5 a couple of times to get it to switch screens.
Regards.
Feb 19, 2010 | Acer Computers & Internet
Blue screen - no signal - turns off [visio tv L42hdtv10a]
With out turning on the T.V., Push the [Input] button on the remote control. The TV should turn on and activate the input menu, just continue to push [Input] until it is set on TV (or HDMI, etc.). this should solve your problem.
Oct 29, 2008 | Vizio GV42L 42 in. LCD Television
NO SIGNAL DISPLAY
try to resolder all the loose electronic parts of you TV..maybe the cause was the loose parts.
Mar 28, 2008 | Sony KP-61HS30 TV
Tv monitor turns blue during forward or reverse vcr search
On some TV's the screen will go blue if there is not a strong, solid video signal present. This is to prevent the showing of very snowy or all snow channels, or garbled, mixed-up external video signals. This is normal. On some VCR's the video signal changes when the FF or REW search feature is used, and this could trigger the TV to go to blue screen. The only way around this if you can enter the TV's menu and turn off the blue screen feature.
Jun 23, 2007 | Panasonic PV-V4020 VHS VCR
Televison & Video Logo
454 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
