Question about ASUS P5ND2-SLI (890552603831) Motherboard
Computer won't power off
I recently add a 2nd hard drive and everything works fine but when i shut my computer down it won't power off. It logs out of everything and appear to shut off but the power supply is still running. What I'm thinking is that it don't know how to shut down the 2nd hd but I'm not sure. Please help!
  • 1 more comment
  • ragnar590 Dec 30, 2008
    Sorry, running XP.
  • debmeag May 22, 2009
    I can't find APM. It is not in my power options tab. Did I loose it? Maybe I over cleared some registries?
    My computer will go into Standbyand will hibernate if I select these manually. It just won't time out.
    I'm running XP.
  • Beeuwen Gerryts
    Beeuwen Gerryts May 11, 2010
    Are you running Vista? Also make sure that you choose "shut down" and not "hibernate" by accident?
    Scholar:
  • 55 Answers
The most common reason for this problem is that ACPI (the Advanced Configuration and Power
Interface) isn't enabled. To enable it:
Click Start | Control Panel, select Performance and Maintenance.
Click the Power Options tab.
Select APM - Enable Advanced Power Management Support.
Click OK.
Posted on Jan 28, 2009
Ihave a aopen computer. The other night when shutting down -- before the windows statement that it was ok to turn off the power. The lights on the power and reset lights flickered. I latter tried to power...
One bad lead can cause a computer to continue on a cycle to shutdown or fail to detect a hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO THE HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
May 19, 2011 | Acer AOpen AX 6BC (91.87810.451)...
Pc does not power on with hard drive plugged in
When you plug in the 2nd hard drive as a single drive does the drive spin up and the computer goes through the Power on self test (POST)?
If you cannot hear the drive spin up and the computer doesn't boot up then most likely the hard drive is faulty.
Feb 26, 2009 | HP Pavillion ZV6000 Athlon 64 3500+ 15.4in...
Not shutting down
sounds like that when you did a restore one of the files did not load correctly try using your repair disk and that should fix it
Feb 10, 2009 | Medion M3 Composer 5200 PC Desktop
Standy By Going off/Computer shutting down
The presentation power scheme is used when you are giving a briefing using the PC as your slide show. So the presentation power scheme will never shut off the monitor or the hard drive, don't want it to shut down in the middle of a briefing.However, leaving it in that state for long periods of time may cause the CPU to overheat and shut itself down for protection. A better scheme for quick boot up would be Home/Office. Turn monitor off after 20 minutes and "never" for hard disk. This way it will save energy (therefore heat) and you will have a quick boot up. If you are using XP Pro, there is also an option to automatically put it in standby when you close the lid of your monitor. Hope this helps. If you have any questions let me know... Please rate this solution before logging off.
Feb 04, 2009 | HP Computers & Internet
Screen dies when booting up
TRY PLUGGING IN EXTERNAL MONITOR, THIS IS IF YOU HAVE A LABTOP AND I THINK NOT.
HOW ABOUT REMOVING THE OLD DRIVE AND PUTING IT ON THE NEW COMPUTER AS 2ND DRIVER OR SLAVE DRIVE, SOME COMPUTER CABLES OFFER SELLECT CABLE THE C DRIVE WOULD BE 0 AND 2ND DRIVE WOULD BE 1, IF YOU DONT HAVE SELECT CABLE THAN EACH DRIVE HAS TO BE SET UP YOU WILL HAVE TO GO TO THE MFG WEB SITE LOOK UP JUMPER SETTINGS, THE FIRST DRIVE WILL BE THE MASTER AND THE SECOND ONE WILL BE THE SLAVE, NOW IF YOUR CD ROM IS ON WITH THE HD THAN YOU WILL HAVE TO HAVE 2ND CABLE FOR THE CDROM TOPUT ON THE 2ND SET OF PINS MARKED 2ND HD OPTION AND YOU HARD DRIVERS MASTER AND SLAVE GO ON
BANK 0 IF IT SAYS 0, IF IT SAY1 THAN PUT IT ON 1.
REBOOT AND THE COMPUTER WILL START AND PUT YOU INTO THE CMOS AND YOU WILL ADD THE HARD DRIVE BY GOING TO 2ND HD PUTTING CYCL, HDS, SECT, YES LBA
2ND CABLE YOU SELECT CD OR DVD
F10 AND YES
REBOOT
EVERYTHING SHOULD WORK FINE.
IF YOU DONT FILL CONFERTIBLE DOING THIS TYPE OF INSTALLATION THAN HAVE YOUR COMPUTER PROGRAMER FRIEND DO IT FOR YOU OR COMPUTER TECHN WILL WORK TOO.
ROD
Jan 20, 2009 | Nvidia Riva TNT2 16 MB Graphic Card
Computer won't shut down
i read an forum, mboar asus shutten dwon NOT avaible.
Dec 29, 2008 | ASUS P5ND2-SLI (890552603831) Motherboard
WD My Book 500g HD error. Turns off when USB is plugged in
Check the USB port on your computer. It's very likely that the problem is there. On my computer USB ports stop working sometimes and the HD does exactly that. HOwever, when i restart the computer, everything works fine.
Mar 30, 2008 | Western Digital My Book Premium ES...
Installed new larger hard drive now crashing after an hour use
When you say "shuts down" do you get a BSOD (Blue Screen of Death) or does it just shut down without an error message? It definitely sounds like overheating. Try using a laptop cooler, something like this: http://www.overclockersclub.com/reviews/antec_notebook_cooler.php (I'm not saying you should buy that model necessarily, there are many such coolers). They can make a huge difference.
Apr 21, 2007 | Compaq Armada E500 Notebook
ASUS P5ND2-SLI (890552603831) Motherboard Logo
162 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
