Question about Kenmore 44103 Side by Side Refrigerator
Need help on how to replace water dispenser flapper
The water dispensor flapper broke and I have a new one on the way. any ide how to go about it's replacement?
  • liqdxstnce Feb 19, 2009
    Have the same problem on a Kenmore side-by-side. Removed the drip tray but I don't see any screws. Perhaps the fascia pops off, but I definitely don't want to break it trying. Anyone tried this before?
Nevermind.. I couldn't wait. If you slide the fascia (part that surrounds the "refreshment center" and has the buttons on it) up, it has enough flexibilty that the top catches can come out. Once the top is free, you can pull the top of the fascia away from the door and slide it down to release it from the bottom. With the fascia removed, you should see the circuit board and more of the ice and water mechanisms. That whole assembly came off for me with three screws, one electrical plug, and the water hose. From there, it's easy to see what needs to be done. The actuators have a couple screws holding them on. Should be fun putting it back together :)
Posted on Feb 19, 2009
Whirlpool model # ed5vhexvq1 side by side ...ice maker will not dispense ice..water works but it sounds as if there is no power going to icemaker from dispenser
Does the icemaker bucket has ice cubes. If yes then your problem is in the dispensor. If no ice cubes on the icemaker bucket then your problem is with the ice maker unit.
Let say Ice cubes on the ice maker bucket and dispensor makes noise when pressing for ice cubes. Then either your ice dispensor flapper is frozen or may be ice cubes in bucket may have defrost and frozen again sticking together.
Oct 01, 2014 | Whirlpool Refrigerators
I have a Kitched Aid SxS fridge,model KSBS25TNBL02. I changed the water filter, cleaned everythng, etc. It makes water and ice jst fine, but when I press the Ice dispenser, no ice comes out. I can look...
HI MIKE.may be its just jammed with ice.empty all and try empty first.might be making ice and solidifying due to water leak.(high pressure or valve) or motor gone.good luck Ali
Aug 21, 2012 | KitchenAid Refrigerators
Hello. My side by side refrigerator model MSD2434GE, serial no 11874215CG , I can not get water from the water dispensor, I ice dispensor works fine, I have tried pressing the lock three times but still...
There is valve at the back of the ice maker unit.This valve is the one unit with twin inlet.From one inlet the water enters the ice maker and from other inlet the water enters the water dispenser.so in that valve the ice maker side is working but water dispenser side is not working.Or the ice is got clogged/ over frosted in the water dispenser entering pipe.either the valve needs top be replaced or the water dispenser pipe needs to be checked.Calling service person is advisable.He will just check and confirm what is the issue, the water valve or the over frost build up in the water dispenser tube.and do as required to solve the issue/.If case if the water valve needs to be replaced then cost of water valve is approx $40.------------- this will help.Thanks.Helpmech.
May 29, 2011 | Maytag Refrigerators
Can anyone tell me the trick on taking off the plastic cover plate over the ice/water dispenser area? I have tried to look for the tabs to push out and then remove, but it is not working. One of the tabs...
Insert a butter knife between the dispensor grate and the dispensor cover about 1 " from the side and push inward , to unsnap the plastic clip on each side (at the bottom) . Then lift upward , to unhook the top portion of the dispensor cover . There should be a single plug to disconnect to completely remove cover . FIRST , remove the top freezer hinge cap and disconnect the plug there , as this will disconnect the electricity going to the dispensor and avoid any electrifying experience .
Aug 28, 2009 | KitchenAid Refrigerators
Maytag plus msd2758ge water-dispensing problem
check your micro switch behind the water dispensor lever. You'll need to take the face off the ice/water dispensor to find the switch. Or could be the water valve is stuck in the open position. You'll need to replace the water valve. Hope this helps!
Jul 28, 2009 | Maytag MSD2732GR Side by Side Refrigerator
Ice dispensor
Make sure that the "flapper-door" closes about 3 seconds after the ice dispenser button is released. Mine had a habit of catching and staying OPEN. This allows warm air to enter the dispenser / freezer compartment causing your problem.
If it is stuck you have to take the dispenser apart to loosen / lubricate the flapper door cam to allow for free movement.
This is the worst ICE system I've ever seen for a variety of reasons.
Jun 06, 2009 | LG LSC26905TT Side by Side Refrigerator
NEED MANUAL FOR GLHS68EEPWO BROKE THE ARM FOR THE WATER DISPENSER
ill assume that the dispensor paddlle is what broke and it is white?? if this is the case hewres the part number, 5304433612.. no real manual available for changing procedure. but the front dispensor panel unscrrews and lifts off allowin youacees tot he armature.
Mar 09, 2009 | Electrolux Refrigerators
No power to the water dispensor or other buttons on the door
it has to be one of many things the Control Board or Double Outlet Water Valve,Dispenser Door Solenoid
Here to help
Shaun
Nov 16, 2008 | GE GSS25JEMWW Side by Side
Water dispensor not working
Since you have water getting to the icemaker/dispenser, the most common problem I've seen is the solenoid valve is history and needs replacing. It could also be the switch that is normally activated by the dispenser itself and in turn activates the solenoid valve or the wiring in-between the switch and valve, but I have personally not seen either one of those go bad.
Jan 02, 2008 | KitchenAid KSRB22FNSS Stainless Steel
Kenmore 44103 Side by Side Refrigerator Logo
70 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
