Question about Mitsubishi WD-52725 52". Rear Projection HDTV
Mitsubishi wd52725 green blinking light
I saw a posting by you earlier this year regarding your Mitsubishi television. We are having the same blinking green light problem with our Mitsubishi wd 52725. What solution did you find for this problem? At this point we are weighing fixing the tv or trashing it!
Haven't done anything as of yet. I saw many posts that stated it costs between 800 & 1500 to fix the problem with no guarantees on the repair or how long the repair would last. Still weighing my options.
Posted on Dec 29, 2008
Mitsubishi error code 56. I just replaced lamp that went out. Set now blinks both green and yellow light. When you hold down device and menu it definitely does 5 blinks and then 6 blinks for error code...
If the galant is gdi domestic spec is a valid code. Unfortunately is not listed in the mitsubishi manual. You will and MUT II or MUT III with japanese programe to see it. Usual problem with gdi is the high pressure fuel pump driven from the intake camshaft. It can be repaired.
Oct 02, 2010 | Televison & Video
I have a mitsubishi tv model # wd52725, the timer light is blinking nonstop green? do you know what the problem is? i cant seem to find anything in the manual thank you irene Irene_padilla@msn.com
Thats caused by failed capacitors on the DM board. You can get the V26 DM repair kit at www.tvrepairworld.com which should fix that issue. The kit contains the capcitors and the CD with detailed repair instructions.
Jan 03, 2010 | Mitsubishi WD-52725 52". Rear Projection...
Practical soln. for the blinking green light?
Call Encompass Parts or visit their website online 1-800-638-3328 and FOX has Lamps for $109.00 1-800-227-5369 Heres you another Tip Go to E-Bay they have alot of Good deals there Look under Electronics
Dec 08, 2009 | Mitsubishi WD-52725 52". Rear Projection...
What repair is needed for blinking green light and
These sets had a lot of problems like yours---for a while lots of them had 3 different boards with caps going bad etc---a real nightmare---fix one board and a few months later another goes out.
I was at a local Mitsubishi authorized repair center recently---Because of all the problems there is now available an ENTIRE CHASSIS exchange for most of these sets---it wholesales for about 200---a third of what it will cost you to have a shop fix all three of the suspect boards.
This is from what I was told a response by Mitsubishi from the THOUSANDS OF ANGRY PEOPLE WHO PAID A LOT OF MONEY--and 3 or 4 years later the sets are dropping like flies.
If this information has helped you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Blinking timer light will not turn off.
You most likely have a fault in the defelection circuitry that is causing this. A repair is needed, none-the-less....accordianman
Jan 01, 2009 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi WS55909 blinking green light
how long was it blinking. after a complete loss of power the green light will blink on power up as it is resetting itself. It says in the manual that it should take about a minute. Over the last two days I've have to reset it several time both by unplugging it and using the manual reset button and it has taken about five minutes for the blinking green light to clear.
Dec 09, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Status light stays on
I have a 52inch mitsubishi dlp model ws-52725,I turn on the tv and the green light is plinking I have this befor and had to replace the module at a coat of 600.00 that was 2 years ago .I have done all the necessary steps,light still plinking.what do I have to do now ?My last mitsubishi I had for 15 years with no problem.Its mitsubishi going down hill. Thank you PS there any help any where ?
l#wd52725
Nov 22, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Mitsubishi Model WD-52725 timer green light blinking fast
My Mitsubishi WD52725 will not turn on...the timer light is blinking. We pushed the reset button, unplugged tv. Just got off the phone with Mitsubishi customer "service." After answering numerous personal questions, and being on hold for several minutes, I was told that the only solution was to push the reset button. Duh! We'd done that several times with no change, which is why I called them! BIG WASTE OF TIME!!!!
Nov 08, 2008 | Mitsubishi WD-52725 52". Rear Projection...
Green blinking light problem too. on a Mitsubishi WS65869
You can go to this link they have the kits with the high temp higher volt capacitors and complete detailed instructions on how to do the repair.
http://servicemanuals.vstore.ca/
Jun 03, 2008 | Mitsubishi WS-55909 55" Rear Projection...
Mitsubishi WD-52725 52". Rear Projection HDTV Logo
257 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
