Question about Dell FAN / SHROUD ASSY 92X30MM 2X333 Fan Kit
My 2x333 fan is not working properly
I just cleaned it since it was very dusty, but it's still not turning properly.
I suspect that there are some dust chunks close to the rotor and it needs to be cleaned from the inside, if that's the case - is there a way to open it without damaging it?
Thanks!
Dylan.
    Problem Solver:
  • 5 Answers
Well sometimes there are fixable if going to try use a small flat head screw driver and find the plastic clamps and gently pry if you break one don't cry because you probably have to buy a new anyway but its the learning experience you get by having the balls to try. well if you get it open check for dust chunks they do **** up a lot of dust be prepared for serious dust bunnies read the label is it bearingless or ball bearing give the blower blade a good spin does it seem a little wobbley or does it seem to want to stop as soon as you spin it then get a 9v battery and check if it will spin at all if it does put back together and thank GOD you didn't have to shell out that much money for little piece of plastic and a motor and if you do have to buy one pray to GOD you find a cheap one those super blows can get ridious on prices. well have a nice day (compaqsiget over and out have a nice day)
Posted on Jan 06, 2009
Runco cl-610 projector
Likely the fan blades are dirty and out of balance. If this projector is in a dusty or smoky place you will need to clean them (or have them cleaned by a tech) often. If you are not good with electronics, I suggest taking it to a dealer. If you can get the covers off properly, you will need use a can of compressed air to carefully blow out the projector and fan blades.
Jan 05, 2013 | Runco Lamp for CL-610 Projector
Cpu not heating, ite chip getting very hot ,no display
If the fan on top of CPU is dirty, dusty, damaged or not connected properly,it could cause CPU to overheat. The Computer should switch off automatically to prevent damage to CPU (they can burn out very quickly if not cooled properly!!!)
1. Is the fan connected properly to motherboard?
Check cable running from fan
2. Is fan dirty or dusty?
Use a small brush or can of compressed air to remove dust off fan. Never use a normal household vacumn cleaner-this can create a static electric discharge which could damage components.
3. Is fan damaged ie does it spin when powered on?
Replace fan with similar make and model
Hope this helps. Thanks for using Fixya
Jul 13, 2011 | Computers & Internet
My 20" Patton electric fan has stopped working. I use it for animal cooling and it operates in dusty conditions. I suspect that the motor is shot. Is it worthwhile to replace the motor and are motors...
You could just try to clean the motor out by taking it apart, and shining the shaft up. then put some motor oil/engine oil on the shaft. That will work 99% of the time.
Aug 12, 2010 | Vacuums
I've had my acer aspire (5315) laptop for over 2 years
Sometimes, the CPU heat sink fan might get clogged up or faulty or stop spinning entirely. Make sure that the fan can turn properly.
IF YOU CAN, open the unit when the battery is disconnected and the power is not connected, then reseat the CPU Heat sink and re-apply a eye drop heat sink thermal paste onto the CPU. Reconnect and tighten everything again properly and adhere to the sequence in turning the screws back as per their numbering on the heat-sink
If the FAN has trouble spinning, doesn't turn at all or is noisy and runs irregular please replace the fan. The fan alone should cost about a few US $.
May 16, 2010 | Acer Aspire 5315 Notebook
My Acer laptop seem t0 shut down for no apperent reason and it always has to be pluged in
it sounds like your battery may be dead or close to dead if your laptop has to be plugged in all the time. if there is a battery check meter on the battery, you can check the battery condition with that.
unless it is a problem with your charging circuit, the battery would need to be replaced. recommend going to a local shop and have them test your battery first and your power adapter for proper output as well before buying a new one.
for your random shutdowns, it may be overheating. if the top or the bottom of your laptop is very warm i would suspect overheating. if you look in the back where the cooling fan exhaust port is, and see a lot of dust or other matter, then it would be most like heat issues.
if you turn it upside down and look for the cooling fan intake, and it is very dusty or a lot of matter inside, much the same thing.
>> if it is very dusty, it will need to be cleaned. a can of compressed air is a quick solution, but blowing the dust back inside usually just leads to an accumulation somewhere else. a professional cleaning would be the best solution for a dirty computer. i dont advise using an air compressor to blow through the cooling vents. for one thing if you spin your fan with a compressor blast, that fan is not only spinning but also acting like a mini generator, generating voltage and current, putting this back into your motherboard. air blasts can also severely stress or even dislodge micro sized components on your motherboard.
if it is clean, one common mistake with laptops is having them directly located on your lap. this can block the cooling fan intake and will cause shutdown every time. if your laptop is on a desk or table, it also needs several inches of space in the back for proper heat exhaust.
if your laptop passes the clean checks, i would next check your DC power jack (where your adapter plugs into)
With your laptop turned off.
try VERY gently moving the plug side to side and see if there is any free play at all. If it feels snug, then boot your laptop and try this again after it has booted. if it shuts down then your dc power jack is damaged and will have to be replaced.
if the dc power jack check passes, i would then reboot your laptop and
first, with the screen open, and the laptop on a flat surface, i would try gently lifting each of the four corners, one at a time. when doing this you only need lift the laptop about an inch.  this is to check for any possibly loose or intermittent motion related problems.
if this doesnt cause any shutdowns, then let it run for several hours unused and see if it shuts down. if you have hibernation or standby enabled, these would need to be temporarily disabled for this test to work properly
if it doesnt shut down
From this point i would start to suspect either intermittent defects with charging circuit or other underlying motherboard issues. cant say for certain without actually looking at it.
hope this helps
Feb 15, 2010 | Acer Aspire 3680 Laptop
Optima getting fan fail error what can I do?
its eather it is dusty or the fan morter is burn out.
Jan 04, 2009 | Optoma EP739 Multimedia Projector
Hunter Thermostat fan won't turn off
Hi and welcome to FixYa,
Initially, I am inclined to suspect 3 possibilities:
  • sticking relay contacts (if used) (a possibility, least likely);
  • dusty thermal sensor/switch for the fan (likely);
  • time delay. design feature, will power down the fan only after a certain period that the heater has turned off. This is to dissipate residual heat not only on the heater but on the immediate surroundings of the heater element (most likely).
Good luck and Thank you for using FixYa.
Jan 01, 2009 | Hunter Fan Company 5/1/1 Programmable...
Dell 2x333 fan is working, but having difficulties. I suspect it needs to be cleaned from dust on the inside, is ther a way to open it? I couldn't figured it out.
to open the computer there will be 2 screws on the back on the side edge at the top and bottom, remove these and slide the side panel of the computer backwards and it should come off and you will see the fan in front of you, use a can CO contact cleaner (safe to use on all electrical parts) or canned air, if your computer is a different setup (as the make and model was not provided) send me the make and model and i'll get back to you with a more detailed answear
Dec 29, 2008 | Dell FAN / SHROUD ASSY 92X30MM 2X333 Fan...
Computers & Internet Logo
Alun Cox
