Question about Sakar Digital Concepts 88379 Kidzcam Digital Camera Kit
Camera will not do any thing
I put batteries in the camera and pushed the mode button. nothing happens unless i hold the mode button then the screen says 20
  • ham_bill Jan 03, 2009
    I have the kidz cam 88379, but have no idea what the modes are on the camera? The camera had no instructions. Does anyone have a manual or no what each mode means??
You have to hold the mode button for two seconds for the camera to activate. Then it will tell you how many photos can be taken. In your case, you can take 20. Your camera is now ready to take pictures and as soon as you take one, it should go down to 19..18.. etc. Then you connect the camera to your P.C and the pictures should be on there.
Posted on Apr 02, 2009
Stuck in video mode
I had the same. I plug it into the computer and unplugged it several times, took out the micro SD card. Finally it said "no SD" after a while. Pulled out battery and put back in then plugged into computer again, and back to normal it seems. Sorry this is not a step by step but I was just trying random things till it worked. Did not re-test to see if it is OK for the next recording session.
Feb 21, 2012 | GoPro HD Hero 960 Video Camera
How does this thing work?
Install the software on your computer. Put a battery in the camera. Push and hold the button to turn it on (display shows 00) Take some pictures - the camera makes a tiny beep, the led on the front flashes, and the count goes up by one. Push and hold delete to remove the last picture (count goes down) hold longer to delete them all (goes to 00). When you've collected some pictures, rush to your computer to download them with the USB cable before the battery runs out; when that happens the pictures are all gone (there's no flash memory in this). Holds about 40 pictures depending on the amount of detail in them.
Feb 03, 2011 | Disney Pix Click Digital Camera
Flip video mino troubleshooting freeze
There is a reset button! Get a pin and push into the tiny hole at the bottom - inside the tripod screw hole. Push in and hold. The camera will reset. I called the Flip support - they were great !
Apr 05, 2009 | Pure Digital Flip Video Ultra Camcorder
Kidz Cam only works when connected to P.C
Try these steps..
>> Disconnect the camera from the computer
>> Remove batteries
>> Now press and hold the power button/mode button for 2-5 seconds .. then release
>> Now insert the batteries and see if it works now.
Please let me know if this works.
Regards,
Srinivas
Apr 02, 2009 | Sakar Kidz Cam Digital Camera
Set time/date on Argus APS 400
I continued to push other buttons on the camera while the date or time was flashing untill I found that the mode button made it change.
May 21, 2008 | Photography
Camera powers off automatically once turned on - lens stuck in out position
Hi trldg.
My S4, which admittedly is 4-5 years old and looks it, has given me intermittent problems for 2 years or so with the lens sticking out. I have always been able to fix it by power cycling.
However, recently it seemed there was nothing I could do andI was getting ready to junk it and buy another one. Then I searched online and I was able to fix it. I knew nothing about MENU+ON or MENU+FLASH+ON sequences (are there others you know about)?
Anyways, I got the hint from a post which suggested this sometimes happens when the battery is swapped while the power is on. I was fiddling with a bunch of things when I think what fixed it was this sequence:
1. remove battery
2. hold down MENU (or possibly MENU+FLASH; I was trying both)
3. insert battery
Now, my fault was such that the power always seemed to be on when the battery way in. If this isn't the case with yours, then you may need to hold down POWER ON as well in step 2 (which might mean 3-4 hands required).
Things went back to normal after that.
Hope this helps you.
Rob.
Mar 10, 2008 | Pentax Optio S Digital Camera
Camera wont turn off
Remove the battery. The same thing happened to mine and once I put the battery back it worked fine.
Dec 31, 2007 | Vivitar Vivicam 5105s Digital Camera
Turns on, yet not on?
Have you read the manual ?
Aug 15, 2017 | RCA CDS4100 Digital Camera
Dark LCD
Is it possible that you've gone into M (manual) mode and the shutter speed is fast and a small aperture (large number) been selected? Or has the Exposure compensation been adjusted to be -2? Does it do the same thing in fully automatic mode? It certainly sounds like some setting has been adjusted incorrectly.
Aug 31, 2005 | Canon PowerShot A70 Digital Camera
Sakar Digital Concepts 88379 Kidzcam Digital Camera Kit Logo
106 people viewed this question
Top Sakar Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Sakar Toy Expert? Answer questions, earn points and help others
