Question about Bose Wave Radio
My unit does not work. Is there a fuse that might need replacing.
While operating the unit, I accidently increased the volume to a
loud sound. There was weird noise and the unit went dead. Can
the unit be brought back to life.
  • vernonhagen Dec 29, 2008
    Model # AWRC1P: Hope this will help in solving
    my problem. VKH
  • vernonhagen Dec 30, 2008
    I no longer have a problem. My wife discovered a loss of electrical supply.
    Thanks for an interest in my problem.
    VKH
  • 151 Answers
Burnt. Is it still under warranty?
Posted on Dec 29, 2008
  • 4,234 Answers
The short answer is yes. The longer answer will require a bit more info. Most likely either the output transistors have failed or the speaker may have beel blown. It depends upon how loud you made the radio go. If this is the small wave radio, I just took in one for repair and may be able to provide you with more details in a day or so. Stay tuned...
Dan
    Novelist:
  • 163 Answers
Please give me the model number?
  • ronny2051 Dec 30, 2008
    k..
    the problem is seems like that there is some condenser gone bad because of voltage supply to radio. There are two possible causes—
    1) the main adapter is not working properly.
    2) The power condenser (handle the power voltage supply) gone.
    So, your radio needs a service.
    Thanks
Audio receiver sudden death
I would suggest not turning it up so loud the next time and post the model and manufacturer information so we can better help.
There may be fuses that blew, replace them but do so with the same type of fuse, going to a different fuse will probably destroy your unit the next time you turn the volume up.
Mar 19, 2014 | Audio Players & Recorders
How do I increase the sound volume of myToshiba Satellite L755 laptop
By the clock at bottom right there is a speaker icon that can increase volume. right click on it and click sounds, click playback tab at top, Right click on speakers and select properties, should be an enhancment tab for bass boost and loudness.
Feb 12, 2012 | Computers & Internet
Yesterday i have bought a brand new CD 740 A and 650 C. Both the things where fixed with Bose AM5. It sounds really good. when the volume is increased more than half, the loudness too increases. is there...
Please note that you volume control increases in a logarithmic scale, in simple words it increases in a doubling scale eg: 2,4,8,16,32,64------------. So if your half volume is 16watts per channel the next increase is 32 and the next 64 so on. So don't be surprised if after half volume it suddenly starts getting very loud. There is nothing you can do about it.
Jul 28, 2011 | Cambridge 740A Amplifier
Can you please tell me how to increase the volume on my husbands phone as it not very loud thank you
most of the times there are side keys in mobile placed on either side of the mobile by pressing them up and down we can increase the volume. but if a pair of keys is not present on one you are talking about then certainly in setting-----sound settings you can increase the volume of the mobile. but keep in mind some time if a mobile previously working fine suddenly started to transmit low sound there may be a problem in mic as well. try the above mentioned steps and if the problem remains focus on the mic. it may be replaced by some mobile repairer.
Also it may be possible that the output sound of your mobile is low as you listen from your own mobile its volume if increased could also give you good results. thankx
Feb 10, 2011 | Cell Phones
The volume-up control is not working.
Here is a copy of your owners manual
http://www.sonystyle.com/wcsstore/SonyStyleStorefrontAssetStore/pdf/warranty/SEL-asset-166073.pdf
These units are very popular for having install errors, volume problems, recording issues etc. You need to install its driver to get it recognized by system,did you get a cd or mini cd with it?If the unit was accidently dropped, the volume will be affected without you even knowing it. I've seen these broken in parts and put back together with lots of solder work. I recommend getting a fresh set of batteries, checking the data transfer cord, power cable for any errors, and understand the at times, the volume will increase but no decrease and vise versa. This has a lot to do with wear and tear on the buttons and again, accidently dropping the unit.
Jan 12, 2011 | Sony Walkman NWZ-E344 Digital Media Player
Model C-60 Yamaha organ. Loud hissing sound
This is likely in the power amp or the drivers for it.
The key to troubleshooting is a schematic. Try to procure one.
You MIGHT try using circuit cooler in the area of the power amps to isolate a bad component or cracked circuit board.
Mar 10, 2010 | Yamaha Music
Problem with sound - Philips HTS3455 Home Theatre System
Hi, I am sorry to say that there is probably a fault. First check the fuses if able (a possibilty). If not that then will need to go in for repair.
Hope that helps
Jul 24, 2009 | Audio Players & Recorders
I have an Alpine CDA-9815 head unit installed in a 2002 Dodge Dakota. I currently have a 12" DVC sub bridged at 4 Ohms. My head unit's volume goes up to 35. When i turn in past 24-25, the head unit...
It sounds like the sub woofer amplifier is pulling down the voltage level in the truck when it starts to get really loud. It may be the voltage regulator which is probably part of the alternator, or the alternator is not capable of supplying the needed current for the amplifier. If the voltage level drops below a certain level, the radio will see it as if the battery is disconnected. It requires a voltage level of around at least 10 volts to stay turned on. When an amplifier is playing loud, it draws a lot of current. If the current supply does not increase, it lowers the voltage level to compensate and get the current it needs to play at the level the head unit is pushing it to. As the voltage level goes down, the current increases when the voltage is dropping due to increased demand. You could check this with a voltage meter and monitor the level right at the battery and have somebody turn the volume up on the head unit slowly as you monitor the voltage level. The normal operating voltage of a car while the engine is running is about 14.4 volts. It should not drop much at all, no matter how loud the amplifier is playing. if it does drop, you have a problem with the trucks regulator or alternator.
I hope this helps, if you need more assistance let me know.
Dave
Jul 08, 2008 | Alpine Car Audio & Video
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Ringtone volume is reduced...
turn increasing ring off, try this
menu>settings>sound>increase ring>off
hope it helps!!
Dec 13, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Bose Wave Radio Logo
27 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
