Question about Palm Tungsten E2 Handheld
SD Card Jams Into Device, Doesn't Come Back Out
When i put an sd card into the slot, it clicks then its in, when i push it again, it doesnt click and doesnt come out. any solutions? (i took it apart but couldnt quite do anything because i couldnt fugure out how the power conector unplugs)
    Problem Solver:
  • 14 Answers
There is system that locks the card in the card slot,it might have jammed or broken.
Thanks
Posted on Jan 31, 2008
SOURCE:
SD card won't click into the slot and it won't work without it.
Somehow, I doubt this is for a "Bottom Freezer Refrigerator".. Anyway, these SD cards usually push in all the way and back out a fraction of an inch and stay put. It should only go into the slot one way. Have you tried with a different SD card to see if the problem goes away? If not - there' probably an issue with the device - or this unique "Bottom Freezer Refrigerator" of yours ;-) Good luck!
Aug 21, 2015 | GE PDS22SIS Bottom Freezer Refrigerator
When i put my sd memory card back in my digital camera it said file error
This can be due to a corrupt configuration file in the SD card. I recommend:
1) Insert the card in the SD slot in a computer that has the slot
2) Go to "My Computer" (or "Computer" in Windows 7)
3) Right click the "SD card" icon
4)Click "Format..."
5) Press "Start"
Then you should be able to use the SD card properly with your camera.
Apr 05, 2011 | Cameras
It says reading card when i put the sd card in but never does anything else
It sounds as if the card may be corrupt, so you could try formatting it on PC:-
Put the SD card into the slot on PC, or into an attached card reader. Go to the 'My Computer' screen, and right click on the SD card's icon to bring up the format options. Click on 'format' and follow the instructions. Before taking the card out, click on 'safely remove..'
If the camera can then read the SD card, format the card again in the camera and it should be read ok. Hope this works!
Dec 26, 2010 | Cameras
MY MEMORY CARD WILL NOT LOCK INTO PLACE WHEN I PUSH IT INTO SD SLOT
  • Most likely the SD card is not being pushed in far enough to lock into place. You really need to use your fingernail to push it in past flush until you hear a clicking sound, at which point the card will lock into place.
  • Here are full instructions for insertion and removal of the SD card: Insert the memory card with the metal contacts going into the slot first and facing up at you. In other words the SD card label should be upside down when you insert it this way. You need to push the card in past flush to have the spring mechanism lock the card into place. To get the card out of the slot, push the card in past flush and then the spring mechanism will release it. You will hear a click when the card locks into place or is released from the slot.
  • Dec 05, 2010 | Bushnell Trail Scout 11-9500c Digital...
    I have alot of photos in my pc and wanted to put this 2gb card and get them on there
    put the microSD into a micro SD adapter and plug the adapter into the SD slot on your PC the folder will open and you can drag photos from your photo folder into the SD folder
    Oct 01, 2009 | PNY 2GB microSD Memory Card
    I like to up grade my sd card on my magelian 360 roadmate E-mail as follow:bojo9335@verizon.net
    To change the sd-card do the following:
    Peel back the rubber gasket to expose the SD card slot. Do not
    completely remove the rubber gasket.
    Push the SD card until you hear a click. Do not attempt to pull
    Remove the SD card from the slot.
    To Insert new SD Card
    Insert the SD card into the slot (Do not force
    the card into the slot.)
    first and the beveled edge to the left.
    Close the rubber gasket.
    Mar 22, 2009 | Magellan GPS
    How can i use sd/mmc memory card reader on my laptop? ia am using dell inspiron 1525 model?
    The SD/MMC memory slot is already configured to read standard and HDSD cards. Just remove the DELL blank from the slot by pushing it in until it clicks and release it. Then pull it out. Insert the SD/MMC card into the slot and push it in until it clicks. The DELL Blank is shorter than an actual SD/MMC card, so don't try to push the SD/MMC card any further than the 'click'. Remove by pushing in until it clicks, release, remove.
    Jan 10, 2009 | Dell Inspiron 1525 Notebook
    Installing the memory card in my Treo 650 cell phone
    there's a card slot on top of the device - see pic attached (which shows both - SIM card and memory card slot opened). To open it press down and release dummy card, thenn pull it out and put SD card into slot (pushing it slightly deeper)5deba98.jpg
    You can back up your Treo to either your PC or your SD
    card. If you back up to your PC via hotsync, then there is a nice freeware which
    can be installed to your Treo that is called SyncAll (all one has to do is right
    before the sync, open the program and click "force all to sync"), and it will move
    all the files, including preferences and such that don't normally get sync'd. If
    you backup to your SD card, there are numerous programs for accomplishing this. It
    is important that the number of backup-to-SD programs are limited for the Treo 650
    due the NVFS file system. You can try THIS ONE for example - it's free.
    Apr 26, 2008 | Palm Treo 650 Handheld
    Micro SD card wont work
    type 277634# * # (no spaces)
    click port setting
    click mass storage
    click mass storage remove
    go back to main screen and check again for memory
    if this doesnt work,take out memory card and try without the memory card.
    Nov 01, 2007 | LG CU500 Cellular Phone
    Palm Tungsten E2 Handheld Logo
    53 people viewed this question
    Top Palm Computers & Internet Experts
    Marvin
    Marvin
    JC Meredith
    JC Meredith
    Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
