Toshiba Satellite A205-SS5000's dvd drive
If i stay on my Toshiba Satellite A205-SS5000 for any amount of time its dvd drive won't eject. It just flashes a yellow/amber light at me. If i restart it will work again, but it's extremly fustrating to have to turn my comp off all the time, and impossible to download things that have multiple disks.
    Problem Solver:
  • 9 Answers
A virus can cause that problem but it could be as simple as the drive going bad. I would formatt & do a clean OS install. That would rule out a virus problem.
Posted on Dec 31, 2008
DVD drive won't open on my Toshiba Satellite U305 S7467
Insert a striaghtned paper clip in the tiny manual eject hole.
Dec 29, 2012 | Amstron Toshiba Satellite U305-S7467...
Toshiba satellite CD door will not open
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/laptop-disassembly-1.htm
1) ALL power removed. Remove the AC adapter (Charger), and Battery.
2) Turn the laptop over bottom side up, Battery Compartment facing AWAY from you, down on a table.
You may wish to lay a soft Static free cloth on the table, to prevent scratching the table, or laptop.
3) Take this cover off,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-02.jpg
Remove the Ram Memory module/s. ('Stick')
Lay them/it carefully aside. Handle by the BODY. The Body is everywhere on the Ram Memory module, EXCEPT the gold plated contact pins at the bottom.
The Body is coated with a see-through protective plastic.
4) Remove this Philips head screw, and push the optical drive out,
http://www.irisvista.com/tech/laptops/toshiba-satellite-a205/big/toshiba-satellite-a200-a205-03.jpg
The top of the optical drive will have small Philips head screws, or Torx screws. They sell Torx screwdrivers real cheap,
http://en.wikipedia.org/wiki/Torx
Remove the screws, remove the cover, remove the disk.
Regards,
joecoolvette
[Sounds like you may need a replacement optical drive ]
Oct 31, 2012 | Toshiba Satellite Computers & Internet
How to replace dvd drive in toshiba laptop a205
shut down the system and remove the battery.
Look under the PC, on the dvd drive area, you will see a screw, use a screw driver to unscrew it and push the drive out from there.
Take care.
Jan 13, 2010 | Toshiba Satellite A205-S4617 Notebook
My Toshiba Satellite A205-S5803 will no longer read or write cds
Try getting your recovery DVD's out --- put Disk 1 into the drive; choose "Install Applications and drivers" --- click Next and follow the directions.
Oct 08, 2009 | Toshiba Satellite A60 Notebook
Toshiba satellite A205 DVD player partially Inop
The disk drive could be going bad, or the lens may be dirty.
Try getting a dvd lens cleaning kit if you don't already have one, and run that. Make sure to read all the instructions that come with the cleaning kit.
ex - http://www.walmart.com/catalog/product.do?product_id=9123830
May 31, 2009 | Toshiba Satellite A205-S4707 Notebook
Servvices manual to help me change my dvd-rom for toshiba satellite A205.
In order to change your DVD drive you need not take your system apart, there should be one screw on the bottom near your drive to remove which will allow you to slide the drive out.
Should you feel more comfortable with a picture guide, here's a link
You can do it, don't get discouraged.
Apr 17, 2009 | Toshiba Satellite A135-S2386 Notebook
On my Toshiba Satellite a205-s4707 dvd player not working
Allright this one can be tricky so we need to isolate the problem between software and hardware.
First, get into the bios and see it's being detected.
If not then turn off the computer and unscrew the drive from the laptop, MAJORITY of laptops only need to have one screw unscrewed to release the drive. If yours doesn't then you'll have to do a little more work, let's just assume you have the majority for now.
Next, pull the drive out, feel free to give the back connector a quick puff of air, now carefully place the drive back into the laptop so that it's nice and tight.
Check to see if that solves your problem.
If not we'll try something else.
Feb 22, 2009 | Toshiba Satellite A205-S4707 Notebook
Dvd Driver Problem.
DVD drive lens may be dirty or the DVD drive itself defective.
Dec 13, 2007 | Toshiba Satellite A205-S4617 Notebook
DVD drive malfunction
http://support.microsoft.com/kb/929461
I had a similar problem with my P205D-S7454. The registry fix worked for me.
Oct 23, 2007 | Toshiba Satellite A205-S4607 Notebook PC
Computers & Internet Logo
523 people viewed this question
David Payne
David Payne
