Question about Hitachi 46UX50B 46" Rear Projection Television
No Volume on the Television
There is no sound on the televsion. The volume control looks like it is going higher but no sound comes out. We had the cable repair guy come out and he used an alternate television and he got sound. Is there a special nute button somewhere that we accidentaly hit? Thanks
    Genius:
  • 2,920 Answers
Make sure the tv is on internal speakers and not external speakers.
Posted on Dec 29, 2008
Dim screen (Desktop)
Control Panel\Hardware and Sound\Power Options
at the bottom there is settings for screen brightness.
To get to control panel on 8, (not 8.1) go to desktop, then Winkey+c and click settings then control panel.
Dec 29, 2013 | Compaq Computers & Internet
Why doesnt the volume come on whe i turn my televsion on?
first thing is,check its not muted or output is selected for added surround sound,second may need to open back of tv see all wires are connected to the speakers and board.first explore all your menu options for muted sound or output
Mar 19, 2013 | Curtis CMMT32 32 in. LCD TV
Have windows XP. Somehow audo is out.Did I accidently switch isit off?
Yes, you might have turned off the sound in your PC.
For Windows Xp this is the procedure to turn it ON.
Go to 'Start'--->Settings---->Control Panel----->Sounds and Audio Devices
Here you will get a window where you will find all the sound related options.Here you will beable to modify the volume levels and check whether the mute checkbox is ticked, if yes then uncheck the box and click on OK.
your problem should be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Apr 13, 2011 | Computers & Internet
I just bought a 32 in samsung tv.. the audio worked fine until I had the cable guy come and install the cable box on it.. Now I turn it all the way to 100 and still can't hear it very well.. any...
Try adjusting the volume on the cable box. The cable box should have a on-screen volume control, try setting it up some. You may have to navigate around to find where you control the cable box volume but it should be there.
Mar 08, 2011 | Televison & Video
Hi Folks - I have a Roland Fantom G6 that produces no sound! Everything else seems to be fine - the display registers that I am hitting the keys & even the skip-back sampling feature produces a wav...
This probably is not a DIY repair... The audio comes out of the CODEC and is buffered by Op Amp used as filters and then goes through the volume controls, After that it goes to the jack board with buffer OP amps. First thoughts might be a damaged volume control, however, the "B" outputs don't go through volume controls...
About the only thing I would think you could do is to CAREFULLY open the unit and look for a loose cable involved with sending the audio to the volume control panel and then the cable that takes the audio to the jack board...
More than that you would probably need to take it to a shop equiped to troubleshoot.
Nov 23, 2010 | Roland FANTOMG8
I am unable to go to menu on my televsion.
Some universal remotes do not correctly handle the features of the original remote. You can get an exact duplicate remote from remotes.com: http://www.remotes.com/remotes/servlet/rs?a=Search&o=c&uid=0&m=6509DD&uuid=12709186471510
Alternatively, get one of the higher end programmable remotes. The ones programmed from your computer are more likely to be trainable to do all the features of your original remot.
I hope this helps.
Apr 10, 2010 | Sylvania 6509DD 9 in. TV/DVD Combo
I can't get the tv volume to work when using my onkyo tx-sr806. What might be the problam?
I assume you are looking to have sound from the television through the speakers that are connected to your receiver?
If that is the case then make sure you have connected the audio out from the television to the audio input for what might be labled monitor or TV/SAT. Then turn the volume on the televsion all the way up and switch the input on the receiver to TV/SAT.
Jun 17, 2009 | Onkyo TX-SR604 Receiver
Onkyo ts595 goes into protect mode with volume increase
HI check your speaker cables are not touching, also make sure "b" speakers are not on and that all your speakers are 4ohm or higher as this will cause the amp to shut down if they are to low an impedeance,The amp is protecting itself when it shuts down.
hope this helps.
CABLE GUY.
Aug 03, 2008 | Onkyo TX-DS575 Receiver
AUDIO
Hey Tex
You are on the right track, sounds like a noisy volume control. Can often be repaired with a squirt of cleaner spray into the potentiometer assembly.But I suggest you use crc2-26 contact lubricant spray, not silicone spray which is a great materials lubricant, but not electrical. Worst case, the Vol Potentiometer, may have to be replaced. Go for the CRC first and see how it goes. Good Luck, happy FixYa
regards
Graeme
Mar 05, 2008 | Audio Players & Recorders
Bose Wave System CD 2000 FM volume much lower cd stops if volume higher.
sounds like a loose cable from the control bard to , some one will have to open up to fix, i recommend bose do that for you,
as for fm volume, the same could be the cause as the fm antenna coudl be disconnected, ( are you using an external FM antenna ?)
Feb 29, 2008 | Bose Wave Radio
Televison & Video Logo
82 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
