Question about Pioneer VSX-D411 Receiver
Pioneer Receiver will not come on
Receiver is getting power but is stuck on "standby" mode, any suggestions
  • jasnodo Dec 23, 2007
    same shit different model pissing me off my timer light just flashes
  • Anonymous Mar 27, 2014
    Stuck in standby
    Problem Solver:
  • 14 Answers
Press and hold the enter button on the amp then hold the power button down whilst holding the enter button still do this for about 10 seconds then it should reset its self
Posted on Apr 02, 2008
2 Suggested Answers
SOURCE:
SOURCE: standby light on pioneer vsx-d308 receiver
I have the same problem. my sandby light is on but my receiver will not turn on! I checked my power going into the power supply board that was good. But i do not have power going to the transformer or the receptacle. And both of my fuses r good. check ur fuses and go from there . If u know how to get a power supply. please let me know.
Posted on Oct 14, 2008
My Yamaha Rx a710 is stuck in stand by mode can't get any thing to work how do I do a hard re set on this receiver
  1. Set the unit to Standby Mode using the Power button. ...
  2. While holding down Straight button, hit the Power button. ...
  3. Use the Program Selector buttons to navigate to INIT-CANCEL and press the Straight button to select INIT-ALL.
  4. Turn off the unit using the Power button
Oct 20, 2016 | Yamaha Audio Players & Recorders
I have a AVD-C700es and there is power going to the receiver but it won't turn on. Any suggestions? It seems to be stuck in standby mode!!!!!
Could be blown, most receivers now a days have overload protection that protects them, try disconnecting or checking your speaker wiring and turning it on again. Also try leaving it unplugged for a few minutes and trying again after. If all else fails, it is probably a internal fuse blown to protect the receiver, a repair shop will probably charge 100 to repair it.
Sep 07, 2014 | Audio Players & Recorders
Stuck in standby mode on Fisher RS-911A receiver
Does it power up or straight to standby? If it is on but in standby it could be speaker protection issues...check speaker wires and/or speakers for issues. If it's straight to standby and no power, it's repair shop time.
Jan 02, 2014 | Fisher Audio Players & Recorders
Tv stuck in standby mode
When a TV is stuck in standby mode often means that there is a problem with its power supply or even in the horizontal output circuitry. May be a component with short-circuit in the RGB output driven by the flyback transformer or a rectifier diode in the power supply output.
I hope having helped you.
Sully
Sep 27, 2013 | Sony Televison & Video
Receiver stays on standby mode
Receiver either just stuck or held or having problem in amplifier output area.
Try to unplug it from AC outlet for couple of minutes and replug back in and power up, if works, fine and if does not, take it to local repair shop as it might requires some parts replacement in amplifier out area.
Feb 10, 2009 | Insignia Audio Players & Recorders
Standby light on pioneer vsx-d308 receiver
Jun 14, 2008 | Pioneer VSX-D308 Receiver
Denon dra 1025ra seems to be stuck in standby mode. How do I release standby to power up
Unplug receiver from AC outlet, and plug back in. The power reset should clear up the problem.
May 18, 2008 | Denon Audio Players & Recorders
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
Onkyo TX-8522 stuck on standby
This is Not a real Fix, However it stops the problem!
Do not plug any power cords into the Receiver.  I have found that using the "switched or unswitched" plugs in the back cause the trouble.
Nov 15, 2007 | Onkyo TX-8522 Receiver
Yamaha RX-V595A tuns off automatically
This was happening to mine also, all of a sudden. This solution came from the owners manual. Sure enough, the impedance selector was stuck in the middle , between 4 and 8 ohms....I also, made sure the speaker wires were not touching each other at the splice. Problem fixed.
B
The unit fails to turn on when
STANDBY/ON is pressed, or set in
the standby mode suddenly soon
after the power has been turned on.
The power cord is not plugged in or the
plug is not completely inserted.
The IMPEDANCE SELECTOR switch
on the rear panel is not fully set to the
upper or lower end.
Firmly plug in the power cord.
Set the switch fully to the upper or
lower end when the unit is in the
standby mode.
Oct 27, 2007 | Yamaha RX-V595A Receiver
Pioneer VSX-D411 Receiver Logo
820 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Morne Olivier
Steve Sweetleaf
Steve Sweetleaf
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
