It is the APP sensors , Your vehicle has electronic throttle control . P2122 Throttle Pedal Position Sensor Switch Circuit Low Your best bet would be to take it to a qualified repair shop .
SOURCE: 06 chevy impala v6 3.9 liter engine. Check engine
there is a large evaporative leak. keep away form ottozoo, they dont have the brain power to actually diagnose a light bulb., their job is to sell parts., if they sell you the wrong parts tough.Take it to a qualified repair shop that does a lot of GM work or the dealer.
SOURCE: The "engine power is reduced" light comes on
po455 is Probable Cause[s]
1. Defective, loose or missing fuel cap
2. EVAP canister broke, hose cracked or not connected
3. Purge or vent solenoid defective
4 . Vacuum leak at engine po121 code po121 means Throttle Position Sensor/Switch A Circuit Range/Performance Problem . it is usually indicative of a faulty throttle position sensor or faulty wiring harness in the engine bay.
SOURCE: I have a 2010 Chevy impala. Reduced engine power
I have Caprice 2007 LS V6 , At the engine start I
receive a message Traction control off and check engine , I don't know why .
Please you can help me
My Email :- [email protected]
Thanks...
please scan the ECM for codes and post them
