Question about Compaq Presario 700 470024-192 Notebook
Operating system wont restart
Just upgraded the ram on my Compaq f700 from 1 gig to 2.. powered up my laptop and nothing happens ....black screen....what happened?..how can I fix the problem?
  • rtj440 Dec 29, 2008
    been there done that...the RAM is pc2 5300 sodimm so I know it is the correct one...double checked the seating of the chips...still no luck...did hear the computer beeping at me while doing the switch...
  • rtj440 Dec 31, 2008
    bingo!! you were right the first time....finally decided to reset the ram chips again nice and slow and carefully....all is well and I'm back in business...thanks much....
    President:
  • 1,179 Answers
Make sure the RAM you purchased is compatible with your computer. Putting the wrong RAM in is one thing that could cause this problem. You could also try reseating the RAM as if it is not seated properly then the computer does not see it. Hope this helps & please remember to rate my answer. Thanks.
Posted on Dec 29, 2008
  • Roy Lonsinger
    Roy Lonsinger Dec 31, 2008
    Beeping usually signifies either a RAM or Video card problem. If you have already checked the RAM then I would say the graphics card has come loose or went bad. Hope this helps.
Get black screen after upgrade Acer 3680
might be that the ram you got was the wrong ram for that laptop.not all ram work in all laptops.
May 23, 2014 | Acer Aspire 3680 Laptop
I have a compaq 6820,s and it won't power up, i get nothing, no screen, sound power, nothing at all. I change the power cord and nothing happen. So could anyone out there help me please?
Try reseating the RAM modules, If this does not work then the RAM maybe faulty. Remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. If the RAM is faulty them it needs to be replaced.
Feb 24, 2012 | Compaq Presario Computers & Internet
When I power on my laptop there's a beep code, on my m30x-s181st
That is your memory error code.
Re-seat your ram, or restore the ram you replaced it with if this is an upgrade. If neither of those apply, you should test your ram slots by leaving your ram door opened and apply constant pressure with your fingers lightly pushing the ram stick while booting.
If you get a boot screen, then you have the infamous goal post flex.
Those little upright locking wings on each side of your ram will flex over time and allow the memory stick to float up, unseating your ram.
Those little plastic brackets holding your locks on just get tired and begin stretching and relaxing over time
When this happens, your ram LOOKS like it is seated, but it's actually floating away from the contacts. I have fixed many Dell Laptops with this problem by placing hard packing foam under the ram door to keep the memory sticks seated. Yes it's cheap, but it's also permanent.
Apr 08, 2010 | Toshiba Satellite M30X-S181ST Laptop
256 MB DIMM#1(DDR333) UPGRADE TO 2GB RAM in compaq nx6110 pc notebook
You should be able to upgrade to 2 gig. Here are specs. Good Luck.
512.0 MB / 2.0 GB (max)
  • Technology DDR SDRAM - 333.0 MHz
  • Memory specification compliance PC2700
  • RAM configuration features 2 x 256 MB
  • Nov 20, 2009 | HP Compaq nx6110 Notebook
    Screen black, although it is ON. Nothing happens
    HI This is kamal
    it very simple just change ur ram
    definitely ur compaq pc laptop would run
    and let me know it would be working or not
    regards
    kamal singh
    Oct 08, 2009 | Compaq Computers & Internet
    Upgrading ram
    You can only run 2gig max IE: 2- 1gig or 1-2gig you cant run 2-2gig the bios will not accept it
    Mar 13, 2009 | Toshiba Satellite P205-S6337 Notebook
    Error message after installing memory ram upgrade.....
    The memory appears to be the right kind.
    Try installing just one 1GB module, and run the diagnostics (press F12 at boot time and select diagnostics).
    Dec 20, 2008 | Dell Inspiron E1505 Notebook
    Screen turns black suddenly
    Hi guys!
    I think your problem is one of the following:
    1- AC Device or Batteries.
    2- RAM.
    3- Graphic Card.
    So, plz check them by order.
    I hope this problem is solved.
    Nov 04, 2008 | HP Compaq Presario V2000 Notebook
    Upgrade ram
    Each memory slot can hold DDR PC2700 with a maximum of 512MB per slot. 2 slots=1 gig or 1024MB ram.
    May 22, 2008 | Compaq Presario M2000 Notebook
    Compaq Presario 700 470024-192 Notebook Logo
    48 people viewed this question
    Top Compaq Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Alun Cox
    Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
