Question about Canon PIXMA MP210 Photo All-In-One Printer
It shows me an E6 error, tells me it is out of color ink and I know it isn't. I only use gray scale
When the print message was on my computer screen it showed me the color cartridge was 1/2 full(and I don't use it at all). Then the printer wouldn't print at all, insisting I replace the color cartridge. I took it out, tried to put the same one back. It won't take it.
    President:
  • 2,692 Answers
Consumer reports magizine,in last months issue, said that this seems to be a problem on many models. Leaving too much ink. No answer other that to replace the cartriage. Manufactures claim that they have to do it to make sure that it never runs dry.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=15402
Posted on Jan 02, 2009
PABLOCSA
  • 1124 Answers
SOURCE: Ink Replacement
Go to your printer preferences and set your option there.
Start >> Control Panel >> Printers
Select your printer >> right click >> Properties >> in the next dialog, hit the button "Printer Preferences" and set your color there.
Thank you for using FIXYA!
Dont forget to rate my help!
Have a great day!
Pablo :-)
Let me know if you have further questions about this issue.
Posted on Oct 17, 2008
  • 327 Answers
SOURCE: My HP Photosmart C4180 all-in-one
as the colours are at the end so its not printing properly.as very less colours in the cartridge.just get it refilled or replaced.
Posted on Dec 15, 2008
pineworks
  • 4041 Answers
SOURCE: won`t recognize new ink cartridges
Hi there
There are only a few steps you need to do to reset a Brother printer ink cartridge and once you do it, you will be up and printing in no time. There are actually two things that a Brother printer uses to detect ink and you can manipulate one or the other.
Instructions
Things You'll Need: · Black electrical tape, masking tape or duct tape
1. Step 1
Identify the printer If your printer uses memory, you can tell which printer you have by looking at where the cartridge goes in, if you see two "eyes" and a part of the cartridge goes in between them, follow Step 3. Otherwise, continue with Step 2.
2. Step 2
Clear the memory by taking the cartridge out and unplugging the unit for 30 seconds. Then, plug it back in and put back in the cartridge. You may need to do this five times, as the memory holds the last five cartridges.
3. Step 3
If the Brother printer has "eyes" where the cartridge goes, you will need to block in between them with a piece of tape so that it thinks the cartridge is always full. Simply put a piece of tape on the piece of the cartridge that goes in between the eyes to block the path of the infrared beam
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 03, 2010
  • 104 Answers
SOURCE: so I refilled the black
You have to refill both.
Posted on May 16, 2011
  • 1044 Answers
SOURCE: I cannot get my printer
Please take out the new cartridges and re-position them correctly i.e. color cartridge on the left and black cartridge on the right seating. Check that you hear a click sound when the cartridge is placed in the seating. Print a test page. Then switch off the printer for some time. Re start the printer and now carry out the gray scale printing.
Posted on Jul 19, 2011
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
I have a HP Deskjet D4260 and when i print something using HP Deskjet D4200 series its black and white. I need the pictures to be in color
U must be using HP74, 75 cartridge for your printer.
There are few reasons you are getting black and white (gray)...for printing job.
1. No color ink.
- If you are out of color ink.. that's what it happens.
- check your ink level through control panel.
2. Printer set up. (I think this is pretty much the reason you are not getting color)
- First, check your printer setting.
If they are on gray scale mode, pls chang to color.
How? when you click the print (through file manu), there are option for control panel on your screen. Click that option and will see some detail option you can choose from size, print quality.
Among the print quality option, pls choose, color mode instead of gray mode. That's it.
If you would like to save money, try refill kit by "ROADINK".
Not only they are easy, but also the printing quality is good.
For your better understanding pls check out my youtube video.
And will see how easy ink refill can be done.
May 12, 2011 | HP Deskjet D4260 Printer
Hi there, I have a canon printer: PIXMA MG5250. I do a lot of office printing. Can you tell me how to change the setting to only print in gray scale? I like to safe ink usage as much as...
go to the Printing preference, then there's a a settings of Color that change into grey scale.
or if you have a drive /software of your canon PIXMA, theres a printer preference and a settings to grey scale.
Mar 21, 2011 | Canon Office Equipment & Supplies
Print with single cartrige. I rarely use color. The color cartrige ran dry and nothing will print in b&w until I buy a new color cartrige ( for about $37.50) and install it. HOW DO I BYPASS THIS...
as long as the color print cartridges remain in the printer you should be able to print in only black and white.
If the error message does not come up and prompt you to chose this option, you should be able to tell the printer to print in black .
(1) go file print or print
(2) a gray box will pop up click on properties
(3) Click color
(4)click gray scale
This should do it for you!
(5) select black print cartridge only
Mar 26, 2010 | HP Office Equipment & Supplies
Hi there, Can I print in Black & White when I ran out one of colour ink catridges??? On Brother website it says that you can. According to their advice the Error message shoud come up on LCD screen...
If the error message does not come up you should be able to tell the printer to print in black and white in your page setup or print properties portion when you go to print your page.
(3) Click color
(4)click gray scale
Mar 26, 2010 | Brother MFC 6490CW InkJet Printer
I just bought a new printer today its a lenmark Z2300m Color Printer i only have color ink for it do i need black ink for it because everytime i try to print it comes out greenish
Under your printer preferences there is a way to print gray scale. SO even if your image is in color, it will print black and white. Every printer interface is different, but when you go to print, there's usually a properties or setting button that will bring you to another page from the initial print menu. here is where you would choose gray scale.
If you try for black with only a color cartridge, it'll come out a dark green or blue color. Or on some cases, it will tell you it's out of black and you can't print.
Sep 30, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Wouldn't print black-and-white if the color cartridge is empty
Select true black and white. Any other setting uses the colour cartridge to sharpen the printing.
Aug 22, 2009 | Canon PIXMA MP210 InkJet Printer
Why Does My Color Ink Run Out So Fast When I Am Printing In Gray Scale
When sending your print job to the printer, you need to be sure to select "black and white", otherwise your computer will use your color ink cartridges to produce your gray scale image/document.
Aug 12, 2009 | Canon PIXMA MP470 All-in-One Printer
Printing error message: cartridge problem.tri-color.I wasn't even
hi,
its becoz even if ur print contains only black text in it, while printer printing in black it needs a cyan or yellow ink to give very clear print out. work around for this issue, go to the printer icon and right click and go printing preferances and change the option to print only in blak or print only in gray scale. it should resolve ur issue............
Regards,  raj_p5983
Jan 21, 2009 | HP OfficeJet J4580 All-In-One Laser...
Error 5200
my printer is not working. its showing error(5200).what can i do to solve this problem.
Dec 08, 2007 | Canon PIXMA MP130 All-In-One InkJet...
Canon PIXMA MP210 Photo All-In-One Printer Logo
603 people viewed this question
old marine
old marine
