Question about Video Game Consoles & Games
Xbox 360 won't recognize my controller!
I TRIED SYNCING IT MANY TIMES NEVER WORKED! I just got a replacement, same problem my controllers wont synce up at all i need help
  • chris Aug 04, 2012
    ok i have done everyting i know what to do i bought a detel wireless remote it flashes and sometimes it goes on and on and on and other times it stays on for a sec then the lights go off can someone tell me step by step how to sync it up to my xbox 360
    President:
  • 2,976 Answers
Turn on the X-Box, turn on the controller, press the "Find" button on the X-Box, It's the 3/8" ROUND button on the consol. Press the find button on the controller. It's the 1/8" round button next to the LB button.
Posted on Jan 02, 2009
My xbox 360 will not sync with any controllers besides the one controller I've already had synced. I haven't had any problems with it until recently, and now it seems like the xbox won't...
If you have an xbox slim model then there is a button above the USB slots at the bottom. Press Start and Back on the controller until the center button lights up. Then press the button above the two USB solts and hold it for a couple secs.
If you have n old xbox there should be a simliar button some where.
Also if you bought one of the charging packs for the controller, use the cord that came with it.
Thank you for your time, Good luck and I hope it works.
Jun 05, 2011 | Microsoft Xbox 360 Console
MY CONTROLLER WONT CNNCT TO MY XBOX EVEN WEN I SYNC IT . ITS BRAND NEW.
You might have to replace the batteries in the controller, as if the battery life is low the controller will have issues syncing to the xbox 360. Just in cause, To sync the controller to the xbox 360, you must turn on the controller using the xbox guide button and then press the Wireless Sync button right next to the Controller Charging Port. Then you must press the sync button on the xbox 360. You must do this semi-quickly, or the sync process will not complete.
Lastly, You also might have a faulty controller, I suggest you go back to the store you got it from and see if they will replace the faulty controller.
Jan 20, 2011 | Microsoft Xbox 360 Controller
My xbox 360 controllers will NOT sync , i tried looking online and i tried every posible way. But nothing worked , is it the controller or the xbox itself. it worked purfect lasst night and it fell on the...
I'm sure you have tried most of these steps but I'm going to list them any way. So we have a complete picture of the trouble shooting process.
1. Sync system first (By pressing the sync button on the system)
2. Right after you hit the sync button on the system, hit the button on the controller
Try replacing the battery's and or rechargeable battery for the controller. Repeat the sync process above.
Try another controller with your xbox or try your controller with a different xbox. Repeat sync process above of course.
If another controller works with your system than that would indicate that there is an issues with your xbox controller.
If your controller works with another xbox and no other controllers work with your xbox than there is a issue with your console.
For issues related to the xbox I would suggest contact xbox directly by calling 1800 my xbox.
If possible please rate the solution I have posted.
Aug 25, 2010 | Microsoft Xbox 360 Controller
Wireless controler won,t connect to consol
I hope the info listed above has helped in some way.
If possible please rate this solution.
Aug 22, 2010 | Microsoft Xbox 360 Controller
Xbox 360 Controller: My xbox 360 controllers wont sync at all no matter...
Try replacing the batteries in your controller. If this does not work then try the controller on another console. Failing this your controller is broken.
Best recommendation is to buy a wire and use it wired.
May 18, 2010 | Microsoft Xbox 360 Controller
My Xbox 360 controller is not flashing when I try to connect
make sure you press the find button on the 360 and the one on the controller.
on the 360 it is a small circle bellow the disc tray and to the right of the two memory slots.
on the controller it is on the top its small and circlular with three semicircles near it.
if it still doesnt work then try to synce up with another persons console. if the controller still doesnt then you need a new one. if it does then use their controller to sync up with your console. if it still will not sync up with YOUR console.
then call
1-800-4MY-XBOX
1-800-469-9269
Jul 08, 2009 | Microsoft Xbox 360 Console
Syncing dont work!!!!
Sounds like the sync button is probably stuck. You should tap it a few times with something pokey like a pin and see if that helps, if not the contact inside broke off and the easiest thing would be to replace it.
Jan 29, 2009 | Microsoft Xbox 360 Controller
XBOX 360 WIRELSS CONTROLLERS JUST BLINK WONT CONNECT
Did you try to press the sync button on both the XBOX and the controller? This should make them connect after they take a second to find out that their searching for eachother. If this doesn't work then you should call into Microsoft and talk to them because the sync system might be faulty. Try the controllers on another XBOX before calling just to make sure though.
Dec 30, 2008 | Microsoft Wireless Controller for Xbox 360...
If your controller is just blinking you must press the small button on your xbox and at the same time press the small button on the back of your xbox controller and the xbox will pick controller signal.
Jul 06, 2008 | Microsoft Xbox 360 Controller
Video Game Consoles & Games Logo
1,721 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Josh Whitehead
Josh Whitehead
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
