Question about Kenwood KDC-MP5032 CD Player
Radio turning off then on again?
My radio turns off then turns on again and keeps doing it. Can it be getting to hot or do you think it can be the power wire?Any help will be great.
Your radio is shorting out, it normally just does that if it is not a killer short
Posted on Aug 20, 2008
Turn off radio
I would think pulling the power would do it.
Apr 22, 2014 | Radio Communications
All the wires are hooked up to my radio correctly but when i crank my car or turn the key back the radio doesn't come on. then when i cut the park lights on the speakers make some kind of flickering noise...
I think you need to check your power wires to your radio. This is a common mistake. There are several power wires to deal with. One wire stays hot to keep the clock and radio presets working. The second is Hot when the key is turned on. The third is hot when you turn on your lights for instrument lighting. If you connected this wire for your power source, You would have this problem you are describing. If it's wired correctly, Check the ground wire to the radio. Hope this helps.
Mar 13, 2010 | 1995 Buick LeSabre
My CD is stuck and reading no disc how do I get it out without damanaging my system?
Turn the radio off and then disconnect the battery, wait 2 min then reconnect the battery. Turn on the radio and hit eject, that should reset the radio and you have to set the stations and clock. Note: radio must be off before disconnecting the battery, os your going to have to re-enter the radio code to have the radio active again.
Good luck and keep me posted.
Jul 22, 2009 | 2008 Chevrolet Malibu Classic
The radio wont turn off when i turn the key
You could be hooking up the main power to a full time hot rather than the radio circuit. Use a test light to find the switchable hot and hook up your power wire to it, then then memory for the radio goes to the full time hot.
Apr 14, 2009 | 1991 Chevrolet S-10 Blazer
Kenwood KDC-W312S wont keep the saved channels after car restart
Check the yellow wire connection on your wiring harness... This is the wire that provides continuous power even when the ignition is off. This is how the radio remembers presets/time and such. Every time you turn off the car, the radio "resets" because you dont have the yellow wire connected to an ALWAYS HOT wire.
If you cannot find a hot wire, then you can run a wire from the yellow on the back of your radio directly to the positive terminal on your battery. Dont worry, it doesnt draw enough power to run your battery down.
Most cars have a cigarette lighter or power port somewhere that is always hot. You could always run the yellow wire off of one of these.
Just find a way to get the yellow wire on a hot wire and your stereo will remember the presets.
Mar 29, 2009 | Kenwood M-303USB Shelf System
Radio turns off in starting position
this look like a low battery and every time you try to crank your car it takes more power and kill the main power to the radio
solution # 2 the radio as 2 power wires one is always hot ( with current) and the other is connected to the ignition switch if you have replaced the radio those 2 wires maybe are connected backwards the one that goes to the switch is probably connected directly to the battery and the one is suppose to be always hot is probably connected to the switch if you have the original radio have your battery tested and if is ok then try get a haynes book at any auto parts for you car and try to follow the wire that is always hot normally is a yellow or orange wire
solution #3 this apply only if you car still have the original radio
turn your ignition switch to the on position but don't crank your car and turn your radio on select a radio station then turn your ignition key off and wait 3 minutes then turn your ignition switch on again with out cranking your car and the radio should be in the same radio station you select if this test pass then chances are is your battery getting low and if this test fail then the hot wire has a blow fuse look for the fuse inside the hook let me know what happend and good luck
Mar 18, 2009 | 2001 Toyota Sienna
Dashlight, running lights, tail lights all dont work.
you have a wire wrong on the radio it all happened
when you turnd on the lights right i done the same
thing on 96 dodge ram pick up when you turn on the lights one wire u would think is a ground turns into a hot for radio lights so check your fuses unhook radio
turn on lights an check for hot wires that are not hot when they are of hook that one to the memory
wire on radio
Feb 23, 2009 | 1998 Mitsubishi Eclipse
2006 factory dodge radio sat quit working
soft reset. get in turn on truck with door shut turn on sat radio on ch 184. turn off radio turn off truck and take keys out. next open door fully for 90 seconds. shut door. turn on truck. turn on radio and have sirius reset it. its called a soft reset.
Dec 25, 2008 | Eclipse SIR-ECL1 SIRIUS Radio Receiver
Car radio
Obviously there is a heating problem with it. It seems that it is getting too hot and its shutting down before it overheats and catches fire. Pull the radio out of the dash and leave the wires connected. Are there any bare wires or ones not connected good? There may be a short between the wires thats not a significant enough connection to blow the fuse. Seperate the wires from each other and turn the radio back on. Let it play till the time that it usually shuts down. If its still doing it I would suggest smashing it with a hammer.
Jan 26, 2008 | Cherokee Jeep Grand - RBB AM/FM Stereo...
No recieving
sounds like the reciever is getting hot? try bringing it to a local radio shack dealer and see if they will have there techs. look at it.
Jun 10, 2007 | Radio Shack Pro-2018 Scanner
Kenwood KDC-MP5032 CD Player Logo
114 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
