Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Liftmaster garage door opener problem.
Hello, I have just installed the rebuild kit for my liftmaster opener, (yr 2000). I have adjusted the springs so the door will hang still four feet off the ground. I degreased and relubed all parts-chain, wheels, pivot points, etc. Now the problem is when I activate the opener the door only travels about one foot, then stops and reverses.????
Thanks in advance,
Vince
  • 1 more comment
  • wildbregner Dec 30, 2008
    I replaced the plastic drive gear ,now door will only travel about a foot then comes right back up.
  • sclark1959 Jan 03, 2009
    I also just replaced the gear and sprocket kit and have the same problem. The traveler moved about 8 inches, stops and goes back. No apparent reason.
  • Joseph Chapman
    Joseph Chapman May 11, 2010
    When it reverses does the traveler go all the way open or closed or does it just travel a foot or so and stop.
Thats what it was
Posted on Dec 31, 2008
  • 37 Answers
Make sure that you pluged in the RPM Sensor.
Posted on Dec 30, 2008
How much is gear kit for 1/2 #41A2817?
Gear kits can be purchased for chain drive machines from any of these 3 brand names ...Liftmaster/sears craftsman /chamberlain / All 3 of these brand names are manufactured by Liftmaster the worlds largest maker of garage door openers and related parts ! You can purchase a gear kit on ebay for around $30 or less depending on the seller ! If you go to garage door parts sites it will be slightly higher so your best bet is EBAY , The gear kit only requires the main gear and sprocket housing that attaches with 3 screws , just remember after the gear is installed that you run the motor co that the trolley starts in the door down position otherwise you risk having the trolley smack into the opener , this is crucial for any travel adjustments that are made later! Hope this helps you ,sincerely Glenn
Feb 04, 2015 | liftmaster Garage Door 1/2 Hp
Installed two new springs on automatic doorman model 455 and it won't close or open. chain will not move door where are adjustment screws? I think that may be the problem
Does it make a noise? Did it run before you changed the springs? Did you replace springs on opener or on the door? What adjustment screws are you looking for? Do you think they went out of adjustment when you changed the springs?
Sep 04, 2011 | Sears Craftsman LiftMaster Chamberlain...
The range for the remote openers (4) for mu Liftmaster garage door opener has decreased to the point of having to be within 6 feet of the door to open it. The liftmaster was installed 5 yrs ago. The...
There is an antenna extender kit available for your opener. The part number is 41A3504 and should be available from any good door opener company that handles Liftmaster or Chamberlain. It should come with instructions.
Jul 22, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a LiftMaster garage door opener.When the door closes it is not completely closed on the right side. It has about a 1/4" gap at the bottom. It starts closing evenly but when it is about 2 feet...
It sounds like a door spring problem. Here is a website with a video of adjusting a door with extension springs.
http://www.diygaragerepair.com/Extension-Springs-s/296.htm
Oct 26, 2010 | Sears Craftsman LiftMaster Chamberlain...
The garage door opens halfway and then stops; it will close completely however
COULD BE A BROKEN SPRING
COULD BE A SENSITIVITY ADJUSTMENT.
HOW DOES THE DOOR WORK MANUALLY - IF YOU CAN'T LIFT IT NEITHER CAN THE OPENER.
ALSO COULD BE BAD DRIVE GEARS - BUT MOST OFTEN A SPRING 2ND WOULD BE OPERATOR ADJUSTMENT
Jun 20, 2010 | Sears Craftsman LiftMaster Chamberlain...
My liftmaster garage door only opens 8 inches and then stops
It sounds like the opener is stopping because the weight of the door is tripping the lift sensor on the opener. There are two screws on the side of the opener to adjust the lift and close pressure. Find the lift pressure screw and ajust it higher to see if that remedies the problem.
Also, because you said the door will not stay open at the top when you open it manually, I think your springs are not adjusted correctly. They should hold the door open in the up position when not connected to the door opener. That may be the reason the opener lift pressure is kicking it out.
If you have to adjust the springs, be careful that you know what you are doing. There is a lot of potential for getting hurt if you don't know the proper proceedure.
Good luck.
Jan 17, 2010 | liftmaster Chamberlain Garage Door Opener...
Installed Chamberlain Whisper Drive but door slides backwards
It sounds like you may have a spring problem. Release the door from the opener and see how it acts manually. Open it as far as the opener does and then see what happens when you release it. Also the weight of the door should give you a clue.
Aug 24, 2009 | Liftmaster, Chamberlain, Sears Door...
Belt drive track arm bows up
YOU MAY NEED TO GET THE SPRING ON THE DOOR ADJUSTED.
WHEN AN OPENER IS INSTALLED THE SPRING SHOULD BE SET A LITTLE HEAVY. YOU WANT THE DOOR TO SLOWLY DRIFT CLOSED IF LEFT HALFWAY UP.
IT SOUNDS LIKE EITHER YOUR SPRING NEEDS ADJUSTMENT OR THE DOOR BINDS AT THE BOTTOM - HOW DOES IT WORK MANUALLY??
IF YOU CAN'T CLOSE IT WITH 3 FINGERS THE OPENER WILL HAVE TROUBLE.
YES THE CRAFTSMAN RAIL IS WEAK MAKING IT THAT MUCH MORE CRITICAL TO SET THE HEIGHT PER INSTRUCTIONS AND MAKE SURE THE DOOR WORKS EASILY,
HOPE THIS HELPS
Apr 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
LiftMaster Gargage door opener problem
The door obstacle detector(reversing switch) needs adjustment, or the down limit sensor needs adjusting, or one of the lift springs is loose or broken. First, remove power from the opener, pull the red door release rope, and try to lift the door up manually. You should be able to lift it all the way open with litle effort. If it opens ok, pull the door down about halfway and let go. If it is properly balanced, it should stay where you left it. If the door fails either one of these tests, it needs spring replacement or adjustment. If the door moves ok, refer to your owners manual on how to adjust the reversing switch, linit switches, and photocell sensors at the door bottom.
Jul 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
253 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
