Question about Kenmore Washing Machines
Rotary dial won't work
The timer dial that you set the mode you want and that you pull out to start the washer does not work. When you turn the dial to set the mode, the outer dial handle just turns but the setting dial does not turn. What should I do?
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 12, 2010
My kenmore 665 started pumping hot water without ever turning machine on
You might have a bad water valve, or a bad timer (especially if this dishwasher uses a mechanical timer - one that has a rotary dial in front).
Feb 24, 2015 | Kenmore 665
Why would my Amana washer not do anything but fill up with water. Nothing will function at all on all the cycles but the fill. It doesn't even click on the timer when you try to set to any setting exc
Hi Kirby
First... Caution
Because your dealing with water & electricity it can be lethal to fiddle around inside. That said...
Washing machines are controlled by a master timer unit, usually mechanical, but rotated by an AC Clock motor. If the timer is not getting voltages to the various Switches around the "timer unit" or "clock motor" then the individual selected functions won't work.
Manually Rotating to a particular function then Activating the On/Off Push/Pull switch should start things happening even if timer motor is dead. So
If your OK with AC electrical goods then open it up.
Connection wires may have fallen off or something simple. A multimeter is your best friend here. Look for the big rotary clock behind the main control dial. Listen for the clock motor running. The main Push in & out Button is the On / Off switch. Check that its got AC on the input wire & switches across to the other wire when the knob is pushed in / out. This may be the problem...
You can always call an appliance repair technician!
Good Luck
Nov 19, 2014 | Amana 3.2 cu. ft. Top-Load Washer
Dishwasher won't start
its the timer in the dial replace it and it will work fine yes its worth fixing
Dec 03, 2012 | Kenmore Dishwashers
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Washer continues to run but the timer stops at 42 minutes
OK I see it.
Most likely problem is the timer. The timer tells the machine what to do and when. Yours is sticking at the 42min mark.
I do not see the model number so I'll take an assumption.
Digital timers are integral to the control panel and can be replaced as part of the panel.
Rotary dial timers are easily removed and replaced.
Switch the breaker off. Do not touch the control panel without first having done so.
To remove the control panel there are screws around the outside of the door frame and on some units from inside the machine on the door frame. Remove them and the control panel will be exposed.
If you have a rotary dial timer remove the control knob (pulls off) and the screws retaining the timer inside the control panel. You can sometimes "fiddle" with this style timer and get it going again. It is usually just dirt struck in the mechanism stopping it turning. But it is not expensive and I'd just replace it.
Digital is another system. If you can remove the timer section as a unit then you can replace it. Fist I would get the model number and go to your local parts dealer. Ask it you can get just the timer. If so replace it. There are no serviceable parts in an digital timer.
I hope this helps you. Please rate it is it helps clarify for you.
Mar 10, 2010 | Whirlpool Dishwashers
How do you find and use the self-timer setting?
Hello.
Turn the function dial to the drive mode position.
Press the function button in the center of the dial.
Turn the front control dial to select the self-timer drive mode.
Use the rear control dial to to switch between a ten-second and a two-second delay.
Press the shutter-release button partway down or press the function button to set the mode.
When you are ready to take the picture.
Press the shutter button partway down to set the focus and exposure.
Press the shutter button all the way down to start the timer.
Hope this helps.
Feb 16, 2010 | Konica Minolta DiMAGE A1 Digital Camera
Fabric softener cup on Maytag Neptune washer is full of fabric softener after the cycle. Checked valves in output mode. Both the main and the bleach valve turn on and dispense water, but no water dispenses...
Hi. your problem is actually a rather complicated one.
Timer and selector switches The timer switch is usually the largest dial on the main control panel. It can be either a mechanical device much like a simple clock, or completely electronic with just a digital readout.
The timer runs the washing machine in a pre-determined pattern. It provides the electricity to all of the washing machine components at the correct time and for the correct length of time.
The Start switch is usually part of the timer knob. When you set the timer to the proper cycle, you either pull or push the timer knob to start the cycle.
The selector switches or knobs vary from machine to machine. Most washing machines have one or several switches or knobs on the control panel besides the Timer/Start switch. These let you adjust certain settings; for example, the water temperature, spin speed, timer cycle, and so on. Normally, the washing machine completes the cycle selected on the timer, regardless of how you set these switches and knobs.
Jul 14, 2009 | Maytag MAH2400A Front Load Washer
Washer only works by manually advancing the dial.
yes this sounds like a timer it sounds like it is getting stuck in the cycle. replace the timer and this will clear up the problem
Dec 29, 2008 | Maytag SAV3710AWW Washer
Kenmore Washer timer dial is not advancing
ok " timer has a small stepper motor in it, and it can be replaced
take stepper motor out .
appliance parts store will have it
or just replace timer
take make and model number with you
Jan 13, 2008 | Washing Machines
Ge 900 MHz cordless phone set on rotary dialing
Lisa, If the 900MHZ phone is Model 26928M programming for rotary dial usually goes like below, can't hurt to try on any model. TONE/PULSE DIALING This adjustment allows you to select tone (touch-tone) or pulse (rotary) mode dialing. The phone is pre-set for touch-tone use. To set to tone or pulse dialing: 1. Press and hold the program button for two seconds. You will hear a beep. 2. Press the *tone button to select Tone Dialing or press #pause to select Pulse Dialing. 3. Press the program button again. You will hear a confirmation tone.
Sep 29, 2007 | Uniden Cordless Phone
Washing Machines Logo
29 people viewed this question
Sal De
fordexpert
Robert Rankin
