It did not empty and dishes were not cleaned. It seems like the dirty water did not empty---pump???
Leave it off for a while and try it again, if this does not work you will need:
A person to help tip the machine over
a basin
a pliers
screw drivers
some rags
Empty out as best you can the remaining water from your machine.
Roll over and remove the bottom of the dishwasher, you might need to remoce screws from the back panel too.
Carefully remove the bottom panel, there may be devices attached to it slide your hand in and unclip them, BUT be carefull often the edges of the metal is sharp.
Once the bottom is of grab your pliers and you patience and release the clips on the hoses, blow them all out. The salt store might need to be emptied completly.
Reconnect everything and replace the bottom.
Stand the machine up and refill the salt store with water to the top.
Test the machine, it should now work.
Hope this helped
SOURCE: Whirlpool dishwasher ADP 4732AL
sound like you have a valty inlet valve if your model has the valve built into the hose you will have to replace the hose assy.
SOURCE: my whirlpool dishwasher does not clean dishes.
Replace the impeller kit below the spray arm.
SOURCE: Maytag dishwasher not draining fully
Try cleaning out the air gap. The air gap is not part of the machine, and is located on your sink. If this becomes clogged, it may cause the machine to not drain properly. Also, I know you said you checked the drain hose and cleaned as far as the filter and chopper blade, but have you checked the lower filter? There is a filter located underneath the machine that should periodically be cleaned. To check this, you need to access the machine from underneath by removing the bottom vanity cover. Hope that one of these helps!
SOURCE: Whirlpool dishwasher 2966 draining failure
take the airgap apart. located on top of sink. clean out and reassemble.
SOURCE: Error code F4
The F4 error code on your washer indicates a problem in the electrical circuits of the washer... and not end-user repairable.
This problem requires a technician to test the wiring circuits to diagnose the problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
