Question about Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Remote receiver faulty
Nothing on my heritage fan,model H52CU, worked until I by-past the remote receiver and then it worked again. This tells me I need a new receiver.
  • mike_perr214 May 11, 2010
    how do you by pass your remote?????????
  • 8,197 Answers
That is correct you need a new receiver for the fan. The other problem that could have happened is when you replaced the batter in the remote you accidentally hit the dip switches and changed them. That is the box that has 4 white switches on it. One is in the remote and one is one the receiver that goes in the fan.
Good Luck ANd Please Rate FixYa!
Posted on Dec 29, 2008
Is heritage model h52ul an outdoor fan?
Here's a guess.
If it looks like an inside fan, it probably is not waterproof enough to last past one trip outside and get rained on.
Nov 05, 2015 | Heritage Dryers
I have a Heritage Celing fan model M42UL. I connected it to work with the remote control. It does not work with the remote anymore. How can I reconnect it to work without the remote?
Make sure your dip switches match in the receiver & transmitter. If you have a wall switch, make sure it's ON. If there are pull chains on the fan, press the high on remote then pull chain until it's on high speed.
Aug 29, 2015 | Heritage Dryers
We just bought a house that has 3 of the same fans. THey are hunter with remote and no pull cords. The master bedroom fan doesnt work. We tried to rewire it and the only way we could get anything to...
Hi Leanne,
Most fans have green, white, black and blue wires. Green is earth or safety ground, white is neutral, black is for the fan and blue is for the light fixture. Some fans may deviate from these commonly used colors in which case you should consult the instructions. Below are links to instructions for different Hunter remote fans, additional instructions for Hunter remote fans or you can look up your fan by model number or use. It appears that the built-in remote Hunter fans have no provision for controlling a light when the fan is wired from a traditional switch instead of using the included remote, as they have only a green, white and a single black that remains powered constantly to supply the remote receiver. The hand held remote transmitter tells the receiver to switch power to the fan motor and light bulbs as needed.
It is possible that the transmitter or receiver you're using in this room is not working. Try using one of the other remotes with the non-working fan by matching the code of the remote to the fan. If it doesn't work, try selecting a different code on the fan and match it on the remote (in case there's a problem with that particular code in this location). Try all (or as many as you care) codes to see if any codes work with this remote.
By this time, you should have either found a working code with this remote and are all done, or still have a non-working fan. Since you have tried more than one remote - and know that one of them worked in the other room, suspicion falls on a faulty fan or integrated remote receiver. You can replace the fan if you like with a traditional fan and light and purchase an after market or third party RF remote control if you no longer wish to get an integrated remote receiver.
I hope this helps and good luck. Please rate my reply - thanks!
Apr 19, 2011 | Dryers
Heritage superfan model 4000hp fan does not work!
This fan has a unique dc motor and a proprietary controller. DO NOT USE A STANDARD CONTROLLER OR SWITCH. The controller is very rare and is no longer made or supported. The company was purchased by Casablanca Fans, but they offer no help.
May 03, 2010 | Heritage (5BUW52WZ4HN) 52'' Ceiling Fan
Light or fan will come on with without remote
Most remotes use an X10 format that transmits over wires .. Odds are someone else in your neighborhood is on the same code. Does the light come on with regularity? If it does than that is your problem. Without knowing the exact model I can't tell you how to change the code. When you change it you must change the receiver and the transmitter
Oct 02, 2009 | Heritage 30" Children's Room Ceiling Fan...
Heritage Ceiling Fan
You can try a univeral remote and that should work. You can buy one online at: http://www.ceiling-fans-n-more.com/ceiling-fan-remote-controls.php
Jul 10, 2009 | Dryers
Hampton Bay Garrison 52" fan stuck on high
nothing wrong with the power supply, or the remote, the speed switch in the fan is faulty, as it is more finiky than a manual speed change(like with a cable)
Jun 15, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Heritage ceiling fan, M52UL lost remote
Translate Homepage ' Dictionary Homepage I have the fan model m52ul where I can get the fan speed control is the box that receives the signal from the control
Nov 22, 2008 | Dryers
Fan is Erratic
Ceiling fans with wireless remote controls have an electronic receiver installed in the fan, which controls the light, dimming, and fan speed. Sometimes the receiver goes bad and needs to be replaced. If you have had any power outages or power surges, they may have fried the receiver. I've noticed that my ceiling fan light turns on when the power is restored after a power outage. Now, whenever my power goes out, I shut off the light switch that powers my ceiling fan so It doesn't experience a surge to to the controller when the power comes back on. I've purchased new receivers on eBay and Amazon to replace my blown remotes and receivers.
Sep 07, 2008 | Hunter 22451 The Brookline Brushed Nickel...
Light not working by pull chain or remote.
I would try removing the remote part. Connect the two main (light & fan) wires direct to your house main. Then if the pull chain works then you just need a new remote unit.
Feb 13, 2008 | Heritage (5BUW52NK2YQ) 52" Ceiling Fan
Heritage (5BUW52WZ4HN) 52'' Ceiling Fan Logo
172 people viewed this question
Top Heritage Dryers Experts
roeb
Michael Galve
Michael Galve
Ottoniel
Are you a Heritage Dryer Expert? Answer questions, earn points and help others
