Question about Weather King 12AJA4801AH Air Conditioner
Whirlpool Dryer blows cold air when starting no heat
The dryer blows cold air. We have recently changed the thermal fuse and it seemed to get a little warmer inside, then went back to blowing cold air. Please help!
Whirlpool model # LGR5620KQ1
  • 39 Answers
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Posted on Jan 13, 2009
Thermal cutoff switch fails 2x in a year. Heating coil ohms out ok.
Whirlpool Thin Twin, dryer thermal cutoff failed twice - Appliance ... > Appliance Repair Help > Dryer Repair
Oct 12, 2011 - 6 posts - ‎2 authors
Friends Whirlpool Thin Twin came with purchase of condo half a year ago. A month ago it stopped heating. I checked continuity and found the ... Whirlpool Dryer Thermal Cutoff
Jan 9, 2013
Thermal cutoff blew again (Whrpl Elect Dryer)
1 post
Jan 5, 2013
More results from
Why does the thermal fuse keep blowing in my dryer ... > Manage My Life > Questions
Dec 28, 2015 | Dryers
How do I know when the thermal fuse for my whirlpool deut electric dryer is bad?
Take it out. check it with a multimeter set on ohms. Get a hair dryer turn it on hotest setting. with meter leads on each end of the thermal fuse have someone hold the hair dryer blowing hot air on fuse. It should show continuity through it when cold. After heat is applied it should show 0 or infinity. If its working properly move on to over temp switch.
Sep 02, 2014 | Whirlpool GEW9250 Electric Dryer
If the drum is turning and air is blowing then the most likely causes are thermal fuse trip, thermostat fault or heater fault.
Some good points mentioned on this site.
Discussion about thermal fuse on this site.
May 05, 2014 | Dryers
Dryer is not heating up.
90% of electric dryers emitting cold air need a new heating element installed. If you've checked the thermal fuse, and verified the unit has around 220 volts of power, then the only thing left is the heating element. Typically costs around $40-$60. Can be done by you if you have basic electrical knowledge, otherwise call an electrician.
May 13, 2010 | Kenmore 62802 Electric Dryer
Dryer jus blows cold air on heat cycle and i replaced thermal fuse
either you have an open limit or your element is bad . thermal fuse if bad won"t even let dryer turn on
Jan 25, 2010 | Whirlpool LGR5636L Gas Dryer
Dryer blows only cold air.
If it's an electric dryer, then unplug the machine and check for a blown thermal fuse or a faulty heating element. The thermal fuse is about an inch long and is located inside the rear of the dryer, usually attached to or near the exhaust duct. The thermal fuse and heating element can be tested for continuity using a multimeter or ohmmeter. A lack of continuity will indicate a bad component. Sorry for your trouble and I hope this helped. Best wishes.
Oct 07, 2009 | Whirlpool Dryers
Dryer blowing cold air whirlpool awz3513
Check for a blown thermal fuse or a faulty heating element. Both components can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty component. The thermal fuse is about an inch long and is located just inside the rear of the dryer and is usually attached to or near the exhaust duct. Hope this helped and best wishes.
Aug 31, 2009 | Dryers
My dryer is just blowing cold air
Check the breaker box make and make sure the breaker is all the way over to the on side and then if it still continues check the thermal fuse and the heating element.
Apr 01, 2009 | Whirlpool LER4634J Electric Dryer
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
There is a thermal fuse its location depends on the dryer if the filter is on the top then you have to take off the back panel and check the white fuse. If the filter is inside the dryer you have to take off the bottom panel. a flathead screw driver for the 2 clips the check the white fuse behind the lint trap (where the filter goes).
Oct 29, 2008 | Whirlpool GGQ8831L Gas Dryer
Weather King 12AJA4801AH Air Conditioner Logo
181 people viewed this question
Top Weather King Heating & Cooling Experts
Tim Whalen
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
