Question about Mintek MDP-1815 Portable DVD Player
I drop the player and can not get the disk to play it will not spin
    President:
  • 814 Answers
This company is out of business. It will be cheaper to buy a new dvd player. If you could find service it will probably cost you more than a new dvd player. I hope this information helps you with your problem.
Posted on Jun 09, 2009
CD player plays some CD but some of the others it spins them and tosses them off the cone
The center cone on the hub could be a problem if the player was not for the right juke. Each brand has their own style. (If you still have the old player, check and make sure the the hubs are the same.) The center cone on the hubs are glued in place so if they are different you might be able to pop the old one off and replace it to the new player. One other problem could also be the magnetic pressure disk that is supposed to hold the disk on the hub. Is it centered in the hold down arm or does it rub the sides? Does the disk wobble as it spins? The magnetic disk is supposed to hold it down on the hub to prevent it from wobbling and coming off the turntable.
Oct 20, 2014 | Wurlitzer Jukebox 1015 One More Time...
DVD Player will spin disk, but will not read
Is your DVD player a multisystem player??????? If no,It is quite possible that the DVD's you are playing are not recorded on the format which your DVD can play. Please check It is also possible that the head of the DVD requires cleaning over use for 2 years OR the DVD being played has been lying inoperative for a long time thus gathering dust and moisture requires cleaning now
Dec 20, 2009 | Cars & Trucks
Disk rotating and a message "invalid disk"
you can try manually cleaning the laser lens ( gently wipe , do not press down hard , it is suspended by fine wires ) using a q-tip and a drop of that cleaning solution you got with the laser lens disc. ( fluff another q-tip a little ) then dry wipe it with another q-tip and try a disc.
you can look at the laser lens and see if you see the laser come on also to determine if that is working ( do not look directly into the laser ! )
if the laser works but it still does not read discs after cleaning it manually , then there is a problem with the focus coil on the laser or the signal board is bad
Jan 10, 2009 | Coby DVD-211
CD Player Skipping And Spinning Backwards!
Clean laser first. Near the laser there will 2 / 3 adjustable pots. Mark location on them all first. Pick one (then another) move a little left or right and see if you can get it working. If all fails return them to original positions nothing but time lost.
Apr 01, 2017 | Yamaha CDC-502 5-Disc CD Changer
Pioneer PD-F907 CD wont play most of the time
MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
Jun 26, 2008 | Pioneer PD-F907 CD Player
Phillips portable player PET724
I had the same problem with my PET724. I tried cleaning the lens, letting the battery run dead, even beating on it but nothing worked. When I was cleaning the lens again with some cleaning agent I accidentally slid the laser head as far away from the center as it would go. When I loaded another disc it has worked fine ever since. I have played at least two dozen discs so far with no problem.
Hope this helps.
Apr 19, 2008 | Philips PET724 Portable DVD Player
Audiovox MVDVD4
Just stumbled upon this as I was searching for a new MVDVD4 and thought it might help you out!! :
When the van was a little over 3 years old, the DVD player suddenly quit working. I would put in a DVD, the player made some noises like it was trying to read the DVD, then the display would say "NO DISK".
As it was out of warranty and I have a background in electronics, I opened the player. After playing around for a little while, I was able to fix the player real easily. If you have the same problem (and the player is out of warranty), open up the DVD player by removing the screws and breaking the seal. I blew out the inside with compressed air, but I doubt this made a difference. The problem was that the DVD was not spinning. The spinning mechanism under the DVD tray was not starting like it should. I carefully sprayed a couple drops of WD-40 (well actually Remington's Rem Oil) where the metal rod the spinner sits on goes into the motor mechanism that spins it (it will make sense when you look inside. It is where the little metal rod goes into the plastic casing). After a couple of drops of oil, the player worked fine again.
Mar 02, 2008 | Audiovox MVDVD4 Car Video Player
Check disc message
Sometimes the Spindel Comes lose from the Platter,Put one small drop of Super glue,Where the Center pin on the Platter is let dry for ! Hour,Should restore full operation...
Jul 19, 2007 | Zenith DVP615 Portable DVD Player
Mintek MDP-1815 Portable DVD Player Logo
85 people viewed this question
Top Mintek Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Mintek Televison and Video Expert? Answer questions, earn points and help others
