There is a small "lever or slide" for a lack of a good name at the moment . It is located at the base of the post where the arm is attached . It has a small lip on it that is what you use to slide it out , allowing the arm to slide off the post. It works as a" keeper" that is pushed back in to keep the arm attached when the arm is slid back onto the post .
SOURCE: 2001 dodge ram 1500 v8 spark plug wire diagram
the firing order is 1 8 4 3 6 5 7 2 clockwise around the cap
SOURCE: Need to remove wiper arms from 1998 Dodge Ram in
pull off the guard shield at the base of the wiper arm and a nut should be exposed remove the nut if one there and it should pull off if neither is present pull the arm upwards and with a tiny pin fit into the hole causing the wiper arm to stay up and out and simply lift it off
SOURCE: How do you remove the wiper arm on a 94 Dodge Ram
throw a grenade at it and hopefully the arms will fly off, whatever happened to a nut on a threaded flange to hold wipers on. No wonder imports own the market.
its dave solved it i had been at it for 2 solid hours THANK YOU itsdave
