Question about Kodak EasyShare Z1275 Digital Camera
  • 3 more comments
  • mb0046 Jan 04, 2009
    I have tried several different batteries from different packs and the camera will turn on for a second and then turn off and the lens stays out.
  • DPeariso Jan 12, 2009
    Same problem here folks...just sent mine off to precision camera for repair $95 is what the estimate is for repair. I was 1 month outside of warranty and think that our friends at Kodak might now something about this problem, but won't offer assistance when you call them.
  • raynique06 Jan 18, 2009
    my kodax camera just turn on for a split second and shut off and then I put some new charge batteries in it, it still does the same thing. I don't understand why it does that in the first place!
  • renee_morcom Jan 22, 2009
    I have the EXACT same problem! The camera turns on for a second to let the lens out and then it freezes and won't take pictures, and it won't shut off either-----it's just frozen like that. I have tried regular batteries, and then went out and got rechargeable batteries. I still have the same problem. I have missed some great pictures because of this.
    Can anyone help me?
  • Anonymous May 21, 2009
    This problem just started happening for me. I've had the camera just over a year... maybe 15 months. If you repeatedly try turning the camera on, it seems to eventually work for a while. The problem seems worse with rechargeables than normal AA's. I bet the rechargeables provide a lower amp current, and the camera "thinks" they're low sooner. This is bad though, as buying batteries is way too expensive.
My Z1275 was off with the lens open. When I turned it on, the lens moved a little, the screen came on
for an instant, and then the camera off.
Here is what I did to "fix" it.
I turned it on and helped the lens (gently) close while it was moving. It closed and the camera came on.
It must have been dropped and slightly bent in such a way where the lens could not close.
Good Luck!
Posted on Apr 14, 2009
Flat batteries
Posted on Dec 29, 2008
Panasonic Plasma TC-50PU54 LF21030116 Power light blinks 8 times When I attempt to power on it turns on for split second then shuts down. Is this fixable? thanks.
Yes. It is probably a problem with the internal power circuitry. Look in the circuit board area where the power cord mates with it for capacitors that have bulging tops (instead of the flat tops that are normal). If you see even one, you need to replace all the large capacitors othe power supply section (normally around 5 or 6).
Dec 08, 2014 | Panasonic Televison & Video
The on off button is red. when pushed it turns green for a split second. the audio comes on, but not the picture, and shuts off a split second later. the on off button turns red again.
Please let me know model number and brand of your tv to find out possible cause of problem and to suggest a solution.
Mar 18, 2011 | Televison & Video
Camera turns on for a second beeps three times and shuts off.
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
Oct 31, 2009 | Cameras
Samsung bl103
Mine did the same thing. Just let it sit for a couple of days. Don't mess with it. It'll eventually stop doing that and work. That's what i did. It worked for mine.
Jul 15, 2009 | Samsung Digimax D53 Digital Camera
simply change the batteries as the batteries are unable to tale the load internal damage because of not using regularly.
May 30, 2009 | Kodak EasyShare Z1275 Digital Camera
Camera turns on and then right off immediatly
first if u want to get ur cam to work use energizer rechargeable batteries after charging them for sure this is the best kind u can use powerful and last longer ,to get ur pictures out u can take memory off the cam and put it inside memory card reader then plug it to ur computer through usb ,computer will read it easy and u can download ur pics to ur pc
Mar 27, 2009 | Vivitar ViviCam 3750 Digital Camera
Kodak C533
it was my bf present and im having trouble with my kodak c533 camera it wont turn on.....
May 23, 2008 | Kodak EasyShare C533 Digital Camera
Lense not closing, switching on for one second then shuts down. when attempting to turn on green light flashes then turns off
try resetting the camera once ... remove the batteries and press the power button for few seconds and put ur batteries back !!
May 21, 2008 | Canon Cameras
Sony cybershot dsc-s90
Hey Gregorious03,
You could try removing the batteries for at least one minute and then reinserting them, or you could try initializing the camera back to the factory settings under the setup menu. I hope this helps!
Go Ahead. Use Us.
May 14, 2008 | Sony Cyber-Shot DSC-S90 Digital Camera
Turns on for split second
Same as above light flicks briefly will not come on tried several batteries that works in another camera please help Frank JJ Cali
Nov 12, 2007 | Sony Mavica MVC-FD200 Digital Camera
Kodak EasyShare Z1275 Digital Camera Logo
377 people viewed this question
Top Kodak Cameras Experts
Are you a Kodak Camera Expert? Answer questions, earn points and help others
