Question about Samsung PCN5425R 54" Rear Projection Television
Loss of convergence after powering off.
One morning I powered on and all convergence was lost. I had no controls to adjust it, nothing worked, so I replace the convergence board, and convergence module. Now I am able to adjust my convergence just fine but when I power the TV off I loose the convergence and have to redo it every time I turn the TV back on. On another note when I try the auto focus feature it displays a message "Check Factory Settings". Any help would be appreciated.
    Sergeant:
    Champion:
  • 375 Answers
You must enter the service mode and align your convergence and save it to the epromm also activate the auto focus to activate the sensors , power on /mute-1-8-2- / press enter to save and before you exit activate the focus key on the remote ,very inportant to do the last step./g
Posted on Aug 18, 2007
Periodic power loss to ignition on 2000 Tundra.
Check the connections on the battery,It sounds like one or both may be loose.
Jun 02, 2009 | 2000 Toyota Tundra
Big Screen problem
What did you put in. convergence amp or convergence power. this is a rca hd52w59? i always ask the question in customer menu under setup can you see the option of convergence. if not this is the fl231 fuse problem. consult the article fl231 under tips and tricks section of my profile. the curved picture is an indication complete loss of convergence power. there is a board that does provide convergece power. The convergence on this set is controled by three diffrent boards. power,amp and the small signal board. the small signal board is the most expensive and most complicated to replace ussally a tech has to replace that.
Nov 08, 2008 | RCA HD52W59 HDTV Projection Television
RCA P56812BL big screen porblems
this is a complete loss of convergence. FIrst question do you have the convegence option under setup in customer menu... if you dont then it might be the fl231 fuse problem common with these sets. if you do then try autoconvergence... if fails then you probally have a bad convergence power board. there are three diffrent boards that can affect convergence. convergence power, convergence amp, and small signal board..
Nov 07, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Double vision tv
MY TV WON'T COME ON? MY POWER SURGE WORKING IS WORKING.
Jun 17, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
My RCA Tv has a concave picture!!!
Convergence problems. FIrst try going into customer setup and seeing if convergence options are there and if adjustments can be made. unfortunately when the picture is bowed like that it idicates a complete loss of convergence which idicates one of three boards have gone bad.
Dec 21, 2007 | RCA HD52W56 52" Rear Projection HDTV
Philips Magnavox 51MP392H Rear Projection TV
A sign that amps are going bad, right now you can check resistors in convergence board alongside the amps, check resistance to see if right.
Oct 08, 2007 | Philips Magnavox 51MP392H Rear Projection...
RCA P46159 Convergence
Why would the set go out of adjustments? I highly doubt if the set needs only alignment. These adjustments are for small drifts only. If anything is way out more then what the on screen can adjust, you have a problem with the convergence correction circuit. There is a convergence power supply in this set that goes bad a lot in these TV sets. There is also a convergence driver board. These RCA sets do not have the integrated IC's like most sets do. Each convergence yoke, horizontal as well as the vertical, has two independent power amp circuits driving them. And that's for all there tubes. So there are 6 separate amps controlling the convergence in these TV sets. You really should call in an RCA authorized repair shop to assist you in this repair. Good Luck
Oct 01, 2007 | Televison & Video
No pic no sound
sounds like convergence drive ics or power supply.would be about $350.00 +++ for these type of repairs
Sep 07, 2007 | Toshiba 42H82 42" Rear Projection...
Kp-46wt510 rear projector from sept. 2003
You have a failure in the convergence circuit. There's a circuit board ( the convergence board) which has 3 IC'c on it that drive yokes on each of the picture tubes red-green- blue. You probably lost power to these IC's or one or more may have opened up. Sometimes poor solder joints on these IC's will develop causing loss of convergence. Hope this gives you an idea as to where you problem is. Stargazer
May 26, 2007 | Sony KV-27V22 TV
Open Questions:
Samsung PCN5425R 54" Rear Projection Television Logo
81 people viewed this question
Jerry Greenberg
Jerry Greenberg
Demonic-2011
Demonic-2011
