Question about Miele CVA610
Steamer backed up water pours out under machine
I bought a house with a CVA610.  After cleaning out the gunked up steamer assembly, I get a little steam, but water comes pouring out from under the machine.  Is there a broken seal, or is the steam pipe just too clogged?  What should  do?
  • wynman May 18, 2009
    I have the same problem and finally took the top off the machine. There are many ring seals inside connnecting all kinds of hoses. One of them was leaking but cannot seem to find a plce to order replacements and Miele is outrageous in pricing them ($30 for two little O rings etc) I would like to know a source for these
    Scholar:
  • 58 Answers
On the cva 610 and 615 the steamer valve gasket tends to wear. Causing the unit to leak. Your best bet it to remove the steamer valve, Looking at the knob stem there is a plastic pin you can press to remove the stem from the valve. Once removed there's a small o-ring on the stem. ( That's where it's leaking from ) replace the o-ring and the stem to be safe. Also take a look at the micro sw to make sure it doen't have any corrosion if so replace it. If not your on the road to recovery. Good luck
Posted on Jan 07, 2009
Tip
Problem: No water flow; Solution: Unclog a small orifice in the flow meter
My 5 year-old Syncrony Logic stopped working for the first time today. The water would not flow, not through the steamer, not through the brew group. I had previously thoroughly cleaned the brew group screens, steamer wand, water dispenser filter, etc. Still no water flow. I could hear the pump working but no flow.
I only use distilled water in the unit, so I've never had a scale problem (distilled water has no minerals, thus nothing to create scale). After downloading a parts schematic from here, I dug into the case. By the way, I suggest you don't proceed unless you have at least some mechanical ability and are not afraid to break something in the process. Be sure to unplug from the wall first, unless you really like electricity A LOT.
After removing the drip tray, grinds bin, water tub, and coffee hopper, I removed the gray top. To do this: from the top remove 2 screws under the water tub, 2 screw under the coffee hopper. And from below the control panel: 4 screws from the under-side along the front and behind the brew group cover. Once the screws are out lift the cover at the back and pivot off the front.
2 things are attached to this cover: the power switch and water hose. The power switch easily slides off the top cover. The water hose runs from the water dispenser fitting and into a little white gizmo with another hose running out of it and into the pump. The little gizmo is a flow meter that ensures water is flowing. Remove the hose from the tank and flow meter in order to clean it.
The top of this flow meter easily comes off by slightly twisting the top counter-clockwise about 10 degrees, lining up 3 tabs with slots and lifting it off. Its a little snug coming off due to an o-ring seal. You'll see the little turbine wheel inside. In the top is the input and output ports in the flow meter turbine chamber.
The input opening into the flow meter turbine is TINY. It was clogged with a bit of gooey fluff. I poked it out with a small pipe-cleaner, then made sure the hose from the tank was clean, and the opening into the turbine was gunk-free.
After I put it all back together it ran like a champ again. I love this espresso maker. First problem in 5 years of flawless operation.
Bill
on Jun 06, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Tip
The above directions worked perfectly on my Kenmore Elite HE3. To minimize...
I CAME TO THE SITE WITH THE PROBLEM OF MY WASHER NOT DRAINING. I HAVE HAD PROBLEMS WITH THIS FOR MONTHS. TAKING THE HOSES OFF. CLEANING THEM ETC... TODAY I FOUND THE BEST SOLUTION.. THE WOMAN WHO POSTED THAT SHE SAVED HER HUSBAND $300.00 BY TAKING THE BOTTOM OFF WASHER WAS RIGHT.....
BOTTOM OF FRONT LOADER.. THERE ARE THREE SCREWS.. YOU NEED ONE OF THOSE NOT PHILLIPS BUT ROUND LOOKING SCREW DRIVERS(SORRY).. ANYWAY TAKE OFF THREE SCREW.. ONE ON LEFT, RIGHT AND MIDDLE.. THERE IS A WHITE DRAIN HOSE WITH A CAP.. VERY HEAVY PLASTIC FRONT. IT IS HARD TO TWIST OFF CAP BUT KEEP TRYING. ANYWAY IT IS GONNA GET REALLY WET.. SOME WATER CAME OUT AT FIRST BUT I WAS NOT CONVINCED.. SO UNDRNEATH I STARTED TO SQUEEZE THE HOSE AND OUT POPPED 3 SOCKS AND AN ERASER.. THEN ALL THE WATER THAT WAS IN THE WASHER THAT WOULDNT DRAIN.. EVERYTHING WAS SOAKED INCLUDING ME AND MY SON SO BE READY WITH LOTS OF TOWELS. BUT IT WORKED. IM HAPPY TO SAY IM DOING MY FIRST LOAD NOW AND EVERYTHING IS RUNNING BEAUTIFUL...
on Jan 27, 2009 | Kenmore Elite 45986 Front Load Washer
I have a Tobi steamer, The steam is not coming out like it should how to I unclog the hose? I do know its the hose. Thank you
My wife has thrashed hers in her shop and it suddenly stopped steaming. It was about two years old. I managed to fix it. I dont think that the hose or the nozzel will be blocked because they are too wide a diameter. There will probably be a build up of silica or calicum inside. Unscrew the hose where it meets the machine. Remove the blue water tank. If you pour some water down the pipe from the end that you just unscrewed the hose , the water should well up in the depression where the tank sits through the little holes at the bottom. If it doesnt then the blockage is inside which is what I found. I used some decalcification liquid product ICL and poured it in from the hose end and let it soak for 10 minutes. Then I got a thin plastic tube to go in and scrape around as far as you can from the hose end. A thin bottle brush or pipe cleaner would be good. I then used a thin piece of wire to poke around the slits in the other end( depression) Then I emptied it out and continually flushed it through with water and give it a good shake holding your hand over the hose end connection hole. I found that when I emptied the water out , it contained all this silica and residue. I would have got about a teaspoon full in total. After several goes the blockage suddenly cleared itself and I found that suddenly the water was running through freely and welling up as described. I kept doing this until the gritty residue dissipated. You can hold the hose end under the tap and tilt the machine so that the water runs freely out through the depression well. I reassembled it and tried it out. Bingo just like new. Hope this helps. - Grant
Sep 30, 2009 | Irons
No steam pressure with little to no water/steam
Remove the steam wand and inside you will find a small teflon like tube at the top, throw that away and run water through the wand to make sure it is clear then re-assemble in machine and test.
Jul 26, 2009 | Gaggia Syncrony Logic 74884 Espresso...
LG WM2016CW won't drain
The impeller may have come off the pump motor shaft. Generally, you will notice a louder sound when the pump runs if this happened.
Unplug the machine. Remove the filter recess by removing the one screw inside and using a putty knife at the left and / or right edge and popping it out. Pull the machine out about 18 inches and tip it back, resting it against the wall. Remove two more screws behind where the recess was holding the pump housing on. Reach under the machine and remove pump. There is a tab to depress under the pump housing to release it from the base. The pump motor is held onto the housing by three screws. Remove them and inspect the impeller to see if it has come off the shaft. If it has, pushing it back on will not solve the problem, as it will come off again. Install new pump motor and reassemble. Clean washer tub with the longest, hottest cycle and three Ah-fresh tablets, Whirlaway hot tub cleaner, Smellywasher cleaner (smellywashercleaner.com) or Tide washer cleaner. Repeat. From now on, use only 1 tablespoon of HE laundry detergent per load (1/2 T if 2X concentrate) and only 1 teaspoon of fabric softener per load if you use it. (these machines use very little water, and thus require reduced amounts of additives to work properly)
Feb 08, 2009 | LG WM-2277HW Front Load Washer
Francis francis x1, blocked steamer
Pour in a solution of 50% distilled white vinegar and 50 % water. Set the steam wand knob to a water setting, and run the solution through there. I would suggest letting a small amount of the vinegar/water solution drip out, then cut the machine off for about 20 minutes - allowing the vinegar to thoroughly soak and decalcify the insides. After 20 minutes, let the remaining vinegar/water pour through.
If the problem persists, Francis Franic is now owned by illy - 1-877-469-4559
-Tha Mp3 doctor
Oct 05, 2008 | FrancisFrancis! X1 Espresso Machine
Water hissing at back of brew unit after coffee made
I think you have to replace the steam valve.
Have you descale your machine regulary?
How old is your machine?
Maybe your boiler have to be replaced:-(
Jul 25, 2008 | Saeco Incanto Classic Espresso Machine
Steam frother
1. Pour in vinegar instead of water. 2. Bring vinegar to a boil but do not run it through the machine. 3. Turn off machine for the machine for an hour. 4. Remove sheath from the steamer. 5. Place tip of steamer into large mug of cold water. 6. Turn espresso machine on and allow vinegar to run through steamer.
Optional: Before starting the process, unbend a paperclip or metal hook (for hanging holiday ornaments) and use it to clear the steamer orifice.
It may take the vinegar a little while to dissolve and loosen the blockage. If the process does not work the first time time, try again later and allow the warm vinegar to sit in the machine longer.
Jun 19, 2008 | Krups Allegro FND111 Espresso & Coffee...
Miele coffee system and dishwasher
When it came out it retailed for 2,500$
Jun 03, 2008 | Miele CVA610
Miele CVA610 Logo
452 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
just-ice
Michael Galve
Michael Galve
Colin Stickland
Colin Stickland
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
