Question about Ricoh Aficio 1515 Black and White Copier
Double sided is no longer an option with mac os 10.5.4
I have a new computer with mac os 10.5.4. Previously I was able to print double sided but now the button to choose double sided is disabled. I've gone to the ricoh website and downloaded the latest driver but still nothing.
  • linda487 Jan 02, 2009
    I went to the Ricoh site and downloaded the driver for Mac OS X v10.5 or later which calls it a PPD Installer Ver.1.0.0a
  • Tim Babcock
    Tim Babcock May 11, 2010
    Which drivers are you using for the copier? Are they PCL or Postscript?
  • Ricoh Master
  • 2,794 Answers
Go into the advanced settings of the driver and look for the settings that tell the copier what features you have. Make sure the duplex is turned on. Normally I set these up for Windows use and I have one client who uses a Mac and he did show me that the features do exist for the print driver.
Once it is enabled the double sided printer feature should work.
Posted on Jan 02, 2009
Duplex printing in HP 2420dn on Mac OS X Lion 10.7.4
According to the specs, this printer does not have a duplex unit and therefore cannot print double sided prints.
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printercannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.
I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
Jul 17, 2012 | HP LaserJet 2420 Printer
I have a new mac 2.3 GHz intel Core i5. I have Print Shop ProPublisher version 11 for my old mac. But on my new mac it says it won't work because its not Power PC supported. What do I have to do to get...
I can only assume that either 1) your old mac was built before 2006 when apple stopped shipping powerpc based processors or b) your old mac was running on Snow Leopard or an earlier release of OS X that had the capability of running Power PC programs in an interpreter. From OS X Lion upwards Power PC is no longer supported. Your version looks to be so down level that it is unlikely there will not be an upgrade path. I think you will have to buy a replacement such as iStudio or http://www.broderbund.com/p-846-the-print-shop-mac.aspx.
Dec 29, 2017 | Broderbund Print Shop Pro Publisher 11
How to connect iomega ego blackbelt 3.0 to mack and change the partition
Mac decided not to go with USB 3.0 so you will have to use the USB 2.0 Y cable.
Using the USB Y cable. Plug the cable into the device first, then make sure to plug both USB's in to the computer starting with the short side USB then the longer side USB second. Also try using the USB's on the back side of the computer.
Formatting with Mac OS X, version 10.5 or above. 1. Make sure you have copied any needed files to another location. 2. Select Applications > Utilities > Disk Utility 3. In the left hand column, click on the drive icon for the Iomega Hard Drive. Make sure you click on the high level icon, not the second level volume icon. 4. Select the Partition tab. 5. Change Volume Scheme from Current to 1 Partition. 6. Select the format type from the Format drop-down menu. Select Mac OS Extended (Journaled) (recommended) or Mac OS Extended. 7. Click on the Options button. 8. Select the type of partition you want to use: GUID Partition Table - for boot ability on Intel-based Macs Apple Partition Map - for boot ability on PowerPC-based Macs Master Boot Record - if you will use the drive on a PC as well as your Mac. Use this option ONLY if you selected PC-DOS as the format type. CAUTION! In most cases, the computer will fail to format the drive as a Mac OS Extended (HFS+) partition using Master Boot Record. For best results, always choose GUID Partition Table (Intel) or Apple Partition Map (PowerPC). 9. Click OK. 10. Click Apply (10.5-10.6) or Partition (10.4). The drive is ready to use when the format completes.
Nov 28, 2010 | Iomega 500GB eGo BlackBelt Portable 34621...
Double Sided printing of PDF files
you have to set the printer properties to do double sided printting
Sep 11, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
I am unable to print double-sided. the option is available in 'print options' but i cannot select it. (im using Mac OS X 10.5) thanks!
If the printer is DUPLEX it can turn the paper and do the whole magic automatically. You probably DON'T have a duplex attachment so you'll have to manually have to turn the paper after its printed. When you print, select the option to print only even pages, print, put the printed paper back in and print the odd pages. You may have to try it a couple times before you get it right.... Good luck.
Aug 04, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Mac will not add printer
Hi, try to reset the print system as the apple article below:
SummaryWith Mac OS X 10.4, 10.5 or later, Printer Setup Utility includes a Reset Printing System feature, a troubleshooting function that you might want to use after you try all other printing troubleshooting stepsImportant: This feature should only be used as a "last resort" for troubleshooting a printing issue.
Products AffectedMac OS Printing/Fax (any version)
What does Reset Printing System do?
  • Deletes all printer queues and jobs.
  • Resets all printer settings to their default by deleting configuration files.
  • Performs a permissions check on the /tmp directory.
Any devices that previously appeared in your Printer List and Fax List will need to be added again after resetting the printing system.
Resetting the printing system in Mac OS X 10.5.x
  1. To use the Reset Printing System feature in Mac OS X 10.5.x, follow these steps:
  2. Choose System Preferences from the Apple menu.
  3. Choose Print & Fax from the View menu.
  4. Control-click on list of printers on the left side of the window, then choose "Reset printing system" from the contextual menu. If you don't see a list of printers, Control-click on the text "Click + to add a printer or fax" and select "Reset printing system..."
    As an alternative, if you currently have one or more printers listed, you can Option-click the "-" (Remove printer) button.
Resetting the printing system in Mac OS X 10.4.xTo use the Reset Printing System feature in Mac OS X 10.4.x, follow these steps:
  1. In the Finder, choose Utilities from the Go menu.
  2. Open Printer Setup Utility.
  3. From the Printer Setup Utility menu, choose Reset Printing System.
  4. Click Reset.
Additional InformationTip: If Printer Setup Utility won't open at all (possibly due to your printing issue), you can try to access the Reset Printing System feature directly by holding down the Option key while opening Printer Setup Utility.
Mar 14, 2009 | Apple Computers & Internet
Difficulty with double sided printing
Sounds like you need updated drivers for your new printer. Try a google search or go to epson.
Nov 06, 2008 | Epson Stylus CX6600 All-In-One InkJet...
EPSON 1800 PROBLEMS WITH NEW IMAC
While you may have installed it, the generic driver may be selected. Here are all the steps to get you back up.
To remove any previous Epson printer driver files and get a good working install of the latest download for the Intel Duo Core, do the following:
REMOVE FILES
1. Double click on the MAC HARD DRIVE.
2. Double click on the LIBRARY folder.
3. Double click on the PRINTERS folder.
4. Drag the EPSON folder to the trash can.
5. Close any open windows.
6. Double click on the MAC HARD DRIVE.
7. Double click on the LIBRARY folder.
8. Double click on the RECEIPTS folder.
9. Delete any "Epson" receipts. Close back to desktop.
10. Open the OS X "Printer Setup Utility".
11. Select the "Printer Setup Utility" menu at the top of your screen and click "Reset Printing System...". Confirm resetting.
12. Close all open windows and restart your computer.
DOWNLOAD
If you have not done so already, use the following steps to obtain the download for the new Intel Duo Core driver:
1. Go to http://support.epson.com
2. Select Printers then Inkjet then your printer model.
3. Under "Drivers and Downloads" select Macintosh.
4. Download only the driver marked for the Intel Duo Core system.
Printer Driver v3.0aAs
Intel-based Macs with OS X (v10.4.4 or later)
epson11769.dmg - 12.4MB - posted on 02/06/06
Installation instructions:
1. Double-click on the "epson11769.dmg" file and follow prompts to create an "epson11769_r1800_printer_driver_30aas" disk image on your desktop.
2. Open the disk image. Double-click the "SPR1800Series 30a" installer icon to begin the installation.
3. Follow prompts to complete installation. Restart Mac once the install is complete.
Do the following to add the printer once the new downloadable Intel Duo Core driver has been downloaded and installed properly:
1. Connect printer.
3. Click ADD.
4. Ensure you are on the Default Browser window.
5. Highlight printer as it appears under Printer Name.
6. For "Print Using" select "Epson Stylus R1800" if this automatically appears on the list. If this does not appear, select OTHER (not "Epson" - which links you to GIMP drivers, which we don't recommend or support). NOTE: if you are using a firewire connection, the printer name may appear as a letter only - ie "E" for "Epson". This is normal.
7. A new window opens where you can Browse to the hard drive location of:
HD > Library > Printers > Epson > Inkjet Printers
(This location contains all the Intel Duo Core Epson driver plugins, be they resident or downloaded.)
8. Highlight/Select the plugin for your printer model in the Inkjet Printers folder, then click OPEN.
9. Use the up/down arrows at the end of "Print Using" again to (re)select the printer's name, which will now appear at the TOP of the "Print Using" list.
10. Click ADD. The new downloaded driver will now be added on the list.
11. If there are other printers on the list, ensure the Epson is made default before testing.
When you are working with a printer model which supports borderless and/or roll paper printing options, you will be able to select these options in the program you are printing from as you set up your print job.
1. Once you have an image or file open, go to File > Page Setup.
2. For "Format For" select the Epson printer name (rather than "Any Printer").
3. Select the appropriate Paper Size. If your printer supports different layout features, each paper size will have several different options. For example, the 4x6 paper size will have an arrow pointing right which offers choices of 4x6 Borderless, 4x6 Standard-Minimize Margins, etc. Pick the paper type plus layout/margin option you want to use here.
4. Click OK on Page Setup. You are now ready to print.
Aug 17, 2008 | Epson Stylus Photo R1800 InkJet Printer
Setting HP OfficeJet 4315 print preferences on a MAC OS X
Whenever you send a file to print from a program a small window shows up. If it shows only
Printer: Drop down menu ARROW Presets: Drop down menu Some buttons at the bottom
then click on the ARROW pointing down for more options. That will show more info, including a drop down menu that will allow you to change page settings, printing settings, etc. For example, if you want to change the printing quality, select "Paper Type/Quality" from that drop down menu and new options will show up allowing you to change the settings of the printer.
Jan 10, 2008 | HP OfficeJet 4315 All-In-One InkJet...
Ricoh Aficio 1515 Black and White Copier Logo
472 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
