Question about Pioneer AVIC-N3 GPS Receiver
Screen is not opening ?
This radio is about a year old and the screen is not opening. It happen before but open after while. Anybody with this same type of problem. I don't open the screen as much only when I used the GPS and for a movie.
0 characters
1 Points
Gps screen not working
Hi your problem can be caused by any fuse that supplements the power to screen check voltages that feed the screen.
also can be your back light is working a way to prove your back light is , turning on the radio in a dark place and bring a flashlight and tries to see something on the display if something is provably which is only your back light and if it is not that the new screen does not works
Another reason could be that the flex cable that you are using that was connected to your old screen and this defective, also check the connection of the flex cable on the screen may be that in the process of Assembly is disconnected.
Jan 13, 2014 | GPS Devices
My Nextar Q3 is a few years old and when I was trying to charge the battery while in my car the screen went blank and stopped giving directions. I tried restarting the unit but the screen went on briefly...
you need to open it and check the wires behind the power board sometimes those wires get loose from the solder weld the battery its ok if you have it connected to your car lighter, I had that happen to me so I opened it and found broken solder welds at the end of those wires, it is a very delicate work to get to it but I think that's what it is.
Sep 30, 2010 | Nextar Q3 GPS Receiver
My Garmin 296 beeps when the power button is turned on, momentarily the login screen flashes on with no backlight then fades away in about 1 second. Nothing appears on the screen and the unit behaves as...
If you have tried the master reset to no avail I recommend that you send your GPS in for repair. Once you open it yourself, the warranty is null and void. If it is under one year old, it is under a full warranty. If it is over a year old, Garmin will repair it for a flat rate of $296. You will have to decide whether repair or replace is the best option for you. That said, here is the link to their repair site
Nov 20, 2009 | Garmin StreetPilot c340 GPS Receiver
I want to replace the LCD and digitser screen in my Garmin 250 GPS but cannot see how to get it open. Can anybody help please
should have two hidden screws under the serial tag on the bottom. there carefully pry the two halves apart with something like a piece of plastic so as not to damage the case.
Nov 09, 2009 | Garmin nuvi 250 GPS Receiver
Does anyone know how to change a cracked screen on a tom tom 300 please, i have managed to open it up but can't get to the screen cable to take the old screen out.
The solution to this is quite simple. Buy a new Tom Tom.
The Tom Tom units are not serviceable items. It's silly and quite honestly inexperienced of you to think they are.
If it's still under warrenty, MAYBE Tom Tom would replace the unit free of charge . But don't hold your breath. As a cracked screen wouldn't be under the fair wear and tear usage policy. So I'm afraid it's a case of dusting those cobwebs out of your wallet.
The strange thing about your question is why open up the tom tom in the first place ?
You can't possibly have a replacement screen!
Your either 11 years old or a very strange person.
Apr 01, 2009 | Tomtom GO 300 GPS Receiver
When antenna is open screen starts flipping out of control
Mar 20, 2009 | Garmin iQue 3600 GPS Receiver
Touch screen failure
Sometimes it pays to procrastinate. My 250c gps was left in a drawer for a year and a half as I hesitated to pitch it. I turned it on recently and everything works good as new. The battery was still fully charged! It must have dried out over time.
Oct 03, 2008 | Lowrance iWAY 250C GPS Receiver
Etrex will not turn on
If batteries were ever put in backwards, you cooked it.
Feb 11, 2008 | Garmin eTrex Legend GPS Receiver
Quest GPS stopped turn on after 4 years of perfect working
Vladimer's solution worked for me too. Hooray! Many thanks!
Jan 06, 2008 | Garmin Quest GPS Receiver
Pioneer AVIC-N3 GPS Receiver Logo
35 people viewed this question
Top Pioneer GPS Devices Experts
Richard Roth
Richard Roth
David Burbee
David Burbee
Are you a Pioneer GPS Device Expert? Answer questions, earn points and help others
