Question about Samsung 26.0 Cu. Ft. Side-by-Side Refrigerator, RS265LABP
Fridge temp display flashing
Cleared out the ice from around the fan on fridge side of my samsung side by side but now the temp display is flashing on fridge side
  • sredfls Dec 29, 2008
    evap fan is running current temp is now 12oc had it a year only happened today
Is the evap fan running? What is the current temp and how long has the unit been in operation
Posted on Dec 29, 2008
  • Phyx C
    Phyx C Dec 29, 2008
    Please send mod # and serial #. I think I can solve this. For now disconnect power for 30 sec. Plug the unit back in,
Samsung rs21 fridge temp keeps flashing
It's a defrost sensors issue. You need to replace the evaporator assembly it will come with all the sensors you need.
Jul 24, 2013 | Refrigerators
Electrolux Icon side-by-side E23CS75DSS - repair man replaced the defrost thermostat and now the digital temp display flashes. The freezer temp display flashes "E" and the fridge display flashes...
Sounds like you have a evaporator fan motor. That is what the error code you have indicates, the fan blade could be stalled to.
I work on these units every day and know them very well, I can walk you through any repair on this refrigerator.
http://www.appliancerepairlesson.com/
Mar 01, 2011 | Electrolux 25.9 Cu. Ft. Side-by-Side...
RS267lash samsung refrig. display panel fridge
Sounds like the fan unit is faouling with ice. The solution is to remove the whole of the contents and then the units inside at the rear. Defrost same and re assemble. Its not that hard if you remove the light difuser first and the two screws. Mark the difuser for top. Then ease out the unit and remove after taking out the electrical connections. They fit only one way. The lower unit has four screws. Two under covers. Easy to unclip. The ice seal may mean that it is not that easy to remove. Defrost both the units with a hairdryer or similar and clear insulation from the fan drain. Re assemble when clear and as dry as you can. The problem will come back so be aware that you have to repeat the procedure when the fan gives signs of fouling. Paul.
Jul 11, 2010 | Samsung 26.1 Cu. Ft. Side-by-Side...
Fan hits shroud. when I open the freezer door it stops.
most units are set so the fan will turn off when door is opened clear ice , readjust or repair fan a slow fan or stopped fan will affect the temp in the fridge section
Nov 25, 2009 | Samsung RS2630WW Side by Side Refrigerator
Samsung side by side fridge/ freezer model number RS21NGRS . Fridge side is not cooling . The fan was making a noise and has now stopped but the temp light is flashing how do i sort this problem thans.
Hi, there is a known fault with the Samsung RS21 units. If you unit is less than 5 years in luck, it is covered by the Extended warranty they have put in place. Apparantly this was featured on BBC watchdog!. i've had the same problem and had it fixed free of charge by Samung. Either raise a service request on the Samsung uk web site, www.samung.com/uk or call the customer services on 0845 7267864 and explain you description. the noise is an ice build up which stops the internal fan pushing cold air around the fridge. the bootom of the fridge , in the drawers is cold?
Aug 12, 2009 | Refrigerators
Freezer and ice maker quit working / The temp.display on the door is just flashing .
There may be a fan that moves cold air in the freezer and icemaker compartment(s).  If the fan freezes up the cold air will not circulate.  Since the fridge compartment is still cold it does not sound like a compressor problem.
Jun 02, 2009 | Refrigerators
Samsung rs2533sw fridge not cooling
soiunds like the coil on the refrigerator side is iced up.take and open the refrfigerator side and take a blow drier and after removing the 11 screws use the hair drier to slowly melt the icec behind the cover. If you pull too hard and or too soon you'll break the stryofoam ductin that has to be around the coil. then make sure that the drain line is clear reassemble and have a Merry Christmas!
Dec 01, 2008 | Samsung 26.0 Cu. Ft. Side-by-Side...
I have a Samsung American style side by side fridge freezer - not plumbed in at present. The freezer works ok but the fridge ices up in the bottom half and the overall temperature will not drop on the...
these samsung are liable to ice forming around the fan and jamming it.
take the backplate off inside the fridge and melt the ice off with a hairdryer. make sure the fan rotates freely as well.
if memory serves me right, samsung did a mod to prevent this
Oct 20, 2008 | Samsung Refrigerators
My fridge won't keep temp..
most samsung have a fan in the fridge and an evaporator. take off the back plate of the fridge and melt off and excess ice especially round the fan.; if it keeps happening then you have a fault in the defrost system
May 21, 2007 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
567 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
