Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Dryer Mosel #MDE6700AZW
There is a piece of fabric insulation that goes around the drum on the front side of my dryer that has come loose . I have tried to reinsert it but it keeps on coming back out.Please let me know how this can be fixed
Thanks,
B
    Habit-Forming:
  • 36 Answers
You will need to remove the front panel and the front bulk head. after that you will see that there are clips that need to be pushed down to hold the fabric (felt) down. You need to make sure that the felt isn't torn. If it isn't torn then all you need to do is take a flat head screw driver pry the clips up and put the felt back on and push the clips back down
Posted on Jan 02, 2009
  • scrappika603
    scrappika603 Dec 11, 2013
    What do you do if it is torn?
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
Repair loose tumbler fin
Pop the top, remove the front, the drum will come free. Take pictures of how the belt goes around the motor. Fix your "fin" and reverse.
The top is held down by spring clips.
Thanks for your interest in FixYa.com
a
Dec 12, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
What is the correct belt routing for a maytag MDE6000AYW dryer and should the groove side or smooth side be on the drum? Thanks. dave
groove down. around the drum. near the motor you will find a tensioner. Through the tensioner then around the pulley on the motor. Have your assistnnt hold the drum up while you get up and prepare to put the front back on. You know the rest.
They call it a tensioner for good reason ... you may want to lift it using the length of a screw driver against the floor of the machine.
Watch your fingers.
If you are happy with this answer, please leave positive comments
thanks
a
Oct 14, 2009 | Maytag MDE6000 Dryer
Felt insulation around drum is loose?
This is not a serious problem, but it should be fixed. It probably just came unglued and can be reattached.
Charlie
Aug 17, 2009 | Maytag Dryers
Inside of drum baffles coming loose on maytag neptune dryer
Hello.
Remove the door and the plastic pieces on the opposite side. Take the front panel off. There will be one metal bracket on each side holding the top panel down. Remove those brackets and lift the top. Turn the drum where the loose baffle is up top and tighten loose screws or replace missing ones.
Jul 18, 2009 | Dryers
Scraping sound on left side as it goes around
You need to replace the tumbler guide rubber wheel. I would suggest to avoid further issues, replace all base guides.
It requires dismantling the Dryer.
e
Dec 17, 2008 | Maytag Atlantis MDE6400AY Electric Dryer
Put dryer belt on maytag dryer
generic maytag dryer belt replacement
type 1:older models by Maytag with lintscreen under door
  • unplug dryer
  • remove 2 screws from under front panel
  • tilt front panel up from the bottom and unclip top
  • remove door switch wires
  • set front panel aside
  • remove front drum retainer 2 screws each side
type 2:newer models by whirlpool lint screen in top cover
  • unplug dryer
  • remove lint screen
  • remove 2 screws under lint screen
  • with putty knife or other blunt blade
    unclip spring clips at front corners of top panel
  • remove 1 screw each side of front panel 1/2 way from top
  • remopve door switch wires
  • tilt front panel down and unclip
all
  • withdraw drum forward
  • examine drum rollers for wear
    if worn or locked replace in pairs
  • examine felts and nylon glides(if fitted) for wear
    if worn replace
  • examin case floor for tensioner
    (sometimes broken belt ends pull the tensioner out of place its easy to see the slots on the case floor for the 2 feet and spring, looks like a power socket)
  • loop new belt around drum at wear mark of old belt
  • insert drum
  • loop belt around motor pulley
  • pull tensioner to end of travel against spring
  • loop belt around tensioner
  • relax tensioner
  • rotate drum by hand to make sure belt wont jump off
reassemble in reverse order
Oct 29, 2008 | Maytag Dryers
Maytag dryer making drum making a funny sound when it goes around and when i opened the front a small piece of cork was on the bottom
hi thanks for the question that small piece ov cork is part of the front bearing purchase the front bearing kit. not much $ to replace. tilt dryer towards the wall disconnect power sourc,e remove 2 screws on front panel .to remove the front bearing . 4 5/16 screws 2 each side remove keeping the drum steady you will see the worn part you must drill out or file down the rivets that hold the cork and teflon bearing . remove & replace .thanks the appliance doc
Sep 28, 2008 | Maytag Dryers
Frigidaire electric dryer; model # FDEB34RGS1
front drum seal needs replacing pop clips at front of dryer top ..lift top remove 1 secrew each side of front from the inside..remove wires lift panel off clips ckd front panel around door area for felt seal may also have embedded plastic drum glides a felt seal also goes around bottom half
May 05, 2008 | Frigidaire FGR341AC Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
383 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
