Question about Kenmore 3.8 cu. ft. HE3 Front Load Washer
Our Kenmore HE3 front loading dryer gives off a fuel smell inside
The clothes smell like fuel, the inside of the dryer smells like fuel, the
exhaust smells like fuel. The laundry room does not smell.I have had the
lower front panel off of the dryer and everything looks clean. I took the back
off of the dryer and the cover and cleaned any dust. I took the part off that takes the heat from the flame up into the dryer and there is nothing in it.
the vent from inside the dryer to outside of the house is clean. The flame
looks blue with a little bit of yellow in it. I do not know what the problem is.
When I had the back off of the dryer I did notice one thing that looked a little unusual. The vent
pipe, which the flame of the burner travels through, ( running from the burner to the back of the
dryer ) was painted, inside and out. Some of the paint was cracked and slightly bubbled, as though
it was melting from heat, and there actually was a small pile of soot laying there. I wiped off as much
of the paint as I could with a rag, and vacuumed it out, and put the dryer back together and ran it.
After running the dryer for a while we no longer have the smell. I don't really know if that was the problem
or not, but at least the smell is gone.
Posted on Dec 31, 2008
Dryer has a burning smell. repair man came and looked at it and said mechanically the dryer looked brand new (its only 11months old). He suggested we repair the exhaust tube and vent (which we did). ...
do you have pets ie a dog that moults, as quite often its is foung that pet hairs get inside on the elements and cause a burning smell. if so disconnect from supply. Remove back cover by removing screws and hoover the elements. Make sure electric is off hope this info is useful.
Dec 16, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Will you please replace my he3 washer? It smells,it molds,and stains my clothes.I am very disappointed in this machine.Maybe you could send someone out to my house so I can do their laundry and their...
if you haven't tried AFFRESH it works the best on this washer and after a few loads with Affresh in it it should smell fine but you will have to use a cleaner for now on
Sep 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Bad smell inside dryer
that's because it's brand new. See if it goes away in a month. After a load has dried leave the door open for a bit. What does it smell like?
Feb 27, 2009 | Kenmore Dryers
Clothes smell like gas
STOP USING THE DRYER AND CALL A QUALIFIED SERVICE PERSON TO TEST ALL GAS LINE CONNECTIONS WITHIN THE UNIT!
A gas leak can cause a fire in your home. Although, we have always used a gas dryer, and the clothes do have a fresher smell to them than an electric dryer. Any gas which may be in the area would be consumed when the gas flame was burning as normally the pilot remains lit throughout the drying cycle.
Jan 24, 2009 | Kenmore 43142 Front Load Washer
Dryer not heating he3 kenmore elite
repl/ thermal fuse if no heat if heating for a little while clean exhaust, and repl/ coils
Dec 20, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Burning smell
you can unplug the unit , and reomve the lower aces panel (3 screws along the front bottom of unit) youll probalby see an excess of lint built up in which case you can vacuum it out, and then check/clean and or replace your dryer vent
Nov 16, 2008 | Kenmore Elite HE4 Electric Dryer
HE3 DRYER
Clean all of the lint from the inside cabinet and duct work of your dryer. Then, try to clear the odor, by running a couple of loads of old rags or towels. Good luck!
Aug 14, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore 3.8 cu. ft. HE3 Front Load Washer Logo
201 people viewed this question
Sal De
fordexpert
Robert Rankin
