Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Can I use oven cleaner on the inside of the oven?
I have been given a used range that needs a good cleaning inside and out. I want to do this before it is installed later this week. Can I use oven cleaner on the inside of the oven? How about the range top?
    Genius:
  • 2,920 Answers
Yes to both you can but make sure when you wipe it out to get all the residue
Posted on Dec 29, 2008
My self cleaning oven will not lock, so I am assuming it is broken. My oven needs to be cleaned. Since you can not use an oven cleaner on it, what can I use to clean it?
HELLO,
Please carefully apply the below instruction to clean up your range
self cleaning solution
  • 1 Remove oven racks and soak them in soapy water
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on food.
  • Fast Cleaning method
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently. 6 Dry with a soft cloth
  • hope this solution help?
    thank you.
    Sep 20, 2010 | Hotpoint RB757 Electric Kitchen Range
    How do I clean oven
    Hi
    These are the things you will need to clean your oven.
    Oven Cleaner, Soft Rags, Sponges, Oven Cleaner and a Sponges.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7mMYimF
    Dry with a soft cloth.
    Thanks.
  • Step 4 Allow to sit for 10 minutes.
  • Step 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • Step 6 Dry with a soft cloth.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lkil29
  • Step 3 Turn the oven off and spray the inside with oven cleaner.
  • Read more: How to Clean an Oven | eHow.com http://www.ehow.com/how_2017_clean-oven.html#ixzz0v7lanRHk
    Jul 30, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    How/what can be used to clean range ''glass top'' can those green spunges be used/
    Oven cleaner, use EASY-OFF Fume Free Oven Cleaner, it is the best
    for cooked stains.
    You should not use anything but a soft cloth, and if you use the cleaner
    you won't need something abrasive.
    Once you put tiny scratches into the glass, it will be more difficult to clean.
    After you clean it with oven cleaner, rinse it with a warm wash cloth a few times, to make sure no cleaner is left behind, and read the directions.
    Feb 11, 2010 | Amana ARDS802 Electric Kitchen Range
    The inside of my self cleaning smooth top range
    Using any kind of cleaning solution can cause the self-clean catalytic coating to be damaged. The glass itself isn't sensitive but don't apply anything like oven cleaner or other caustic cleaner to any of the other surfaces unless your owner's guide specifically permits it. On the glass, I have on occasion used a new single-edge razor blade to remove any heavy, baked on splatters and then conventonal glass cleaner to finish.
    Sep 07, 2009 | Ovens
    Since we bought our Maytag Gemini 9 years ago, every time I use the oven cleaning function, I get an f9-4 error and cannot clean my oven. Is there anything I can do to bypass this? Its just too expensive...
    Oven Cleaner can be used instead of letting the ovens "Self Clean". This error report you are getting could be a couple of things, 1 the oven latching mechanism may have gone on the blink (this is the part that locks the door during the cleaning process to prevent any opening of the door during cleaning) 2 it could be that the oven will not reach the self cleaning temp. any longer (this temp is much higher than the hi broil) Good Luck
    Dave
    Aug 17, 2009 | Maytag MER6772 Gemini Electric Kitchen...
    WHITE FILM INSIDE OVEN
    your mom may have used a non-self cleaning cleaner to try and clean this oven in the past. you wont have much luck getting rid of the stain but using cleaners like easy-off or mr muscle may help you reduce the staining.
    it could also be that an element has shorted out and "burned" the surface of the oven. if the oven doesnt heat properly then check the elements for a rough or burnt out area. that does happen but its probably just going to be stained as it sounds like you have tried to do the cleaning.
    p.s. i like mr muscle better then easy-off.
    Jan 09, 2009 | Tappan TGF320 Gas Kitchen Range
    Stove cleaning
    The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
    Jul 05, 2008 | Kitchen Ranges
    Inside the oven door there are some stains from liquid spill that went through the vent, how can I clean it.
    If your oven is self-cleaning, consult the owner's manual for instructions on how to use this feature. The self-cleaning feature works by heating the interior of the oven to a temperature so hot that it incinerates the residue inside the oven. Normally, it is not a good idea to clean the interior of a self-cleaning oven with a spray cleaner; however, refer to your owner's manual or contact the manufacturer of your oven for further information.
    To clean a non-self-cleaning oven, use one of the many oven cleaners that are available at grocery and hardware stores.
    May 04, 2008 | Kitchen Ranges
    Hotpoint self-cleaning oven
      I believe they make an oven cleaner for self clean ovens.  Don't try regular oven cleaner.  Ruins finish.
    Oct 24, 2007 | Hotpoint RB757 Electric Kitchen Range
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    43 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
