Question about Dell Inspiron 1525 Notebook
Power shutoff When I'm in mail,power shuts off when I start to type an entry.
  • 3 more comments
  • rdem9744 Dec 29, 2008
    Yes, only in mail; dell could not or would not correct without charging me a fee.
    Was using Micro Mail, swithched to Outlook Express 2003, still shuts off. Using VISTA (just purchasred from Dell 10 days ago).
    how do i check the power settings and what is bios?? Thanks.
  • Dan rogers
    Dan rogers May 11, 2010
    What mail program do you use? also need to know your OS and what kind of confuser your on.
  • Dan rogers
    Does it only happen when you are in your mail program?
    Master:
  • 413 Answers
It seems kinda wierd that it just happens in mail but from what i can find it seems these computers have power issues and overheating issues. So the first thing to reccomend is that you try to keep the bottom of the computer up and off of anything so it won't get too hot. Also chek the power settings and if you can get to bios check and see if it has any warning systems or auto shutoff.
Posted on Dec 29, 2008
  • Dan rogers
    Dan rogers Dec 29, 2008
    The power setings are in the control panel in windows. To get there open the start menu and click on control panel. Upon some further research it won't be a problem in bios. Another thing to try is to update windows by going to this site= UPGRADES Beyond this it is a dell issue and might have something to do with their hardware and they will need to fix it
No water going to ice maker and water dispenser in the door. replaced the "dual water inlet valve" 2 weeks ago and thought the problem was solved. No problems until yesterday when the same thing start
If your water line to the refridge has a shutoff where it is connected into a house water line, this shutoff can become plugged up. A lot of them have a needle type shutoff that when screwed in shuts the water off. This is where the house line gets punctured. When screwed out this little hole can become plugged up.. Screw shutoff in and out a couple of times and if you can disconnect line from this shutoff. Then open the shutoff and see if you can get water out of it. This may allow you to flush the hole and debris out of the shutoff. Then reconnect line and see if this helps. If it happens again you may want to replace the shutoff valve with a new one.
Dec 12, 2014 | Maytag Refrigerators
I have a 12kw lp gas genwrator that starts and runs for about ten seconds and then shuts down.after maybe 25 tries doing this the generator will stay running and then i try and start it again and it will...
These type of gens have a low oil shutoff. Check the oil. Always have spare spark plugs, a cheap fix. My gen always wanted a new plug every year. Look to see if it has a fuel filter.
Sep 24, 2011 | Generac 13,000 Watt / 13,000 Watt Home...
Shutting off water valve problems
Some shutoff valves are pretty marginal to start with, then they corrode. They can easily break if you put too much force on the handle. You are wise to be cautious. You will have to turn of the main water supply and then replace the toilet shutoff valve. You might be able to replace the shutoff valve yourself, depending on your skills and depending on how the shutoff valve is connected to pipe coming out of the wall or floor. But keep in mind that if you get in over your head you will have no water in the house until you get that new shutoff valve in place.
If you can describe what kind of pipe that shutoff valve is connected to I can help you understand if you should tackle it yourself.
Jun 29, 2010 | Toto Elongated Washlet C100 Toilet Seat -...
After air compressor reach the max. pressure it starts losing air and now there is fluid in the gages. and when it tries to refill it shuts off
You may need to replace a leaking pressure-safety-valve. You may also need to drain water from the compressor tank (which should be a regular procedure). If the motor is a capacitor start type, the capacitor may have dried out and need replacement. If the capacitor becomes weak, the starting torque of the motor is reduced. If the motor just hums without starting, it builds up heat rapidly and a thermal shutoff switch removes power to the motor until it cools off. Hope this helps!
Jan 13, 2010 | Air Tools & Compressors
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
No instructions on programming auto shut-off time (feature listed on box).
You have to use the "Auto-Off" feature, which is located on the same button as on/off:
The automatic shutoff time (ASO) can be
programmed to shut off immediately after
brewing (0:00) or up to 4 hours later. The
default shutoff time is 2 hours.
Press and hold the On/Off button to display
current shutoff time. To change the preset
time, press and hold the On/Off button until
the red power light and LCD display begin to
flash. This signals that you have entered the
Set automatic shutoff mode. Set the time
you want coffee to begin brewing by
following the instructions in “Entering Time
Set Mode.”
When the coffeemaker shuts itself off, two
tones will sound.
NOTE: Automatic shutoff may be
programmed either before or during coffee
brewing. If you program the auto shutoff
time after brewing is completed the unit
will automatically account for elapsed time.
For example, if you set the auto shutoff for
40 minutes and 25 minutes have already
elapsed, the unit will shut off automatically
after 15 minutes (40 minutes minus the 25
elapsed equals 15 minutes).
-Tha Mp3 Doctor
Apr 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Losing power to fuel shutoff relay
The power for the shutoff relay actually comes from a secondary winding on the ignition coil itself. Why the enging would shut the fuel pump off is that as the engine ran for a while the coil gets warm and then breaks down or opens up the circuit for the fuel shutoff relay. Fixed by replacing $85.00 coil.
Feb 12, 2009 | 1988 Honda Accord 4 Door
How can I chat using Yahoo Mail?
Chat with Somebody in Yahoo! Mail To exchange instant messages with any Yahoo! Instant Messenger or Windows Live Messenger user in Yahoo! Mail:
  • Make sure you are singed in to chat.
    • If Offline appears after your user name right next to the Yahoo! Mail icon at the top, click Offline and choose Available, Busy or Invisible from the menu.
  • Press c (think chat).
    • You can also select Chat from the Compose drop-down menu — click the down arrow first.
  • Type the desired user's Yahoo! Messenger ID in the To: field.
  • Hit Enter.
  • Type away.
You can also start a chat by looking for an online contact first:
  • Click Online next to Contacts in the Yahoo! Mail folder list.
  • Now click on the desired contact's name or user name.
  • Start typing.
If you start composing an email in Yahoo! Mail and the prospective email recipient appears under Online, Chat now! in the To: field's auto-complete list, select the entry to convert your email to an instant message.
Nov 17, 2008 | Computers & Internet
Dell Inspiron 1525 Notebook Logo
Alun Cox
