Question about Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Burn resistor value needed
Emerson tv model no: ewc27t3 burn resistor in power supply the circuit board numbers are r2665 7, r2666 & r6667 .i would appreciate your help in solving this problem.
4 Suggested Answers
  • 277 Answers
SOURCE: emerson ewc0903
hi sorry only way for manual is through "sears" any way it looks like your battaries are dead! put new ones and see if it works good luck
Posted on Feb 26, 2006
SOURCE: Emerson EWC27T3 27 in. TV/VCR/DVD Combo
Well, the playing I don't understand. However, I have a few ideas as to what may be going on that'd cause your tv to not eject a dvd.
One thing that's crucial information is this; when you press the eject button, does it:
~Say it's ejecting on screen, but it's silent,
~Say it's ejecting on screen, but it's making a constant clicking sound,
~Do absolutely nothing.
If it does absolutely nothing, then there's a problem stemming from the button you're pressing to the chip that controls the door. There are at least 6 different components in between those two functions, so it's safe to say that you're pretty screwed.
If it says its ejecting on screen, and you either get total silence or a light clicking sound, the most common break-down I've found is within the DVD mechanism; there's a small series of white, plastic gears which runs the laser, the door, the tray, and the mechanism that raises and spins your DVD.
These gears are held in place by a protruding plastic rod held in place by a screw; this rod is actually part of the DVD's chasis itself. However, through the miracle of cheap out-sourcing, these components are mostly made from cheap, easily-breakable plastic. Over time, this is the most common section to break off, making the gear come loose, and fall out of place, ultimately rendering your player useless; this particular gear that seems to break all the time controls both the tray eject AND laser position.
Really, all you need to do is go to a fix-it shop, get some SUPER Super Glue, and glue it back on. Gotta be careful, though; make sure you only glued the peg, NOT the gear.... If you do that, you'll never get it spinning again!
If you feel you know what you're doing, go ahead and try it yourself. HOWEVER, EVEN WHEN A TV'S BEEN UNPLUGGED, THERE ARE CAPACITORS WHICH MAY STILL BE HOLDING ELECTRICITY. THIS IS ENOUGH TO SERIOUSLY INJURE/KILL YOU IF YOU'RE NOT CAREFUL!
Happy fixing!
PS: I'm 17, and I figured this problem out within 3 hours of the initial break. Good luck!
Posted on Jun 13, 2009
  • 88 Answers
SOURCE: I have an emerson EWC27T3 tv/vcr/dvd combo which I
Manual is here:
http://www.emersonaudiovideo.com/support/manuals.aspx
It lists where to obtain replacement accessories, such as a remote control.
Another possibility is:
http://www.remotecontrolwarehouse.com/EMERSON/EWC27T3.html
I have no affiliation or experience with either, but I hope these help.
Posted on Sep 13, 2009
Power supply
What is the brand name and model number to your TV? Provide more details please. To give you the proper value of that resistor, i must get its position or part number. for more information go to http://electronicshelponline.blogspot.com/. It has schematic diagrams to many popular TVs' power supply. Hopes, it might help you.
Nov 12, 2013 | Televison & Video
Power problems
Do you have the schematic for this TV?
Oct 29, 2008 | JVC AV-20420 20" TV
Sanyo crt tv model st-21cf1 all burned resistor....may i ask what is the value of resistors
To which section circuit you are referring here? Power supply regulator section? If you wish to get some information, check the link below. It has schematic diagrams to Power Supply Regulator sections to some popular brand TVs. http://electronicshelponline.blogspot.com/
My emerson tv keeps turning its self off after a few seconds
I do not have a model number to go with. But I would imagine this TV is still on the new side. If this is the case, the values on the starting resistors for the inverter board have changed values. You will need an inverter board replaced. Or if you know of an authorized Philips Center, they may replace the resistors with the same value or new values, depending on the model number of your TV. Thanks for asking and show a few hands of support!
Feb 28, 2011 | Emerson Televison & Video
Resistor burned on my Grandmother's Emerson model NR303TT
Hello Gio, Hi, a burned resistor is usually caused by a shorted part like a semiconductor or regulator, there are two things you should do, find the value of the resistor and what caused the resistor to burned, for the Resistor, the value is usually written on the board, If not you can find the value on schematics diagram (which is usually hard to find, but if you have one, fine), and on the same working model (very remote a possibility). IF this are not available, you now need the assistance of a technician.
Jan 26, 2011 | Emerson NR303TT CD Shelf System
Please help me about my power supply it is compaq (24 pins)model no. ps-7231-6cf..the resistor is burned..i dont know color code or the value number of my resistor..only i know is in the circuit of my...
sir
pls dont try it your self. you should better call a repairman for it. He will if possible repair it or you would have to buy a new one.
thankyou for using fixya
dont forget to rate the solution
Mar 09, 2009 | Computers & Internet
Magnavox 27" TV- Burned Capacitor
For a schematic diagram, contact Philips directly.
Oct 04, 2017 | Televison & Video
A chip on the circuit board started smoking
The component sounds like a resistor, and the fact that it was attached to a heat sink means its a power handling resistor. You said it was burning, so this means that whatever it is attached to is drawing too much current. From what you are saying a component on a board is drawing too much current and is causing another component (the 1 ohm resistor) to burn. My question is what board is this (I am suspecting the deflection or the HV power supply). Please post a picture of the board in question. That way I have a visual guide as to the board and if I can find the schematic, or if you can supply the schematic I'll be able to at least give a better diagnosis of this problem.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Dec 30, 2008 | Sony KP-61V90 61" Rear Projection...
Samsung projection tv convergence problem
I was just working on replacing my stk's and was wondering if you could tell me what value the resistors are? Here is my previous post if you would like to see it. http://www.fixya.com/support/t191186-blue_out
Sep 12, 2007 | Samsung HCL4715W 47" Rear Projection...
Emerson EWC27T3 27 in. TV/VCR/DVD Combo Logo
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
