We do not have wiring diagrams here at fixya due to copy right protected material. You can access it for a fee here
SOURCE: 2005 Chevy Cavalier Electric Window Wiring Diagram
Tom,
See this alot. Sorry,It appears that is a symptom of a bad motor. If it moves an inch or so,then nothing,after a few minutes another inch or so,it's motor time!
SOURCE: brake wiring diagram chevy lumina
why not just replace the turn signal switch must faster and safer . buy one from your local parts house then you can see its not that easy to install but you can do it with a little help
SOURCE: Lincoln Town Car 1999 driver side window switch
I have the same problem in my 2001 towncar. I removed the switch control panel (without removing the door panel) by prying up from the front of the panel. There's a spring loaded plug under the mirror adjustment. Once you get that pulled up, the whole unit will lift out. Since there's a two year difference in the models - it MAY not work... however, you might not have to remove the whole door panel as you think.
In my case, the wiring was bad.
SOURCE: power window switch is not working and i would
I found the answer here; it tells you exactly which wires to jump in order to get the driver's side window to raise:
http://cardealerforums.com/alt-autos-gm/t47387-1996-lumina-power-window-switch.html#post150470
Testimonial: "thank you"
