Question about Corstone Industries Home
A hot lid placed in sink caused small black out line about 1/2"
This is my 2nd corstone sink & great care is taken. Ahot lid was placed in sink; caused small out line about 1/2" long blackened. Can I fix this or cover it up with something. The damage is a very thin line. Will the sink polish help. lEmail: Susanlezak@bellsouth.net
  • 10,865 Answers
I would start with the corstone sink polish. It should remove the line. good luck
Posted on Jan 18, 2009
I inadvertently place a hot pot in my swan stone sink. I small portion melted the sink. Seems like a touch up paint would be the answer. Is there such a product?l
https://www.swanstone.com/index.php?page=faq
It can be sanded. That pot must have been really hot to cause damage. See if this link helps. Without seeing a pic I can't advise further. Good luck!
Aug 29, 2016 | Swanstone Home
My Sharp LCD tv has lines going from the sides to the middle. They started small and continue to grow...getting longer and wider.
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken Good luck in solving the problem and do take care in handling the set because it contains high voltages.
May 31, 2011 | Televison & Video
HOT AND COLD REVERSED MOEN & ONE HANDLE TUB
This is a very simple fix. NOTE: This is for a Posi-temp model only!! First turn off the house water. Relieve the water pressure at a nearby sink. Then remove the handle from the faucet. Remove the black plastic piece, then the two white plastic pieces (these control how hot the water gets by controlling how far the handle turns), then the metal cover over the center piece of the valve. Once these are out of the way, there is a small metal clip that you can see that holds the cartridge in place sitting in a **** on the top of the center piece. Remove this carefully with a small straight edge screwdriver, taking care not to lose it. Then with a small pair of pliers, pulling on the center of the cartridge, pull straight out. Once the cartridge is completely out, turn it counter clock wise, 180 degrees and then reverse the process. The hot/cold will be in proper location now.
Now for an older style, simply take the handle off, turn the center portion of the cartridge 180 degrees counter clock wise and return the handle. Hot/cold will now be in their proper locations.
Good luck.
Aug 26, 2010 | Moen & One Handle Tub & Shower Faucet
We have a single handle Moen kitchen faucet with the built in sprayer in the faucet. No hot water will come out and no water pressure in the hot position. Any ideas?
Check the cutoff valve under the sink to be sure it's fully on. If it is then the cartridge in the faucet may need to be cleaned or replaced.
May 24, 2010 | Moen 7437 Chateau Single Hole Kitchen...
When printing dark line down copy
A line down the copy can come from a dirty document scanner lens.
Usually white out or wet ink will smudge on the document scanner. Opening the document cover check the scanner for a dirty glass. Some document feeders have the white roller on top of the small glass window. They have delicate plastice retainers that hold the roller on both ends. Extra care needs to be taken if this roller is removed.
Clean the roller and the glass with wet towel. Shine a flashlight on the glass to see if there are anymore black marks on it.
Use the finger-nail to run across the glass and make sure no debris is on it. Even a spot can make a line on the copy.
Also, a bad fuser roll can cause a black line on the copy. A defective drum unit can cause a line on the copy as well.
If all else fails place a Xerox service call for this problem.
Oct 22, 2009 | Samsung Office Equipment & Supplies
We began replaceing our galvanized pipes. Since
The problem is that when you disturb the galv. pipes, the gunk inside breaks loose, and travels to the faucets, gets stuck, and limits the volume of water that comes out.
If possible open the lines at the service valves, and force water through the spigot to fluch out the faucet. The service value could also be partially clogged, keep that in mind
Aug 05, 2009 | Plumbing
Pegasus granite, black kitchen sink, rough on the bottam
As a plumber I have seen this problem many times.
A very simple solution!!!!!!!!!
Turtle Wax or any kind of granite counter polish. CorStone (sp?) used to send me a polish/wax that worked wonders but I havent delt with them in a long time so I dont know if it is still available.
Just use try Turtle Wax but make sure not to get Turtle Rubbing Compound as that has grit in it which will scratch the surface of your counter.
Hope this helps.
Apr 12, 2009 | Pegasus Technologies Pegasus 25 In. Black...
How to install supply lines for Grohe k4 faucet
I hope this helps.
Step11Turn off the water supply. You'll find a shut-off valve under your kitchen sinkmag-glass_10x10.gif. Once the water is turned off, open up the kitchen faucets to allow the water remaining in the pipes to drain way. Step2Catch the drips by placing a bucket under the hot water supply line, located on the left side of your sink. Even a minimum of water can cause a mess and be potentially damaging. Step3Use a wrench to remove the compression nut that secures the hot water supply line. Let the disconnected section fall into the bucket. Use the wrench to loosen and remove the nut at the other end of the line and remove it as well. Step4Repeat Steps 2 and 3 for the cold water supply line. Step5Replace the cold water supply line. Hand-tighten the nuts on both ends, then use the wrench to tighten the nuts completely. Repeat the process with the hot water supply line. Step6Turn on the water supply and test for leaks
Apr 08, 2009 | Grohe 32.074.KD0 K4 Prep Sink Single-Spray...
Inside of the carafe
The only thing that work well for me was Dishwasher liquid. put a litle in the pot with some real hot water, put the lid on and swirl for a minute, being careful not to spill. Then place in the maker filled with just enough water to fill the pot the rest of the way. Then shake and swirl over the sink, being very careful not to get that very hot water on you. You may have to do this twice. You will be surprized with all the junk that come out. Then rinse it a lot. Then I place vinegar and baking soda in the bottom and run it through the cycle twice . Very clean and fresh and the coffee tastes great. A lot of work though.
Apr 06, 2009 | Cuisinart DTC-975 Coffee Maker
Home Logo
85 people viewed this question
Top Corstone Industries Home Experts
Donni Steen
Tom Chichester
Are you a Corstone Industries Home Expert? Answer questions, earn points and help others
