Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
Need to remove handle from suction hose on Dyson dc-07 vacuum.
    Problem Solver:
  • 13 Answers
You have to remove the connector at the bottom part of your hose - It is Yellow in color
Posted on Sep 27, 2009
Loss of suction from base but ok from hose. filter cleaned and dried
When the Cyclone Assembly on the Dyson is not spinning around, it usually means that you are loosing suction somewhere. This can either be caused by a clog, suction leak, or dirty filters. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem # 1. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the vacuuming position with the handle down. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the handle was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
hope this helps you .........
Mar 11, 2015 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a dyson 07. Vacuum works fine, great suction using the hose. How do I switch to using the carpet vacuum. (I lost my instruction book) Thanks
If this unit has a suction hose built in to the handle, the carpet vacuum should start working after you return the handle hose to the proper position.
Dec 01, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I have a dyson dc 07 how on earth do i connect the flexible hose for cleasning the the stairs to the machine
Hi its Darran at Dyson.
I am not clear from your question as to whether you have purchased a replacement hose and need to know how to fit it or you are asking how you use the hose to vacuum?
If you are trying to fit a new hose, with the old one removed, simply line up the large plastic cuff on the base of the hose (this is the one with the cable tidy) and push it downwards into the slot at the base of the main body until it clicks into place. You can then insert the wand handle back in and store it on the machine.
If you would like to know how to to use the wand/hose, simply press the wand catch on the front of the wand handle just above the main carrying handle and pull it upwards. You can then splide the hose to the bottom of the metal pipe and press the button on the hose cuff to release the wand handle. The tools fit directly onto the hose cuff for vacuuming the car, your stairs or upholstery.
I hope that this information is useful to you.
Kind regards
Darran
Dyson Customer Service
Apr 03, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My Dyson dc 18 slim extender wand has NO suction. There is a plastic white cylinder object blocking.
If the floor head has suction and the wand does not, or vice-versa, the white cylinder you are referring to diverts the suction between the floor head and wand. If the flimsy plastic switch used to turn the cylinder is broken, you may need a new under carriage or just set the cylinder to wand or floor manually and use it as a one dimension cleaner. Depending on your ability, perhaps the switch can be purchases and replaced by a DIYer, but the job looks moderately difficult.
Jan 31, 2010 | Dyson DC18 Allergy Bagless Upright Vacuum
A Dyson dc 17 Animal and the wand/hose has lost suction
From your description of the problem, it sounds as though the wand/hose is blocked. To check this, remove the wand/hose assembly from the machine, switch it on and test the suction from the top of the wand with your hand. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its good here, then you know that the wand handle is blocked.
For the full diagnostics, check out the Support section on our website at www.dyson.com or call our Helpline on 1866MYDYSON.
Kind regards
Darran
Jan 30, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
I just bought a used Dyson DC07. Works good but
From your description of the problem, it sounds as though the wand/hose is blocked. To test this, please remove the wand from the machine and switch on, testing the suction from the top of the wand handle. If the suction is poor, remove the wand from the hose and test the suction from the top of the hose. If its strong from the hose itself, the wand is blocked and you will need to clear this.
If there is poor suction from the hose, you can remove this by unclipping it from the base of the machine and can then remove any blockages. It is also worth checking the hose for any splits or holes.
If you need any further help or advice, please visit our website at www.dyson.com and check out our support section.
Kind regards
Darran
Jan 30, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
My dyson 17 wand does not work. When it is on and you stand it upright it turns off
If the suction is good from the base but not from the wand, this would indicate that there is a blockage in the wand handle or hose. To test this, stand the machine upright and release the wand handle. Switch the machine on and test the suction from the top of the wand with your hand. If its poor, remove the wand handle from the hose and try the suction at the top of the hose. If its good here, then there is a blockage in the wand handle.
If the sction from the top of the hose is poor, you can remove the hose to check this for any splits or blockages. If it needs to be replaced, you can buy a replacement online at www.dyson.com.
Alternatively, should you any further help or advice with your Dyson, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Jan 25, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
No suction on wand of Dyson DC14 Animal
It sounds as though the wand handle is blocked. To check this, remove the wand/hose from the machine as if you were going to use it to vacuum the stairs. Switch the machine on and test the suction at the top of the wand handle with your hand. If the suction from the wand is poor, remove the wand from the hose and test the suction again from the top of the hose. If the suction here is good, then you know the wand handle is blocked. If the suction is poor at the hose, you can remove the hose from the machine and clear any blockages here.
For the full blockage procedure please visit the support section on our website at www.dyson.com.
Kind regards
Darran
Dyson customer Service
Jan 10, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Dyson DC 14 lost suction to beater bar/ suction to hose/stick
My Dyson DC14 had no suction...see if this works...turn the Dyson upside down...there is a length of hose that connects the bottom of the vacuum to the top, careful remove one end of the hose and check for debris...mine was clogged. Removed the clog and voila...it works. Thanks for the above info on checking the hose for cracks.
Apr 11, 2009 | Dyson DC14 All floors Bagless Upright...
I need to remove the handle from the suction hose on my Dyson DC-07 vacuum and can't seem to find screws or tabs to do this.
Take the handle out by pressing the Yellow tab on the top. Next remove the hose from the vacuum by lifting the yellow tab at the bottom part of the hose
Dec 29, 2008 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
61 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
