Question about Minolta EP4000/5000 CS/PRO Copier
Konica Minolta EP2010 CSPRO pages copy with black lines at top
I'm trying to return this copier to service, but have had no luck so far. The copier functions but leaves black shading across the top. I don't have much experience repairing copiers, so any help is appreciated.
Hi all,would anybody be willing to send me a user guide book on this photocopier....ep 2010 cs pro...regards
Posted on Feb 22, 2012
  • marcoallie
    marcoallie Feb 22, 2012
    hi all,would anybody be willing to send me a user guide book on this photocopier....ep 2010 cs pro...regards
  • 92 Answers
You must change the drum, or cartridge.
Posted on Dec 30, 2008
Konica Minolta Bizhub c754e Blue Lines after installing new machine
The blue toner cartridge or drum are damaged. First, try a different toner cartridge. This will probably eliminate the lines.
Apr 08, 2014 | Konica Minolta Office Equipment & Supplies
What's your problem?Minolta EP3050 CSPRO Copier printed copies, then display read ''malfunction detected'' code C0070
Main hopper toner replenishing motor M8 failure to turn.The output from toner bottle home position sensor does not go high within 5 seconds after M8 motor has been energized.Verify the conectors,sensor and motor.Open the front door,turn the toner bottle 1/4 turn clockwise manually with the bottle holder closed.Under the above condition does the toner bottle turn when the front door inter lock switch is turned on?NO - change the toner replenishing M8 motor.Does the toner bottle stop at home position after turning?NO- change PC35 toner bottle home position sensor.Recomanded use vacuum cleaner.
Aug 14, 2012 | Konica Minolta Copier Toner EP6001 CS Pro...
Minolta EP2010 CSPro copier: Where does the develper bottle go??? I see the Toner MT 102a bottle but where does the Develper bottle install. Or does the toner bottle already have the develper filings?
When the developer is added during normal replacement, the developer bottle is installed in place of the toner bottle. Then when the F8 mode is initiated from the service mode the developer is added into the developer unit and automatically calibrated. This is only done after the old developer has been cleaned from the DV unit.
The toner bottle contains no developer. The developer is replaced separately and only needs to be changed about every 80,000 pages.
Good Luck and Thnak You for using Fixya.
Sep 21, 2010 | Minolta Office Equipment & Supplies
Minolta CSPro copier is not printing
Change the transfer/separator corona holders,corona wires and clean the optics(mirrors,lens exposure lamp),and make a copies.
May 24, 2010 | Minolta EP4000/5000 CS/PRO Copier
C0400Exposure lamp does not turn on or AE sensor problem
1 Check the sanity of the lamp of the scan, contacts of the lamp
2 Contacts of the sensor to automatic exposure, he near by lens, do cleaning optometrists.
Oct 10, 2009 | Office Equipment & Supplies
Minolta cspro ep2010
Do you have two trays or four trays for the paper? If you have four and the display is showing the bottom door is open... turn the copier off and disconnect the bottom two trays and turn it back on..... Just use the top two paper trays.. Or the problem is that a acturator is broken off the side door, look for any broken pieces of plastic. Also, recheck for any jamed paper left in the copier.Good Luck
Jun 12, 2008 | Office Equipment & Supplies
Konica minolta EP2010 error code c05
I have a Konica Minolta CSPRO EP1054 (in the Middle East)
I accidentally plugged the EP1054 copier into a 110V outlet instead of the 220V. Immediately the malfunction code (error code) of "C05" appeared along with the "Call Tec Rep" indicator light (wrench).
I followed the instructions posted by "Soul Visitor" ... i.e., I found the "Trouble Reset Switch" (not shown in the user manual) by opening the upper back panel and pressing the small black button in the lower right hand corner of the middle circuit board (green).
It worked perfectly!7df26b9.tif
Nov 08, 2007 | Konica Minolta DiALTA Di200 Copier
456 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
