Perform the following optimizing steps:
- Clear history - Remove temporary internet files - Clear cache - Stop background running services - Update Java - Also update browsers
- Remove third party tool-bars - Remove unneeded extensions
- Defrag Hard-drive If the problem still exists then download a system optimizer tool for an instant fix. You can download it here: www.SpeedUpMyPC2013.net WebRepOverall ratingThis site has no rating(not enough votes)
Some of the tips for faster internet connection are,
* Check the Start up programs and remove the unwanted
* Maintain a Decent Space limit at Hard drive
* Check for Malware, Spyware and bots
* Clear cookies and temporary history files
* Close unwanted background tasks if any
* Reset the modem
* Browse with latest and updated browser
* Download using torrents
* Upgrade your hardware
Following these steps may fetch you a better result. You can see the difference in your connection speed by having a speed test before and after performing these steps. You can have speed test for free from www.ScanMySpeed.com . You will definitely see the difference.
SOURCE: my computer has high speed
1.Go to Start-> Run-> and type gpedit.msc
2. Expand the Administrative Templates branch
3. Expand the Network tab
4. Highlight QoS Packet Scheduler
5. Click on Limit Reservable Bandwidth and check the enabled box
6. Then Change the Bandwidth limit % to 0 %
Once you have done this click apply and restart your PC. After rebooting you should see a noticeable improvement in your net speed.
SOURCE: Slow Wireless
I'll assume from the wording of your question that you are using a USB wireless adapter.For the most part you get better performance out of a PCI wireless card (and better range) but you should also run a scan and clean with this program to make sure that your performance issues aren't due to spyware or malware also.
SOURCE: My computer is slow.
I am not sure of what type of memory your computer has but i will give you a list of probable causes and solutions:
1) Your hard drive might be too small or it might be full of stuff that will slow it down but this will be expensive to replace so i am going to show you how to speed it up. The way your computers hard disk works is by storing files on it, but there is no logical way for your computer to store it so it is stored anywhere on the hard disk instead of the beginning to the end and these are known as fragments. To solve this you can do the following: Click on "Start" then "All Programs" then "Accessories" then "System Tools" and then click on "Disk Defragmenter" and select C: drive to defragment, allow the computer to defrag your C; Drive, this may take a while, you should also defrag all other drives. To improve performance even more, Click on "Start" then "All Programs" then "Accessories" then "System Tools" and then click on "Disk Cleanup" and select C: drive to clean up and clean up all other drives as well.
2) This could also be a problem with your RAM (Random Access Memory), it could be too small and the only way to get around this is to upgrade or to make sure that you don't have too many programs running at once.
3) This could also be due to a virus. I would suggest that you download AVG Anti-virus or such alike programs and scan your whole computer to search for any viruses.
4) Click on "Start" and select "Control Panel" and then when you find "Add or Remove Programs" and open it. Find all the programs that you don't use and you would like to get rid of, even if they are small it still makes the computer scan more files before it finds what you are requesting.
5) You should also try and minimize on the amount of programs that open on start-up. You can see which programs start up when you turn on by checking at the bottom right hand corner or anything that pops up when you turn your computer on. To change these settings, open the program and find the settings and disable the feature usually called "Run on start-up".
I suggest that you do all of the above steps.
Thank you for using FixYa. Have a nice day and please remember to rate this solution.
Warm regards,
BearWeb
SOURCE: How can I speed up my computer for free.
some optimizations you can do to your computer:
1. Clean up registry to speed up computer.
2. Decrease auto-runs to boost stat-up.
3. Rational use of hard disk to fully utilize disk and avoid losing files.
4. Defrag disks to improve disk speed.
5. Remove junk files to free up disk space.
6. Put shortcuts properly to boost desktop loading.
7. Set virtual memory reasonably to fully utilize physical memory.
8. Forbidden hibernation function to save disk space.
9. Make a simple desktop to save system source.
and you can go http://www.ccleaner.com to download a registry optimizer. it will help to scan registry.
and then go http://www.system-tools-software.com/free-registry-defrag/ to download a totally free registry defrag to clean up your registry thoroughly.
SOURCE: Why is my computer so slow when I am paying $$ for
hi
if your PC is solve there 2 major problem
first check your RAM what seed it have if it's less then 1 GB up-great your RAM
second may be you have a virus in you PC scan you full systems
i hope you will find the solution
The type of documents displable on the internet contributes towards the speed capacity. Where for example word documents or email texts are displayable expediently than motion picture and videos. Consider the number of Medias displayable of the computer at a time to improve the internet speed. For example, display a site at a time and uninstalled unwanted program hinder on the computer background to make faster media displays. Usually computer that are slow to display programs are confused with internet pages that load slowly. A slow computer is due to insufficient memory to display caused by installing high capacity gaming software's or density chatting bundle software's. Once a computer gets video definitions gets over tasked, freezing is expertise directly impeding the internet networked capacity? It is also possible to have several devices sharing the computers networked internet connections. For example, the computer depending on the media cards magnitude can only allow an amount of bandwidth per time. Once connecting to an internet provider that provides high speed least makes benefit since the computers resources are least capable of attaining full capacity from signal provider. Consider evaluating the computes graphic capacities, also storage spaces available for hold sites downloaded from networks contribute towards faster speed.
