Question about Brother MFC-5840CN All-In-One InkJet Printer
I cannot send nor receive faxes.
I have tried everything I have read on here in regards to how to set up my brother mfc 5840cn to send and receive faxes. Every time I try to send a fax it says no dial tone. I know that's not true because I have my phone line plugged directly into the brother mfc 5840cn with another phone line coming out of it into an extension phone. I have double checked my phone lines and everything is in the proper place. When I receive an incoming fax - it just rings and never answers. I have noticed it saying "receiving" but it never seems to make it to whereever it belongs. Help.
  • 7 more comments
  • anattorney Nov 02, 2007
    Followed manual instructions regarding "distinctive ring" service; rechecked all telephone lines; verified that TAD is properly connected.
  • jim west Dec 15, 2007
    I have an MFC8220 all in one and I can not send or receive faxes. The phone line does not work eiher. The phone outlet conected to the fax and to the wireless set up seems to work alright. I have also replaced the cables and I have also replace the fax and nothing works. Please advise. Jim West
    Jwest2577@aol.com
  • Anonymous Mar 18, 2014
    I get an error 20-01 when I try to send a fax. I get an email to our fax account, that we recv'd a call to our fax line, but no fax tone was detected.
  • Anonymous Mar 24, 2014
    Our Brother 7340 fax machine will dial correctly but will not send or receive faxes. It always shows "LINe BUSY"
  • Anonymous Mar 25, 2014
    Just installed a Brother MFC-6890CDW Printer and all works great, just one problem. When sending a fax it rings the phone (about 4 times) and its quite annoying. Just wondered if there was anyway to switch that off?
    Thanks
    We can receive faxes but cannot send. We have a dial tone and can enter the number but it does not send.
  • Anonymous Mar 29, 2014
    fax problem send receive
  • Anonymous Mar 31, 2014
    problems with sending and receiving faxes. sounds like it is off line
    check the wireless setting and phone line
  • 186 Answers
Make sure the phone cord from the wall is plugged into the port marked"line" and not "phone".
Posted on Jul 10, 2007
Can't send fax because of message: Ink Empty Black-Replace Ink
No, the machine needs to have all cartridges installed to perform all actions, including fax and scanner functions.
Jun 02, 2009 | Brother MFC-5840CN All-In-One InkJet...
Fax not working
make sure that every jack is still connected and try to connect a phone to the where the printer is pluged in at and see if you have a dial tone
Sep 04, 2008 | Brother MFC-5840CN All-In-One InkJet...
Fax doesn't recognize incoming phone call
Try this: using a cell phone, call your fax. Listen on the cell for a busy signal, fax tones, dial tone, etc. If the fax does not answer the cell, check the following: make sure the phone line is plugged into the LINE jack on the fax, NOT THE PHONE JACK. The phone jack is to connect a TELEPHONE to the fax. If problem still exists, press MENU on your MFC, and scroll to GENERAL SETUP, FAX. Scroll to SETUP RECEIVE, and, after writing down the settings, try changing the RING DELAY or RING TIME settings. If problem is still there, press CLEAR/BACK button until GENERAL SETUP appears on screen. Scroll down to INITIAL SETUP, and select RECEIVE MODE. Try changing RECEIVE MODE settings. Write them down before you change anything.
Sep 01, 2008 | Brother MFC-5840CN All-In-One InkJet...
Print function stopped working. Brother MFC 5840CN
First things first:
press menu then start bk-copy then fourtimes arrow-up button. machine will display an error code no. plz post AS A NEW POST again.
BTW: The update has nothing to do with the stopping of the machine!
Jan 10, 2008 | Brother MFC-5840CN All-In-One InkJet...
"Receiving Sleep" on Brother Fax 4100
you might have to change the settings for the switching time into stand-by. plz have a look into the manual which describes these settings (zero seconds are possible)
Jan 09, 2008 | Brother MFC-5840CN All-In-One InkJet...
Brother mfc-5840cn
press menu then start mono then 4 times arrow-up (Tel index). machine will be in maintenance mode. press 8 then 0 (zero) then press the start mono button until display shows error A1: xy. Press the right arrow (Speaker +) button. What error codes do you see? (Machine saves the last ten errors). plz post here again.
To leave the maintenance mode press 9 then 9.
Nov 02, 2007 | Brother MFC-5840CN All-In-One InkJet...
I DON'T RECEIVED ANY THING I LISTEN THE NOISE FOR THE FAX
I guess the printer works fine when printing from pc. In this case plz read the manual. It explains the settings for the fax connection. You might have chosen a wrong fax setting. manual can be downloaded here:
http://welcome.solutions.brother.com/bsc/Public_s/index.html
(choose your country and your machine). Here you can find a faq too.
In case the printer doesnt print anything (even no document) from pc or doesnt do copies) it could be that your printhead is clogged.
IT will not print.
Error message Unable to Change Unable to Clean Unable to Init Unable to Print Unable to Scan Cause The MFC has a mechanical problem. OR A foreign obstacle, such as a clip or ripped paper, is in the MFC. Solution Open the scanner cover and remove any foreign obstacles from inside the MFC. If the error message continues, please follow the steps below before disconnecting the MFC so you will not lose any important messages. Then, disconnect the MFC from the power source for several minutes (which will erase all faxes), and then reconnect it. Check whether the MFC has faxes in the memory 1. Press Menu/Set, 9, 0, 1. 2. If the MFC has no faxes, disconnect the MFC from the power source for several minutes and then reconnect it. OR If faxes are present, you can transfer them to another fax machine. Go to Step 3. OR You can forward the faxes to your PC. Please see Transfer faxes to your PC. Transfer faxes to another fax machine If you have not set up your Station ID, you cannot enter fax transfer mode. 3. Enter the fax number to which faxes will be forwarded. 4. Press Black Start. 5. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. You can transfer the Fax Journal report to another fax machine by pressing Menu/Set, 9, 0, 2 in Step 1 Transfer faxes to your PC You can move the faxes from your MFC?s memory to your PC. 1. Press Menu/Set, 2, 5, 1. 2. Using ▲ or ▼, select PC Fax Receive, and then press Menu/Set. The LCD will ask if you want to transfer a fax to your PC. 3. To transfer all faxes to your PC, press 1. OR To keep all faxes in the MFC?s memory, press 2. 4. After the faxes are transferred, disconnect the MFC from the power source for several minutes and then reconnect it. (For details see Using Brother PC-FAX software on page 5-1 in Software User?s Guide on the CD-ROM.)
Sep 01, 2007 | Brother MFC-5840CN All-In-One InkJet...
Printer problem
MFC 5840cn - lcd shows 'unable to print see troubleshooting and routine'
Aug 20, 2007 | Brother MFC-5840CN All-In-One InkJet...
Brother MFC-5840CN All-In-One InkJet Printer Logo
216 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
