Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
I think I have the same TV darker color not as sharp
I had a service tech. look at the TV and he told my wife we have algae in the red and blue tubes and that they must be drained and new fluid replacing the old, is that true? I never heard of fluid needing to be replaced or in the tubes for that matter.
I was told the guns just need to be adjusted?
    Genius:
  • 2,920 Answers
The fluids do need to be changed occasionally.hes right about that.if you allow him to do it he will clean everything associated with the tubes
Posted on Dec 29, 2008
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
The color on my Phillips 60 rear projection big
that means that the phone needs to be unlock by the network provider
Mar 13, 2010 | Philips 60PP9202 60" Rear Projection...
My television is actually a magnavox 51mp6100d/37 51" rear projection and im having a problem with the picture! it is really bright in the middle and then going towards the outsides it gets darker and i...
YOU HAVE ALGAE IN THE BLUE AND GREEN TUBES IT DOES NOT GROW IN THE RED TUBE TAKE OFF THE FRONT COVER AND LOOK IN THE TUBES COMPAIRE IT WITH THE RED WHEN IT IS ON WITH A PICTURE WILL NOT HEART YOU TO LOOK IN THEM WITH IT ON DONT TRY TO FIX IT YOUR SELF
Feb 09, 2010 | Philips Magnavox 51MP392H Rear Projection...
Picture is red
If you are running component video, make sure the blue is plugged in and in the right spot. Component video works like this: the green is a black and white image, the red and blue are cover overlays to make the image display properly. So if everything looks plugged in right, then try plugging in a composite video (Yellow) or S-video cable switching to the appropriate input, and see if the image is still red. If so, go to the set up and set the set to factory defaults, and see if that fixes the color issue, It's possible that the color settings on the TV are messed up, with the S-video plugged in go through the set up menu and see if you can correct the color issue IF THE IMAGE IS STILL RED WITH THE S-VIDEO OR COMPOSITE VIDEO, otherwise the issue is a problem with the component video cable.
Oct 01, 2009 | Philips 60P8342 60" Rear Projection...
My tv color is blue and red is my lamp out or what
no your optic block is going south u need a new light engine big bucks
Sep 20, 2009 | Mitsubishi WS-55859 55" Rear Projection...
Magnavox PTV910 projection TV has blurred blue gun. The coolant in looks ok as far as I can tell from looking with a flashlight or with the TV on. There is also a buzz in the audio which I suspect to be a...
I don't know about the buzz but when you need to replace the coolant it isn't the coolant that actually gets blurry, it is algae that grows over the crt. It kinda looks like snow if you look in there, maybe a tannish color on the blue tube. Usually only grows on green and blue tubes as plants don't grow under red light. Lots of directions available to replace the coolant but my recommendation would be to tip the tv over backwards, pull the plastic focusing assembly clean off catching the old coolant in a cake pan. Be sure not to let any leak on boards as it is conductive. Once those are off you will be able to wipe the CRTs off with a soft cloth. Pretty easy to fill them back up with a small funnel.
If you don't see any algae in there, there are six color coded dials that adjust focus electrically and brightness.
Dave
Apr 19, 2009 | Televison & Video
Screen is getting darker
The most likely cause is the blue and green tubes need to have the cooling fluid changed. After many years the blue and green get clouded with algae. The red tube won't have the problem due to the red spectrum kills the algae before it has time to grow.
The way to replace the fluid for is to completely remove each CRT from the set, remove the drain plug, drain the fluid out the tube, disassemble the lens, give it a good cleaning; then reassemble; add fluid; and reinstall in set. If you check with the site www.TvRepairKits.com they are working on a kit that includes the fluid and photo instruction guide.
Dec 14, 2008 | Philips Magnavox 9P6034C 60" Rear...
Hardly any Blue Color in the picture. the blue tube is projecting darker and dimmer.
You need a Blue picture tube CRT you can get one for your JVC at the following link for a real decent price and they provide free shipping. Heres the link.
http://servicemanuals.vstore.ca/
Jun 07, 2008 | JVC AV-56WP74 56" Rear Projection...
Blue color
as far as alge ...i cant comment on that. it just sound like your blue tube has quit altogther/...yes they can be quite expesive..however it could be crt board..maybe...buy you a new one...LOL
Dec 06, 2007 | Akai PTH5498 54" Rear Projection...
Picture is yellow and green
Your missing the red drive on the set. Its most likly the picture tube. Its a possibility that the red drive circuit could be not working so the best thing to do is take off the gree picture tube socket and put the green board on the red tube. Of course do all this when the set is unplugged. if you have no tv experience. its not a good idea to be messing around inside of these sets.
Sep 02, 2006 | Hitachi 53UDX10B 53" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
47 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Brian Sullivan
Brian Sullivan
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
